<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango ES - The administration menu is not expaning]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">As I am connected over the revers SSH to the Mango ES,  the Administration menu when clicked is not expanding.</p>
<p dir="auto">The Mango version is 3.5, If I upgrade it to 3.7 will it affect that error?</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.mango-os.com/topic/5061/mango-es-the-administration-menu-is-not-expaning</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 06:20:50 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5061.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Jan 2021 23:33:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango ES - The administration menu is not expaning on Thu, 11 Feb 2021 19:57:11 GMT]]></title><description><![CDATA[<p dir="auto">If you are going to do an upgrade, copy the entire mango directory, bzip it if you have to so then you have a working backup on the mango unit itself. You can do this over ssh assuming you have remote shell access.</p>
<p dir="auto">Alternatively, stick with Firefox as its only google chrome that is pulling this jazz.</p>
<p dir="auto">To be honest though, I would stay with 3.5 as there are still a number of issues on 3.7 that haven't been fixed as the dev team are swamped with mango 4Beta.</p>
<p dir="auto">Just use a different web browser.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/26307</link><guid isPermaLink="true">https://forum.mango-os.com/post/26307</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 11 Feb 2021 19:57:11 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES - The administration menu is not expaning on Thu, 11 Feb 2021 11:50:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninok" aria-label="Profile: NinoK">@<bdi>NinoK</bdi></a> is your ssh access through cloud connect or do you have a direct network connection to the mangoES.  I you have ssh access that is not through cloud connect you will not need to drive out as you can fix the failed upgrade through ssh.</p>
]]></description><link>https://forum.mango-os.com/post/26304</link><guid isPermaLink="true">https://forum.mango-os.com/post/26304</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 11 Feb 2021 11:50:45 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES - The administration menu is not expaning on Wed, 10 Feb 2021 12:00:50 GMT]]></title><description><![CDATA[<p dir="auto">Thanks,</p>
<p dir="auto">The device is on the remote site, and I am reluctant to do the upgrade, since if the upgrade fails I will need to travel to the site.</p>
<p dir="auto">Is there any way to make the image of the device and eventually connect remotely and install the image using the dd command?</p>
]]></description><link>https://forum.mango-os.com/post/26294</link><guid isPermaLink="true">https://forum.mango-os.com/post/26294</guid><dc:creator><![CDATA[NinoK]]></dc:creator><pubDate>Wed, 10 Feb 2021 12:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES - The administration menu is not expaning on Wed, 20 Jan 2021 06:05:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi Ninok</p>
<p dir="auto">you will need to upgrade the Mango UI module to the latest version.</p>
]]></description><link>https://forum.mango-os.com/post/26197</link><guid isPermaLink="true">https://forum.mango-os.com/post/26197</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Wed, 20 Jan 2021 06:05:35 GMT</pubDate></item></channel></rss>
