<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Audible Alarm with silence]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
I am facing a problem. I have 2 tanks, and both are continuously filling with water. I have 2 "sensors" to detect the water level of both tanks. If water level exceed a pre-set level, the sensor status will change from Open to Closed and send a signal to a Digital Input.</p>
<p dir="auto">With modbus TCP, I can get the status of that Digital Input (Input Status) <img src="https://camo.nodebb.org/8380202ffe90c4ff85144373dcde4277aefb7527?url=https%3A%2F%2Fi.imgur.com%2F1rMAc9G.png" alt="f7ac1eca-d42a-43c3-9953-922e511b34f9-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I want to create a dashboard with ability to make alarm sound when Digital Input change from 0 to 1, and that sound is <strong>only muted if I press a button on the dashboard.</strong> I tried <strong>Event Audio</strong> but the audio only last for several seconds.</p>
<p dir="auto">Is there any suggestion for this?</p>
]]></description><link>https://forum.mango-os.com/topic/5406/audible-alarm-with-silence</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 06:47:17 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5406.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Dec 2021 13:30:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Audible Alarm with silence on Thu, 16 Dec 2021 16:19:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tungthanh500" aria-label="Profile: tungthanh500">@<bdi>tungthanh500</bdi></a> have you seen the UI settings at  <code>/ui/administration/ui-settings</code> which allow you to choose an audio file? There's no provision to loop an audio file as far as I remember, you would need to create a custom component for this.</p>
]]></description><link>https://forum.mango-os.com/post/27192</link><guid isPermaLink="true">https://forum.mango-os.com/post/27192</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 16 Dec 2021 16:19:51 GMT</pubDate></item></channel></rss>
