<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t browse tags with OPC DA Datasource]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I have created OPC DA Datasource at Mango v4.0.0.beta5 on Windows server. Although, OPC Server seen on the Serves List, I got a "Request Timeout" error when I Browse Tags on OPC DA Tools. What could be the possible reason?</p>
<p dir="auto">Additionally, OPC server and Mango are installed on the same server. And also, we can connect and browse tags by using Matricon application on the same server.</p>
<p dir="auto"><img src="https://camo.nodebb.org/f7153ad36021fcffd7e6a47735fc87009428d523?url=https%3A%2F%2Fi.imgur.com%2FhpePWbv.png" alt="2a2fcfe7-7e28-452d-b788-cae57037d3f7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks in advance,</p>
]]></description><link>https://forum.mango-os.com/topic/5068/can-t-browse-tags-with-opc-da-datasource</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 02:14:14 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5068.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jan 2021 10:53:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t browse tags with OPC DA Datasource on Thu, 28 Jan 2021 13:06:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a> thanks. we got this error, when the device is offline on the site. As a result, we successfully get the data with OPC DA.</p>
]]></description><link>https://forum.mango-os.com/post/26236</link><guid isPermaLink="true">https://forum.mango-os.com/post/26236</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Thu, 28 Jan 2021 13:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t browse tags with OPC DA Datasource on Thu, 28 Jan 2021 06:08:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Nurr</p>
<p dir="auto">I looked at the code where that error originates from.  Before the data source looks at the value it looks at the quality of the tag. If the quality is bad then the DS will throw an error and ignore the value.  You will need to figure out why the server has bad quality for those tags.  But at least you are getting a response from the server.</p>
]]></description><link>https://forum.mango-os.com/post/26234</link><guid isPermaLink="true">https://forum.mango-os.com/post/26234</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 28 Jan 2021 06:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t browse tags with OPC DA Datasource on Thu, 28 Jan 2021 04:56:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a> ,</p>
<p dir="auto">I changed host with localhost and browsed tags on the OPC DA Tools tab. Then, I added some points but can not get values.</p>
<p dir="auto">Additionally, when I change host with localhost, I got an "BAD_QUALITY" error like below.</p>
<p dir="auto"><img src="https://camo.nodebb.org/6ac8b2986e13331c3f0e29ca599d0fe2a8344c8d?url=https%3A%2F%2Fi.imgur.com%2FWPNHS9F.png" alt="9008e7a5-b5db-463b-9e49-75fbc66baa75-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/26233</link><guid isPermaLink="true">https://forum.mango-os.com/post/26233</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Thu, 28 Jan 2021 04:56:29 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t browse tags with OPC DA Datasource on Wed, 27 Jan 2021 13:10:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Nurr</p>
<p dir="auto">if the OPC server and Mango are on the same server you should be using<br />
<code>localhost</code> as the host name</p>
]]></description><link>https://forum.mango-os.com/post/26227</link><guid isPermaLink="true">https://forum.mango-os.com/post/26227</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Wed, 27 Jan 2021 13:10:18 GMT</pubDate></item></channel></rss>
