<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release Notes for Mango 5.5.5]]></title><description><![CDATA[<p dir="auto"><a href="https://docs-v5.radixiot.com/v5-release-notes-overview#5.5.5" rel="nofollow ugc">v5 Release Notes Overview</a></p>
<p dir="auto"><strong>Mango 5.5.4 Release Notes (09/25/25)</strong></p>
<p dir="auto"><strong>access-control</strong></p>
<ul>
<li>Live only cameras can now be accessed on-demand when motion detection is disabled.</li>
<li>Added an option to limit the number of active camera readers simultaneously.</li>
<li>Fixed reader and recorder timing, corrected camera view FPS, resolved reconnection issues, and improved livestream stability to prevent lag and frame loss.</li>
<li>Live only camera readers prioritize UDP connections for better performance, automatically falling back to TCP if UDP is unavailable.</li>
<li>Migrate to JavaCV-based video processing pipeline.</li>
<li>VideoTransformer can be used with FFmpeg or JavaCV implementations.</li>
<li>Bundles required native dependencies (<strong>OpenCV 4.9 / FFmpeg 6.1.1 via bytedeco</strong>) for simpler setup.</li>
</ul>
<p dir="auto"><strong>bacnet-ds</strong></p>
<ul>
<li>The BACnet data source now uses the <strong>shared local device</strong> to emit an IAm message on initialization and listens for IAm messages from other devices to track certain properties.</li>
<li>Previously, each data source performed these functions independently, resulting in unnecessary messaging.</li>
<li>When a request for data to a device times out, only the <strong>polled points at that device</strong> are marked as unreliable.</li>
<li>Previously, all polled points in the data source were marked unreliable, even if other devices were responsive.</li>
</ul>
<p dir="auto"><strong>radix-tsl</strong></p>
<ul>
<li>Fixed an issue where Mango failed to start up when the TLS module was enabled.</li>
</ul>
]]></description><link>https://forum.mango-os.com/topic/6154/release-notes-for-mango-5.5.5</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 12:38:18 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/6154.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Oct 2025 14:14:48 GMT</pubDate><ttl>60</ttl></channel></rss>
