<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release Notes for mangoApi 4.4.0]]></title><description><![CDATA[<p dir="auto"><strong>mangoApi</strong> - Version 4.4.0</p>
<ul>
<li>Upgraded for Mango 4.4.0</li>
<li>Upgrade Spring library version to 5.3.18 (mitigates CVE-2022-22965)</li>
<li>/point-values methods now leverage new AggregateDao interface from Core to query time-series databases</li>
<li>/point-values useCache parameters no longer support BOTH option</li>
<li>/point-values some JSON fields which used to contain null values will now be excluded from the model</li>
<li>/point-values bookend JSON field will always be true/false if BOOKEND is specified in fields</li>
<li>/point-values limit parameter now applies to the returned JSON array length for all single-array queries</li>
<li>/point-values fix queries for POINT_DEFAULT rollup for points configured with NONE rollup type</li>
<li>/point-values queries for POINT_DEFAULT rollup will only use point’s “simplify type” if the point’s rollup is set to NONE</li>
</ul>
]]></description><link>https://forum.mango-os.com/topic/5539/release-notes-for-mangoapi-4-4-0</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 14:58:44 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5539.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Oct 2022 16:32:05 GMT</pubDate><ttl>60</ttl></channel></rss>
