<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SSL&#x2F;HTTP Post error]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I am having trouble sending HTTP Post data to a Mango server. It was working previously but it seems to have stopped since the SSL cert was updated. When I try to send HTTP post from another instance of Mango I get the following error on the client side</p>
<p dir="auto">sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target</p>
<p dir="auto">Any help would be appreciated.</p>
<p dir="auto">Rob</p>
]]></description><link>https://forum.mango-os.com/topic/5281/ssl-http-post-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 08:39:53 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5281.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Aug 2021 09:07:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SSL&#x2F;HTTP Post error on Fri, 20 Aug 2021 16:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robmalone">@<bdi>robmalone</bdi></a> said in <a href="/post/26952">SSL/HTTP Post error</a>:</p>
<p dir="auto">Once the Mango environmental properties file was pointing to the keystore it worked.</p>
<p dir="auto">So you are all good now?  Or still having issues?  If you are still stuck you should follow the recommendations in that StackTrace link about enabling SSL logging by adding this to the java command that is starting mango:</p>
<pre><code>-Djavax.net.debug=SSL
<p dir="auto">And seeing what the details of the problem are.</p>
]]></description><link>https://forum.mango-os.com/post/26953</link><guid isPermaLink="true">https://forum.mango-os.com/post/26953</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 20 Aug 2021 16:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to SSL&#x2F;HTTP Post error on Fri, 20 Aug 2021 16:27:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker">@<bdi>terrypacker</bdi></a> Hi Terry, I had seen that and followed the instructions on how to import the cert into Java but im still getting the same error. This was something I never had to do before. Once the Mango environmental properties file was pointing to the keystore it worked.</p>
<p dir="auto">There is nothing in the server log (receiver end)</p>
<pre><code>INFO  2021-08-20T17:07:57,253 (com.serotonin.m2m2.Main.main:121) - Starting Mango 3.7.4 with Schema Version: 29
INFO  2021-08-20T17:08:00,378 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'asciiFile', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,503 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'BACnet', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,550 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'controlcore', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,581 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'dashboardDesigner', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,597 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\mango\web\modules\dashboardDesigner\web\dox\manifest.xml
INFO  2021-08-20T17:08:00,612 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'dataFile', v3.7.1 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,659 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'dataImport', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,690 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'deviceConfig', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,690 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\mango\web\modules\deviceConfig\web\dox\manifest.xml
INFO  2021-08-20T17:08:00,722 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'dnp3', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,737 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'egauge', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,768 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'envcands', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,784 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'excelReports', v3.7.1 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:00,847 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'graphicalViews', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,034 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'Haystack', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,081 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'http', v3.7.1 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,112 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'jsonFileImport', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,144 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'log4jDS', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,159 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'log4JReset', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,159 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'loggingConsole', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,190 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'maintenanceEvents', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,237 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'mangoApi', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,300 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'mangoNoSqlDatabase', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,347 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'mangoUI', v3.7.2 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:01,362 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\mango\web\modules\mangoUI\web\dox\manifest.xml
INFO  2021-08-20T17:08:01,956 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'mbus', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,003 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'meta', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,065 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'modbus', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,112 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'onewire', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,159 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'opcda', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,175 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'pakbus', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,222 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'persistent', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,284 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'pointLinks', v3.7.1 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,315 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'pop3', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,347 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'reports', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,456 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'scheduledEvents', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,487 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'scripting', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,519 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'serial', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,534 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'snmp', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,565 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'sqlConsole', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,597 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'sqlds', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,643 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'ssh', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,675 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'sstGlobalScripts', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,706 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'sstGraphics', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,925 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'TCPIP', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:02,940 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'templateConfig', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:03,018 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'twilio', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:03,065 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'virtualDS', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:03,097 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'vmstat', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:03,128 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'watchlists', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:03,268 (com.serotonin.m2m2.Main.loadModules:650) - Loading module 'internal', v3.7.0 by Infinite Automation Systems Inc.
INFO  2021-08-20T17:08:23,237 (com.serotonin.m2m2.Lifecycle.loadLic:583) - Checking license...
INFO  2021-08-20T17:08:23,815 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:64) - Initializing H2 connection manager
INFO  2021-08-20T17:08:31,823 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:38) - Starting instance with core version 3.7.4, schema v29
INFO  2021-08-20T17:08:31,824 (com.infiniteautomation.nosql.MangoNoSqlProxy.initialize:77) - Starting MangoNoSql Database
INFO  2021-08-20T17:08:32,135 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:144) - Database at C:\mango\databases\mangoTSDB started
WARN  2021-08-20T17:08:33,707 (org.eclipse.jetty.server.HttpChannelState.asyncError:739) - org.eclipse.jetty.io.EofException: Reset cancel_stream_error
WARN  2021-08-20T17:08:33,815 (org.eclipse.jetty.server.HttpChannelState.asyncError:739) - org.eclipse.jetty.io.EofException: Reset cancel_stream_error
WARN  2021-08-20T17:08:33,978 (org.eclipse.jetty.server.HttpChannelState.asyncError:739) - org.eclipse.jetty.io.EofException: Reset cancel_stream_error
WARN  2021-08-20T17:08:37,500 (org.eclipse.jetty.server.HttpChannelState.asyncError:739) - org.eclipse.jetty.io.EofException: Reset cancel_stream_error
WARN  2021-08-20T17:08:37,552 (org.eclipse.jetty.server.HttpChannelState.asyncError:739) - org.eclipse.jetty.io.EofException: Reset cancel_stream_error
INFO  2021-08-20T17:08:48,472 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:173) - Empty dir delete for database at C:\mango\databases\mangoTSDB took 16224ms
INFO  2021-08-20T17:08:48,534 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:234) - Corruption scan for database at C:\mango\databases\mangoTSDB skipped because the database is configured not to run scan.
