<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to reference and display points tag property]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I want to display some of the tag properties of each point on the dashboard graphics.<br />
I have done a search on the forum but can not find the definitely answer to the syntax.<br />
Can someone shed some light?<br />
I have attached a screenshot below with an arrow pointing to one of the tags (description) that I want to display:<br />
<img src="https://camo.nodebb.org/2f6a91bf1aeaa043f65a7f1f5b18a0507ab72fa1?url=https%3A%2F%2Fi.imgur.com%2F3wNK1I9.jpg" alt="tag - description.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mango-os.com/topic/5226/how-to-reference-and-display-points-tag-property</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 17:37:01 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5226.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jul 2021 05:31:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to reference and display points tag property on Tue, 06 Jul 2021 00:24:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: mattfox">@<bdi>mattfox</bdi></a><br />
thank you. Matt.<br />
It is working.<br />
see below:<br />
<img src="https://camo.nodebb.org/5d13cbfcefe2122105ba1e5504ff8224da5cdfc0?url=https%3A%2F%2Fi.imgur.com%2FAlta4UN.jpg" alt="description tag working.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26766</link><guid isPermaLink="true">https://forum.mango-os.com/post/26766</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Tue, 06 Jul 2021 00:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to How to reference and display points tag property on Fri, 02 Jul 2021 10:00:45 GMT]]></title><description><![CDATA[<p dir="auto">Evening Victor, you can get the tags by the following format</p>
<pre><code>{{Point.tags.tagName}}
<p dir="auto">However, if your tag has a space in it:</p>
<pre><code>{{Point.tags['tag name'] }}
<p dir="auto">In your case,</p>
<pre><code>{{ Point.tags.description}}
<p dir="auto">Hope that points you in the right direction!</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/26743</link><guid isPermaLink="true">https://forum.mango-os.com/post/26743</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Fri, 02 Jul 2021 10:00:45 GMT</pubDate></item></channel></rss>
