<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tag columns visible in Data Sources > Data Points View]]></title><description><![CDATA[<p dir="auto">When viewing the data points for a data source, the default view seems to be all tags as columns. Tags are proving very useful but this behavior is quite unwieldy as you end up with a very wide container you need to horizontally scroll through by default.</p>
<p dir="auto">Similarly, when tags are unchecked, this isn't remembered on page update, i.e. refresh or point edit.</p>
]]></description><link>https://forum.mango-os.com/topic/5518/tag-columns-visible-in-data-sources-data-points-view</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:39:29 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5518.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 May 2022 11:32:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tag columns visible in Data Sources > Data Points View on Wed, 01 Jun 2022 03:21:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cbyrne" aria-label="Profile: cbyrne">@<bdi>cbyrne</bdi></a><br />
I second all your comments about the tags display. It is even worse when you use points with tags in meta data or scripting data source.</p>
]]></description><link>https://forum.mango-os.com/post/27379</link><guid isPermaLink="true">https://forum.mango-os.com/post/27379</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Wed, 01 Jun 2022 03:21:08 GMT</pubDate></item></channel></rss>
