<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Copying&#x2F;recreating a Meta Data source from project to project]]></title><description><![CDATA[<p dir="auto">Hello everyone, I'm hoping someone can help me figure out how to quickly copy a meta data source from one project to another.</p>
<p dir="auto">I am going to have to create multiple similar Dashboards  with the same data structure just different data point XIDS for each site.</p>
<p dir="auto">Ive looked around for ways to upload a json or csv but meta data sources do not have that option.</p>
<p dir="auto">I understand i would need to remap all of the XIDS to the meta data points each time but im looking to at least save myself from having to manually create each meta data point within the meta data source since they will all be identical but with a varying number of points.</p>
<p dir="auto">Anyone know how to do this?</p>
]]></description><link>https://forum.mango-os.com/topic/5946/copying-recreating-a-meta-data-source-from-project-to-project</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 23:08:45 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5946.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Feb 2025 17:14:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Copying&#x2F;recreating a Meta Data source from project to project on Mon, 24 Feb 2025 21:57:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joeamiraglia" aria-label="Profile: joeamiraglia">@<bdi>joeamiraglia</bdi></a> Is there a procedure or guidance on how to do this? I tried and it gave me an error when trying to upload the exported meta data source.</p>
]]></description><link>https://forum.mango-os.com/post/28379</link><guid isPermaLink="true">https://forum.mango-os.com/post/28379</guid><dc:creator><![CDATA[SGAF]]></dc:creator><pubDate>Mon, 24 Feb 2025 21:57:00 GMT</pubDate></item><item><title><![CDATA[Reply to Copying&#x2F;recreating a Meta Data source from project to project on Mon, 24 Feb 2025 19:15:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sgaf" aria-label="Profile: SGAF">@<bdi>SGAF</bdi></a> Hello, you should be able to export the Meta Data Source and its points directly from the Data Source. Alternatively, you can use the Configuration Import/Export tool to export all data sources and/or data points and then make your edits. Please note that if you remove the XIDs from the Data Points and substitute the XID of the Data Source on the other system, new data points created during the import to the other system will be assigned new XIDs. As you mentioned, context points will need to be mapped. Thank you.</p>
]]></description><link>https://forum.mango-os.com/post/28378</link><guid isPermaLink="true">https://forum.mango-os.com/post/28378</guid><dc:creator><![CDATA[joeamiraglia]]></dc:creator><pubDate>Mon, 24 Feb 2025 19:15:58 GMT</pubDate></item></channel></rss>