INFO  2021-08-20T17:08:48,565 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:144) - Database at C:\mango\databases\mangoTSDBAux started
INFO  2021-08-20T17:08:48,616 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:173) - Empty dir delete for database at C:\mango\databases\mangoTSDBAux took 0ms
INFO  2021-08-20T17:08:48,616 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:234) - Corruption scan for database at C:\mango\databases\mangoTSDBAux skipped because the database is configured not to run scan.
INFO  2021-08-20T17:09:01,179 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'runtimeContext' refreshed: org.springframework.context.annotation.AnnotationConfigApplicationContext@277b8fa4
INFO  2021-08-20T17:09:01,210 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextStarted:147) - Spring context 'runtimeContext' started: org.springframework.context.annotation.AnnotationConfigApplicationContext@277b8fa4
INFO  2021-08-20T17:09:02,475 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:77) - Initializing 6 NORMAL priority data sources in 8 threads.
INFO  2021-08-20T17:09:02,549 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source VM stats took 48ms to start
INFO  2021-08-20T17:09:02,596 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Sigfox HTTP POST took 97ms to start
INFO  2021-08-20T17:09:03,040 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Powerpoint Engineering Offices took 540ms to start
INFO  2021-08-20T17:09:03,756 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source DAY TEST took 1277ms to start
INFO  2021-08-20T17:09:08,731 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Mango Internal took 6219ms to start
INFO  2021-08-20T17:09:13,534 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Sigfox TX Energy took 11022ms to start
INFO  2021-08-20T17:09:13,565 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:109) - Initialization of 6 NORMAL priority data sources took 11090ms
INFO  2021-08-20T17:09:13,566 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:77) - Initializing 5 LAST priority data sources in 8 threads.
INFO  2021-08-20T17:09:13,705 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source OPW Sender took 144ms to start
INFO  2021-08-20T17:09:17,186 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Sample Data Points took 3614ms to start
INFO  2021-08-20T17:09:21,117 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source 2RN Summary Report took 7550ms to start
INFO  2021-08-20T17:09:21,456 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source 2RNSubloads took 7888ms to start
INFO  2021-08-20T17:09:22,830 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:408) - Data source Day and night points took 9262ms to start
INFO  2021-08-20T17:09:22,899 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:109) - Initialization of 5 LAST priority data sources took 9333ms
INFO  2021-08-20T17:09:23,297 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:176) - Starting 2 Publishers...
INFO  2021-08-20T17:09:23,297 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:178) - Starting publisher: for dashboard development
INFO  2021-08-20T17:09:23,297 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:178) - Starting publisher: Energy Elephant
INFO  2021-08-20T17:09:23,298 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:188) - 2 Publisher's started in 122ms
INFO  2021-08-20T17:09:32,956 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'rootWebContext' refreshed: Root WebApplicationContext
INFO  2021-08-20T17:09:39,565 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'jspDispatcherContext' refreshed: WebApplicationContext for namespace 'JSP_DISPATCHER-servlet'
INFO  2021-08-20T17:09:40,934 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'restDispatcherContext' refreshed: WebApplicationContext for namespace 'REST_DISPATCHER-servlet'
INFO  2021-08-20T17:09:47,398 (com.serotonin.m2m2.web.mvc.rest.v1.BacnetDiscoveryRestController.&lt;init&gt;:54) - Creating Discovery Rest Controller
INFO  2021-08-20T17:09:48,479 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'restV1Context' refreshed: WebApplicationContext for namespace 'restV1DispatcherServlet-servlet'
INFO  2021-08-20T17:09:58,029 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:133) - Spring context 'restV2Context' refreshed: WebApplicationContext for namespace 'restV2DispatcherServlet-servlet'
<p dir="auto">On the client side there are log entries but only related to the publisher failing</p>
<pre><code>WARN  2021-08-20T16:22:57,321 (com.serotonin.m2m2.rt.publish.PublishQueue.sizeCheck:102) - Publisher queue Powerpoint Engineering Offices discarded 4 entries
]]></description><link>https://forum.mango-os.com/post/26952</link><guid isPermaLink="true">https://forum.mango-os.com/post/26952</guid><dc:creator><![CDATA[Robmalone]]></dc:creator><pubDate>Fri, 20 Aug 2021 16:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to SSL&#x2F;HTTP Post error on Fri, 20 Aug 2021 13:23:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robmalone">@<bdi>robmalone</bdi></a> are you seeing anything in the log output of either Mango?  If so please provide that.</p>
<p dir="auto">A quick google search turned up this: <a href="https://stackoverflow.com/questions/6908948/java-sun-security-provider-certpath-suncertpathbuilderexception-unable-to-find" rel="nofollow ugc">https://stackoverflow.com/questions/6908948/java-sun-security-provider-certpath-suncertpathbuilderexception-unable-to-find</a></p>
<p dir="auto">It could be that Mango isn't pointed at the correct keystore, the one with the new cert in it?</p>
]]></description><link>https://forum.mango-os.com/post/26951</link><guid isPermaLink="true">https://forum.mango-os.com/post/26951</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 20 Aug 2021 13:23:37 GMT</pubDate></item></channel></rss>
