<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to add Local device address on BACNet datasource?]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I'm trying to create BACNet datasource on Mango v4.0.0.beta3. I do not see Local Device address on datasources page. Additionally, "Local devices can be defined in system settings" is written on the help part. How should I add local device adress via System Settings?</p>
<p dir="auto"><img src="https://camo.nodebb.org/a6188857cbf4b7c15c573e194a7bf222ac2a7778?url=https%3A%2F%2Fi.imgur.com%2FdiT7d5g.png" alt="70637c62-2bc4-4c87-9cee-dae9d8568468-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">By the way, I had the same issue with Mango v.3.7.7. I used the legacy page to create BACNet datasource and Local Device part is filled automatically with ip and port.</p>
<p dir="auto">So that, there is no legacy page on Mango v4.0.0, how should I add BACNet datasource?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forum.mango-os.com/topic/5067/how-to-add-local-device-address-on-bacnet-datasource</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 10:33:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5067.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Jan 2021 12:17:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to add Local device address on BACNet datasource? on Mon, 30 May 2022 21:34:05 GMT]]></title><description><![CDATA[<p dir="auto">I found the BACnet local devices menu in the Utilities section under "Admin Home". Here you can create or modify the local devices. Once you create a local device there, it is available in the add new data sources section</p>
]]></description><link>https://forum.mango-os.com/post/27375</link><guid isPermaLink="true">https://forum.mango-os.com/post/27375</guid><dc:creator><![CDATA[shawn.hateley]]></dc:creator><pubDate>Mon, 30 May 2022 21:34:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to add Local device address on BACNet datasource? on Wed, 27 Jan 2021 05:07:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a>  Thank you.</p>
]]></description><link>https://forum.mango-os.com/post/26224</link><guid isPermaLink="true">https://forum.mango-os.com/post/26224</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Wed, 27 Jan 2021 05:07:37 GMT</pubDate></item><item><title><![CDATA[Reply to How to add Local device address on BACNet datasource? on Tue, 26 Jan 2021 12:31:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Nurr you can add the BACnet local devices to the menu under the edit menu page.</p>
]]></description><link>https://forum.mango-os.com/post/26217</link><guid isPermaLink="true">https://forum.mango-os.com/post/26217</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Tue, 26 Jan 2021 12:31:14 GMT</pubDate></item></channel></rss>
