<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoGT  units fail to upgrade and now fail to send email]]></title><description><![CDATA[<p dir="auto">I have several MangoES units and two MangoGT units all running V3.<br />
The MangoES units continue to run fine, are able to access the store and perform module upgrades as they are released.<br />
However the MangoGT units haven't been able to access the store for the past couple months and a couple weeks ago stopped being able to send emails and reports via email.<br />
I use a <a href="http://gmail.com" rel="nofollow ugc">gmail.com</a> account on the MangoES units but the MangoGT units never worked with gmail so I use a <a href="http://mail.com" rel="nofollow ugc">mail.com</a> account for them.<br />
The ma.log shows authentication errors but the user and password for the mail account haven't changed.<br />
The module upgrade returns a "versioning problem" error.<br />
Below is the latest ma.log info. Any help with this greatly appreciated, I don't know what to do!</p>
<p dir="auto">WARN  2022-02-15T08:50:03,016 (com.serotonin.m2m2.rt.maint.work.EmailWorkItem.execute:94) - Error sending email<br />
org.springframework.mail.MailAuthenticationException: Authentication failed; nested exception is javax.mail.AuthenticationFailedException: 535 Authentication credentials invalid</p>
<pre><code>at org.springframework.mail.javamail.JavaMailSenderImpl.doSend(JavaMailSenderImpl.java:439) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
at org.springframework.mail.javamail.JavaMailSenderImpl.send(JavaMailSenderImpl.java:360) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
at org.springframework.mail.javamail.JavaMailSenderImpl.send(JavaMailSenderImpl.java:377) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
at org.springframework.mail.javamail.JavaMailSenderImpl.send(JavaMailSenderImpl.java:365) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
at com.serotonin.web.mail.EmailSender.send(EmailSender.java:179) ~[mango-3.7.7.jar:?]
at com.serotonin.web.mail.EmailSender.send(EmailSender.java:170) ~[mango-3.7.7.jar:?]
at com.serotonin.web.mail.EmailSender.send(EmailSender.java:123) ~[mango-3.7.7.jar:?]
at com.serotonin.m2m2.rt.maint.work.EmailWorkItem.execute(EmailWorkItem.java:91) ~[mango-3.7.7.jar:?]
at com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl$WorkItemRunnable.run(BackgroundProcessingImpl.java:671) ~[mango-3.7.7.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
at java.lang.Thread.run(Thread.java:830) [?:?]
<p dir="auto">Caused by: javax.mail.AuthenticationFailedException: 535 Authentication credentials invalid</p>
<pre><code>at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:965) ~[javax.mail-1.6.2.jar:1.6.2]
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:876) ~[javax.mail-1.6.2.jar:1.6.2]
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:780) ~[javax.mail-1.6.2.jar:1.6.2]
at javax.mail.Service.connect(Service.java:366) ~[javax.mail-api-1.6.2.jar:1.6.2]
at org.springframework.mail.javamail.JavaMailSenderImpl.connectTransport(JavaMailSenderImpl.java:517) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
at org.springframework.mail.javamail.JavaMailSenderImpl.doSend(JavaMailSenderImpl.java:436) ~[spring-context-support-5.1.7.RELEASE.jar:5.1.7.RELEASE]
... 11 more
<p dir="auto">INFO  2022-02-15T08:50:25,828 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c hostname<br />
INFO  2022-02-15T08:50:25,855 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c cat /etc/timezone<br />
INFO  2022-02-15T08:50:25,878 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c /opt/mango/web/modules/mangoESConfiguration/resources/scripts/linux/timezone.sh -l<br />
INFO  2022-02-15T08:50:26,008 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c AP_CONF=<code>sudo /etc/init.d/hostapd status | grep /usr/sbin/hostapd | grep -o "[^ ]*conf"</code> &amp;&amp; if [ -e $AP_CONF ]; then cat $AP_CONF | grep -oP "(?&lt;=^interface=).<em>"; fi<br />
INFO  2022-02-15T08:50:26,304 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c ip addr<br />
INFO  2022-02-15T08:50:26,338 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c sudo /sbin/iwconfig<br />
INFO  2022-02-15T08:50:26,439 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c cat $(ls /etc/network/interfaces.d/</em>.cfg) /etc/network/interfaces<br />
INFO  2022-02-15T08:50:26,464 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c ps -ef | grep dhclient<br />
INFO  2022-02-15T08:50:26,624 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c ip route<br />
INFO  2022-02-15T08:50:26,647 (com.infiniteautomation.system.SystemManager.createProcess:107) - Running command: sh -c ip -6 route<br />
WARN  2022-02-15T08:50:43,441 (com.serotonin.m2m2.rt.maint.work.EmailWorkItem.execute:94) - Error sending email<br />
... 11 more
<p dir="auto">ERROR 2022-02-15T08:51:08,613 (com.serotonin.m2m2.web.dwr.ModulesDwr.versionCheck:174) -<br />
javax.net.ssl.SSLHandshakeException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed<br />
at sun.security.ssl.Alert.createSSLException(Alert.java:131) ~[?:?]<br />
at sun.security.ssl.TransportContext.fatal(TransportContext.java:324) ~[?:?]<br />
at sun.security.ssl.TransportContext.fatal(TransportContext.java:267) ~[?:?]<br />
at sun.security.ssl.TransportContext.fatal(TransportContext.java:262) ~[?:?]<br />
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1331) ~[?:?]<br />
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(CertificateMessage.java:1206) ~[?:?]<br />
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(CertificateMessage.java:1153) ~[?:?]<br />
at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:396) ~[?:?]<br />
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:444) ~[?:?]<br />
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:422) ~[?:?]<br />
at sun.security.ssl.TransportContext.dispatch(TransportContext.java:181) ~[?:?]<br />
