<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Two Publisher Problems]]></title><description><![CDATA[<p dir="auto">In the Mango version 2.7.10, i try to use two publishers (ports 502, slave 1 and 503, slave 1). When i check the open ports in the server, only appear the first one:</p>
<p dir="auto"><img src="https://camo.nodebb.org/0843f0e0b7fbf8a56a4ce453d3e2c85e78ea1070?url=https%3A%2F%2Fi.imgur.com%2FGePAoNo.png" alt="d6cb4f10-a28c-4f17-b912-a8f09a97f10a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">checking the logs file, i found this message:</p>
<pre><code>ERROR 2021-11-05 16:05:00,060 (com.infiniteautomation.modbus.publisher.rt.ModbusIpSlave.receivedException:166) - Publisher Slave Error
java.io.IOException: Stream closed.
	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:458)
	at java.net.SocketInputStream.available(SocketInputStream.java:245)
	at java.io.BufferedInputStream.available(BufferedInputStream.java:399)
	at com.serotonin.modbus4j.sero.messaging.InputStreamListener.run(InputStreamListener.java:63)
	at com.serotonin.modbus4j.sero.messaging.StreamTransport.run(StreamTransport.java:40)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
<p dir="auto">This Mango version only support one publisher? i have others servers with Mango version 3.x.x and i dont have this problem.</p>
<p dir="auto">Java version 7<br />
OS Centos 7.x</p>
<p dir="auto">Regards.</p>
<p dir="auto">Ricardo Palma</p>
]]></description><link>https://forum.mango-os.com/topic/5341/two-publisher-problems</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 23:22:59 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5341.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Nov 2021 22:23:11 GMT</pubDate><ttl>60</ttl></channel></rss>
