<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Static Serial Chart]]></title><description><![CDATA[<p dir="auto">Is it possible to insert data points the chart series directly from the Dashboard designer without having to use the Edit markup?</p>
<p dir="auto">How could I do that? It's not clear to me.</p>
]]></description><link>https://forum.mango-os.com/topic/5617/static-serial-chart</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 15:17:39 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5617.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Feb 2023 21:58:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Static Serial Chart on Mon, 20 Feb 2023 20:02:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: MattFox">@<bdi>MattFox</bdi></a> I appreciate it. I may have a use case for that at some point, but don't sweat it, there's no rush.</p>
<p dir="auto">At the very least, it might help others, and be something to reference if it comes up again.</p>
]]></description><link>https://forum.mango-os.com/post/27634</link><guid isPermaLink="true">https://forum.mango-os.com/post/27634</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Mon, 20 Feb 2023 20:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Mon, 20 Feb 2023 19:20:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> the form example they use to save to the json data store is a good example, but it depends on how many points of data you need to show on a chart at a time.<br />
It demonstrates how you can store and recall data. I'll throw something basic together.<br />
Ideally, the best way to make this work would be storing a complete amchart profile using the chart-options property, that way you can render the chart as desired.</p>
<p dir="auto">I can probably throw something together as a quick reference for others to work from. It won't be anything flash</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/27631</link><guid isPermaLink="true">https://forum.mango-os.com/post/27631</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 20 Feb 2023 19:20:46 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Mon, 20 Feb 2023 19:01:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: MattFox">@<bdi>MattFox</bdi></a><br />
I'm not familiar with that sort of thing. Do you have any documentation on how to work with that? I don't know much about web development.</p>
<p dir="auto">For now, I copied and pasted from the old HTML into the new one and was successful.</p>
]]></description><link>https://forum.mango-os.com/post/27629</link><guid isPermaLink="true">https://forum.mango-os.com/post/27629</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Mon, 20 Feb 2023 19:01:44 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Sat, 18 Feb 2023 08:36:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> if you're programming savvy - it might not hurt to throw yourself together a dashboard page that stores your chart configs as json in the json_data store.</p>
<p dir="auto">This means you can create a template dashboard page with a fixed configuration and naming conventions. Then those fields are populated via the json_data object your page pulls in. Ideal for high component re-use without the frustration of copy and pasting.</p>
]]></description><link>https://forum.mango-os.com/post/27626</link><guid isPermaLink="true">https://forum.mango-os.com/post/27626</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sat, 18 Feb 2023 08:36:39 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Sat, 18 Feb 2023 04:41:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> I think you still have to stick to the old way</p>
]]></description><link>https://forum.mango-os.com/post/27625</link><guid isPermaLink="true">https://forum.mango-os.com/post/27625</guid><dc:creator><![CDATA[tungthanh500]]></dc:creator><pubDate>Sat, 18 Feb 2023 04:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Sat, 18 Feb 2023 02:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: MattFox">@<bdi>MattFox</bdi></a></p>
<p dir="auto">Doesn't seem like it.</p>
<p dir="auto">When I click on the inputs "series-&lt;x&gt;-value" I don't get a prompt to select a data point xid.</p>
<p dir="auto"><img src="https://camo.nodebb.org/5ea54161248eea0e1c2996d054d6280b1cdfbde2?url=https%3A%2F%2Fi.imgur.com%2F1bzj0CF.png" alt="Screenshot from 2023-02-17 20-47-58.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The last time I did this, I had to do it through manual editing of the HTML content, and I was hoping it would have been improved in v4; Ideally I'd like to stick to a single way to maintain these dashboards, instead of a mix of methods.</p>
]]></description><link>https://forum.mango-os.com/post/27624</link><guid isPermaLink="true">https://forum.mango-os.com/post/27624</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Sat, 18 Feb 2023 02:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to Static Serial Chart on Fri, 17 Feb 2023 22:24:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a> unless the option presents itself in the attributes options on the right hand side, then no.</p>
]]></description><link>https://forum.mango-os.com/post/27623</link><guid isPermaLink="true">https://forum.mango-os.com/post/27623</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Fri, 17 Feb 2023 22:24:21 GMT</pubDate></item></channel></rss>
