<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Editing mango.properties for Process Event]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I need to run a Windows command script for a process event, specifically to disable/enable a COM port.<br />
Mango returns:</p>
<pre><code>Process event handler is disabled, you must explicitly enabled it via mango.properties
<p dir="auto">I cannot find in the documentation what to put in the mango.properties file to enable this.<br />
There is nothing obvious already in the file that is commented out?</p>
<p dir="auto">Thanks for any help.</p>
]]></description><link>https://forum.mango-os.com/topic/5891/editing-mango-properties-for-process-event</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:04:29 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5891.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Sep 2024 02:21:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Editing mango.properties for Process Event on Tue, 24 Sep 2024 06:42:38 GMT]]></title><description><![CDATA[<p dir="auto">I put the newly created mango.properties file in the mango root folder, just with the specific lines as above.<br />
This worked</p>
]]></description><link>https://forum.mango-os.com/post/28301</link><guid isPermaLink="true">https://forum.mango-os.com/post/28301</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Tue, 24 Sep 2024 06:42:38 GMT</pubDate></item><item><title><![CDATA[Reply to Editing mango.properties for Process Event on Tue, 24 Sep 2024 02:36:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi Terry,</p>
<p dir="auto">Does the mango.properties file go in the overrides folder, or in the bin folder?<br />
I can't even find it, so I will have to create it.</p>
<p dir="auto">H</p>
]]></description><link>https://forum.mango-os.com/post/28300</link><guid isPermaLink="true">https://forum.mango-os.com/post/28300</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Tue, 24 Sep 2024 02:36:06 GMT</pubDate></item><item><title><![CDATA[Reply to Editing mango.properties for Process Event on Mon, 23 Sep 2024 22:37:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a> Thanks Terry</p>
]]></description><link>https://forum.mango-os.com/post/28299</link><guid isPermaLink="true">https://forum.mango-os.com/post/28299</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 23 Sep 2024 22:37:48 GMT</pubDate></item><item><title><![CDATA[Reply to Editing mango.properties for Process Event on Mon, 23 Sep 2024 17:33:57 GMT]]></title><description><![CDATA[<p dir="auto">The settings introduced in mango 5.2.0</p>
<pre><code>## Settings for event handlers
# Enable the process event handler
event-handlers.process.enabled=false
# Enable interpolation for the process event handler command
event-handlers.process.interpolation-enabled=false
]]></description><link>https://forum.mango-os.com/post/28298</link><guid isPermaLink="true">https://forum.mango-os.com/post/28298</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 23 Sep 2024 17:33:57 GMT</pubDate></item></channel></rss>
