<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango v5.1.4 SSL]]></title><description><![CDATA[<p dir="auto">Good afternoon, I am installing Mango v5.1.4 and I do not want it to use SSL. However, if I set ssl.on=false in mango.properties, the database does not initialize and it does not start. What is the configuration to access the web on port 8080?</p>
]]></description><link>https://forum.mango-os.com/topic/5825/mango-v5-1-4-ssl</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 19:47:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5825.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jun 2024 11:44:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango v5.1.4 SSL on Wed, 05 Jun 2024 16:13:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jdiaz-co" aria-label="Profile: Jdiaz-co">@<bdi>Jdiaz-co</bdi></a> I just reproduced this, this is a bug and we will fix it in the next release. Can I ask why you want to disable SSL? You should be able to access the HTTP port on 8080 even if SSL is enabled.</p>
<p dir="auto">If you are having trouble accessing Mango on port 8080, try disabling HSTS using <code>ssl.hsts.enabled=false</code> and clear your browser cache. HSTS tells your web browser to only ever use HTTPS for that website.<br />
<a href="https://en.wikipedia.org/wiki/HTTP_Strict_Transport_Security" rel="nofollow ugc">https://en.wikipedia.org/wiki/HTTP_Strict_Transport_Security</a></p>
]]></description><link>https://forum.mango-os.com/post/28191</link><guid isPermaLink="true">https://forum.mango-os.com/post/28191</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Wed, 05 Jun 2024 16:13:55 GMT</pubDate></item></channel></rss>
