<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Event Handler Target Point]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I am creating a set point event handler to use with the advanced scheduler, following this <a href="https://docs-v3.mango-os.com/advanced-7day-scheduler?rq=advanced%20scheduler" rel="nofollow ugc">video</a></p>
<p dir="auto">In the set point settings of the Event Handler there's a field I can not quite understand how to use. the "Target Point"<br />
If the goal is to set several data points, one loads them in the External context points, and set their keys to use in the active and inactive actions scripts.<br />
Now, the target point gives me the option of every point I have in the system and does not allows to leave it blank.<br />
What to put there?<br />
<img src="https://camo.nodebb.org/a697b9ea12b86348c15d34ac0ab267ad9a5ff1d5?url=https%3A%2F%2Fi.imgur.com%2FoZEe3W6.png" alt="Screenshot_1.png" class=" img-fluid img-markdown" /><br />
Thanks,<br />
Best,<br />
Rodrigo</p>
]]></description><link>https://forum.mango-os.com/topic/5116/event-handler-target-point</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 09:31:13 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5116.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Mar 2021 23:50:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Event Handler Target Point on Sun, 07 Mar 2021 23:09:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Matt!</p>
<p dir="auto">Best,<br />
Rodrigo</p>
]]></description><link>https://forum.mango-os.com/post/26383</link><guid isPermaLink="true">https://forum.mango-os.com/post/26383</guid><dc:creator><![CDATA[Rodrigo]]></dc:creator><pubDate>Sun, 07 Mar 2021 23:09:35 GMT</pubDate></item><item><title><![CDATA[Reply to Event Handler Target Point on Sat, 06 Mar 2021 22:48:03 GMT]]></title><description><![CDATA[<p dir="auto">Refer to what I gave you in the other post.<br />
Take note you only need to select your target point. After that you move over a few tabs to choose your active and inactive actions.<br />
The options being</p>
<li>Setting a value from another data point</li>
<li>Statically assigning a value i.e. true, false, a number, or a string</li>
<li>Setting a value based upon what is returned from running a script.</li>
<p dir="auto">The last being what your external context points are for.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/26381</link><guid isPermaLink="true">https://forum.mango-os.com/post/26381</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sat, 06 Mar 2021 22:48:03 GMT</pubDate></item></channel></rss>
