<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Now using mysql]]></title><description><![CDATA[<p dir="auto">hi, have migrated from derby to mysql and all data seems to be retrievable and all is working ok...</p>
<p dir="auto">questions though...</p>
<p dir="auto">1/. the existing mangodb folder... is that redundant? can it be deleted?</p>
<p dir="auto">2/. when i go in system settings, its now unaware of database type and database size... is this normal?</p>
<p dir="auto">3/. for scada jobs with 500 tags with per sample change logging, will mysql really make the system better? is there a point where derby can manage ok, then struggle?</p>
<p dir="auto">4/. do the database purge facilities work ok whilst using mysql?</p>
<p dir="auto">5/. will subsequent mango upgrades respect choice of external DB?</p>
<p dir="auto">thanks</p>
<p dir="auto">Neil</p>
]]></description><link>https://forum.mango-os.com/topic/581/now-using-mysql</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 11:36:57 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/581.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Oct 2010 23:42:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Now using mysql on Fri, 22 Oct 2010 05:05:50 GMT]]></title><description><![CDATA[<p dir="auto">Ok. Unfortunately your description doesn't ring any bells. If you ever produce the error again, let me know.</p>
]]></description><link>https://forum.mango-os.com/post/4726</link><guid isPermaLink="true">https://forum.mango-os.com/post/4726</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Fri, 22 Oct 2010 05:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to Now using mysql on Thu, 21 Oct 2010 23:04:36 GMT]]></title><description><![CDATA[<p dir="auto">hi,</p>
<p dir="auto">alas i dont, since i had to revert back to the derby setup as this job is in use.</p>
<p dir="auto">it appeared to be pointed towards a failure to delete due to a nested object failure giving a -1 error.</p>
<p dir="auto">baslically i'd converted a 150mb derby db to sql.</p>
<p dir="auto">this project had about 2 dozen data sources, one of which i no longer needed.</p>
<p dir="auto">i attempted to delete the data source (deleting all the tags at the same time) and it failed with this nested -1 failure).</p>
<p dir="auto">so i then proceeded to delete tags withing the container instead.... which was ok unitl i got to this particular tag... and this still prevented me from deleting the data source too..</p>
<p dir="auto">so for the time being i'm using derby again.</p>
]]></description><link>https://forum.mango-os.com/post/4716</link><guid isPermaLink="true">https://forum.mango-os.com/post/4716</guid><dc:creator><![CDATA[skiv71]]></dc:creator><pubDate>Thu, 21 Oct 2010 23:04:36 GMT</pubDate></item><item><title><![CDATA[Reply to Now using mysql on Thu, 21 Oct 2010 20:30:00 GMT]]></title><description><![CDATA[<p dir="auto">Do you have a more specific error message regarding why the point could not be deleted?</p>
]]></description><link>https://forum.mango-os.com/post/4708</link><guid isPermaLink="true">https://forum.mango-os.com/post/4708</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 21 Oct 2010 20:30:00 GMT</pubDate></item><item><title><![CDATA[Reply to Now using mysql on Tue, 19 Oct 2010 07:55:14 GMT]]></title><description><![CDATA[<p dir="auto">just an update...</p>
<p dir="auto">whilst using my project with conversion to mysql, i had need to delete an array of points within a soon to be redundant data source...</p>
<p dir="auto">so i tried to delete the datasource and had errors about nested object, -1 from the browser in relation to the sql instance.</p>
<p dir="auto">so i then proceeded to delete individual data points, which was successful, apart from one, which refused giving the same error.</p>
<p dir="auto">i have now gone back to derby for the time being....</p>
<p dir="auto">am i missing something, or is this a bug etc?</p>
<p dir="auto">also, i'm noticing that my popup charts arent working now when the web server is viewed from a remote source...</p>
<p dir="auto">i'll check the logs but i guess its trying to look up the derby database and struggling for some reason.</p>
]]></description><link>https://forum.mango-os.com/post/4660</link><guid isPermaLink="true">https://forum.mango-os.com/post/4660</guid><dc:creator><![CDATA[skiv71]]></dc:creator><pubDate>Tue, 19 Oct 2010 07:55:14 GMT</pubDate></item><item><title><![CDATA[Reply to Now using mysql on Mon, 18 Oct 2010 03:46:01 GMT]]></title><description><![CDATA[<p dir="auto">Jokke is correct. Some additional info:</p>
<ol start="2">
<li>
<p dir="auto">Mango cannot provide information about the size of the MySQL database because all it has is a url to a schema. Unlike Derby, it doesn't have a data directory that it can measure.</p>
</li>
<li>
<p dir="auto">MySQL should provide better performance, yes. In most circumstances Derby is a perfectly fine database, but there are certain situations where MySQL provides vastly better performance. There have not been any noticeable cases where Derby is better than MySQL.</p>
</li>
<li>
<p dir="auto">Yes, and in fact, this is one of the cases where MySQL is noticeably better.</p>
</li>
<li>
<p dir="auto">Mango will continue to support both Derby and MySQL indefinitely. They serve competing needs: Derby is for convenience, MySQL is for performance.</p>
</li>
]]></description><link>https://forum.mango-os.com/post/4646</link><guid isPermaLink="true">https://forum.mango-os.com/post/4646</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 18 Oct 2010 03:46:01 GMT</pubDate></item><item><title><![CDATA[Reply to Now using mysql on Sun, 17 Oct 2010 09:50:41 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have been also using MySql. Here are some I have noticed.</p>
<p dir="auto">1/. Yes it can be removed<br />
2/. Same here, it has been the way as long I know.<br />
3/. No idea<br />
4/. I have not faced any problem<br />
5/. Seems working well. I started with v1.8 and have incrementally updated to v1.11 without issues.</p>
<p dir="auto">BR<br />
-Jokke</p>
]]></description><link>https://forum.mango-os.com/post/4638</link><guid isPermaLink="true">https://forum.mango-os.com/post/4638</guid><dc:creator><![CDATA[Jokke]]></dc:creator><pubDate>Sun, 17 Oct 2010 09:50:41 GMT</pubDate></item></channel></rss>
