<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Metadata Internal Server Error]]></title><description><![CDATA[<p dir="auto">Mango 4.0.0-beta.17</p>
<p dir="auto">I am trying to configure a metadata source point, and just a very simple test script based off of the examples. However, I am unable to save the point, it always returns and "internal server error". Is it me or a bug?</p>
<p dir="auto"><img src="https://camo.nodebb.org/045313a196fb04236f64a2dc5317c393a783562d?url=https%3A%2F%2Fi.imgur.com%2FkCfWaoO.png" alt="MetaDataSourceError.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/5228/metadata-internal-server-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 15:37:02 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5228.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jul 2021 14:56:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Metadata Internal Server Error on Fri, 02 Jul 2021 17:51:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brownbucks11" aria-label="Profile: brownbucks11">@<bdi>brownbucks11</bdi></a> another option would be to install the nashorn module which will provide the engine to the JVM when Mango starts.</p>
<p dir="auto"><a href="https://store.infiniteautomation.com/module/nashorn" rel="nofollow ugc">https://store.infiniteautomation.com/module/nashorn</a></p>
]]></description><link>https://forum.mango-os.com/post/26747</link><guid isPermaLink="true">https://forum.mango-os.com/post/26747</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 02 Jul 2021 17:51:54 GMT</pubDate></item><item><title><![CDATA[Reply to Metadata Internal Server Error on Fri, 02 Jul 2021 16:38:52 GMT]]></title><description><![CDATA[<p dir="auto">I managed to work through the issue, looking at the ma.log I saw an error relating to nashorn unavailable, which relates to the Java JDK. I was using open JDK 11 LTS with hotspot. I decided to take a snapshot my VM and uninstall the Adopt open JDK and install the oracle JDK11. These are the General Steps I used.</p>
<p dir="auto">Stopped Mango Service<br />
Uninstalled Adopt Open JDK11<br />
Installed Oracle JDK11<br />
Changed the below Environmental Paths:<br />
1.) JAVA_HOME to "C:\Program Files\Java\jdk-11.0.11"<br />
2.) Path to include "C:\Program Files\Java\jdk-11.0.11\bin" instead of the openJDK path<br />
3.) Path added new "%JAVA_HOME%\bin"</p>
<p dir="auto">I then uninstalled Mango as a service<br />
Restarted Server<br />
Installed Mango as a service<br />
Started service</p>
<p dir="auto">Everything seems to be working as expected, except my script returned an error but that was somewhat expected.</p>
]]></description><link>https://forum.mango-os.com/post/26746</link><guid isPermaLink="true">https://forum.mango-os.com/post/26746</guid><dc:creator><![CDATA[brownbucks11]]></dc:creator><pubDate>Fri, 02 Jul 2021 16:38:52 GMT</pubDate></item><item><title><![CDATA[Reply to Metadata Internal Server Error on Fri, 02 Jul 2021 16:23:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brownbucks11" aria-label="Profile: brownbucks11">@<bdi>brownbucks11</bdi></a> The only issue I can see from the pic is that you have not. selected which point should trigger the script to update.  At least one of the update check boxes should be checked.</p>
]]></description><link>https://forum.mango-os.com/post/26745</link><guid isPermaLink="true">https://forum.mango-os.com/post/26745</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Fri, 02 Jul 2021 16:23:38 GMT</pubDate></item></channel></rss>