at sun.security.ssl.SSLTransport.decode(SSLTransport.java:164) ~[?:?]<br />
at sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1460) ~[?:?]<br />
at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1368) ~[?:?]<br />
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:437) ~[?:?]<br />
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:396) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:355) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108) ~[httpclient-4.5.5.jar:4.5.5]<br />
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56) ~[httpclient-4.5.5.jar:4.5.5]<br />
at com.serotonin.web.http.HttpUtils4.executeWithRetries(HttpUtils4.java:174) ~[mango-3.7.7.jar:?]<br />
at com.serotonin.web.http.HttpUtils4.getTextContent(HttpUtils4.java:132) ~[mango-3.7.7.jar:?]<br />
at com.serotonin.m2m2.web.dwr.ModulesDwr.getAvailableUpgrades(ModulesDwr.java:416) ~[mango-3.7.7.jar:?]<br />
at com.serotonin.m2m2.web.dwr.ModulesDwr.versionCheck(ModulesDwr.java:147) ~[mango-3.7.7.jar:?]<br />
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]<br />
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]<br />
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]<br />
at java.lang.reflect.Method.invoke(Method.java:567) ~[?:?]<br />
at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34) ~[dwr-2.0.11.jar:?]<br />
at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) ~[dwr-2.0.11.jar:?]<br />
at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37) ~[mango-3.7.7.jar:?]<br />
at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26) ~[mango-3.7.7.jar:?]<br />
at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:46) ~[mango-3.7.7.jar:?]<br />
at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431) ~[dwr-2.0.11.jar:?]<br />
at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283) ~[dwr-2.0.11.jar:?]<br />
at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52) ~[dwr-2.0.11.jar:?]<br />
at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101) ~[dwr-2.0.11.jar:?]<br />
at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146) ~[dwr-2.0.11.jar:?]<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) ~[javax.servlet-api-3.1.0.jar:3.1.0]<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.servlet-api-3.1.0.jar:3.1.0]<br />
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1617) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at com.infiniteautomation.mango.webapp.filters.MangoCacheControlHeaderFilter.doFilter(MangoCacheControlHeaderFilter.java:155) ~[mango-3.7.7.jar:?]<br />
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1604) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.authentication.switchuser.SwitchUserFilter.doFilter(SwitchUserFilter.java:200) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at com.serotonin.m2m2.web.mvc.spring.security.RateLimitingFilter.doFilterInternal(RateLimitingFilter.java:53) ~[mango-3.7.7.jar:?]<br />
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]<br />
at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter(PermissionExceptionFilter.java:34) ~[mango-3.7.7.jar:?]<br />
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:155) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:74) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178) ~[spring-security-web-5.1.5.RELEASE.jar:5.1.5.RELEASE]<br />
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]<br />
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270) ~[spring-web-5.1.7.RELEASE.jar:5.1.7.RELEASE]<br />
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:545) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590) ~[jetty-security-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485) ~[jetty-servlet-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:221) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:767) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.Server.handle(Server.java:500) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270) ~[jetty-server-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[jetty-io-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938) ~[jetty-util-9.4.23.v20191118.jar:9.4.23.v20191118]<br />
at java.lang.Thread.run(Thread.java:830) [?:?]<br />
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed<br />
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:349) ~[?:?]<br />
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:247) ~[?:?]<br />
at sun.security.validator.Validator.validate(Validator.java:264) ~[?:?]<br />
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:231) ~[?:?]<br />
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132) ~[?:?]<br />
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1315) ~[?:?]<br />
... 127 more<br />
Caused by: java.security.cert.CertPathValidatorException: signature check failed<br />
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135) ~[?:?]<br />
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:237) ~[?:?]<br />
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:145) ~[?:?]<br />
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:84) ~[?:?]<br />
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:309) ~[?:?]<br />
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:344) ~[?:?]<br />
... 127 more<br />
Caused by: java.security.SignatureException: Signature does not match.<br />
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:450) ~[?:?]<br />
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166) ~[?:?]<br />
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147) ~[?:?]<br />
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125) ~[?:?]<br />
... 127 more</p>
]]></description><link>https://forum.mango-os.com/topic/5482/mangogt-units-fail-to-upgrade-and-now-fail-to-send-email</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 16:07:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5482.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Feb 2022 20:09:38 GMT</pubDate><ttl>60</ttl></channel></rss>
