<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Data Point different logging then configuration]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Some data points on Mango do not log as configured. For example, the point shown below is  configured to log for 5 miutes Interval and point value changes with the tolerance 0.1. There are some logs that is recorded 6 minutes interval. What could be possible cause for that?</p>
<p dir="auto"><img src="https://camo.nodebb.org/81eeb7e31ecc8119e28f05eae380f41e1cae83d6?url=https%3A%2F%2Fi.imgur.com%2F5alEyeS.png" alt="d0ac076d-2b72-4240-ae6e-9b931529907a-image.png" class=" img-fluid img-markdown" /><br />
<img src="https://camo.nodebb.org/c29e3eca9505e056b0fe2047636c628bd82b753f?url=https%3A%2F%2Fi.imgur.com%2FTwyL5PZ.png" alt="d6f0d251-f6fc-4517-90ab-92e18736fea7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Mango Version : v.3.7.7</p>
<p dir="auto">Thanks in advance,</p>
]]></description><link>https://forum.mango-os.com/topic/5054/data-point-different-logging-then-configuration</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 21:36:40 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5054.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jan 2021 12:04:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 11:18:12 GMT]]></title><description><![CDATA[<p dir="auto">Interestingly i have just tested it out and it seems that there is some kind of a rounding thing coming up with values being exactly the threshold value. If value changes next fraction of the threshold then this does not happen.</p>
<p dir="auto">A quick test</p>
<p dir="auto">Create a virtual point with exact settings</p>
<p dir="auto">Current value 1<br />
Set point to 1.01<br />
No logging<br />
Set point back to 1.0<br />
Set point to 1.011<br />
Logging appears</p>
<p dir="auto">If going to other way around</p>
<p dir="auto">Current value 1.01<br />
Set point to 1.00<br />
Logging appears</p>
<p dir="auto">I am guessing datalogging does not happen if new value is greater than current value in the defined threshold but if new value is lower then current value in the defined threshold then logging works correctly.</p>
<p dir="auto">I might also fish out an idea that @Nurr polling time is related to the issue (I guess it might be once per minute?) where the cached value is the new over threshold limit but it does not get logged but still triggers a reset for interval logging and then it has been the same for 5 minutes and then it gets logged by the interval logging sequence.</p>
<p dir="auto">But still even though this happens, interval logging still works in my instance so I guess this information is not actually so relevant.</p>
]]></description><link>https://forum.mango-os.com/post/26280</link><guid isPermaLink="true">https://forum.mango-os.com/post/26280</guid><dc:creator><![CDATA[ThomasEinasto]]></dc:creator><pubDate>Thu, 04 Feb 2021 11:18:12 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 10:52:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a> I would like to log both every 5 minutes and when current point value is 0.1  higher/lower than previous value.</p>
<p dir="auto">Is the logging configuration is wrong for this purpose?</p>
<p dir="auto">In this configuration, point should not wait to log point value for 6 minutes.</p>
]]></description><link>https://forum.mango-os.com/post/26279</link><guid isPermaLink="true">https://forum.mango-os.com/post/26279</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Thu, 04 Feb 2021 10:52:43 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 10:37:59 GMT]]></title><description><![CDATA[<p dir="auto">@Nurr  I see what is happening as Terry explained here</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a> said in <a href="/post/26173">Data Point different logging then configuration</a>:</p>
<p dir="auto">@Nurr never mind about the timestamps.  You are using "Interval logging and point value changes".  This type of logging will log every 5 minutes AND when the value changes.</p>
<p dir="auto">if you want the point to log on a 5min interval. then just use the interval log.<br />
The interval and value change log will also trigger a log if the point changes by the tolerance after a data source poll.</p>
]]></description><link>https://forum.mango-os.com/post/26278</link><guid isPermaLink="true">https://forum.mango-os.com/post/26278</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 04 Feb 2021 10:37:59 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 10:18:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a></p>
<p dir="auto">Here is the link to download timestamped values.</p>
<p dir="auto"><a href="https://we.tl/t-f4tPmTlGJ6" rel="nofollow ugc">https://we.tl/t-f4tPmTlGJ6</a></p>
]]></description><link>https://forum.mango-os.com/post/26277</link><guid isPermaLink="true">https://forum.mango-os.com/post/26277</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Thu, 04 Feb 2021 10:18:21 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 09:36:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Nurr</p>
<p dir="auto">Can you export the time series of this point that is doing it and show us the exact timestamps of the log entry.</p>
]]></description><link>https://forum.mango-os.com/post/26276</link><guid isPermaLink="true">https://forum.mango-os.com/post/26276</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 04 Feb 2021 09:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Thu, 04 Feb 2021 09:13:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a> if the scenarios is like you said, value should be logged earlier than 5 minutes. But the point log shows that it is 6 minutes between two logs.</p>
<p dir="auto">We should explain the situation to our customer asap.</p>
]]></description><link>https://forum.mango-os.com/post/26275</link><guid isPermaLink="true">https://forum.mango-os.com/post/26275</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Thu, 04 Feb 2021 09:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Mon, 18 Jan 2021 16:11:51 GMT]]></title><description><![CDATA[<p dir="auto">@Nurr it is possible that you are seeing a rendered value which makes it look like there was a difference of 0.01 but if you look at the raw data you might find the difference to be slightly larger and being rounded by the TextRenderer on that point.  Just a thought, the logging in your scenario works like I said about.</p>
]]></description><link>https://forum.mango-os.com/post/26191</link><guid isPermaLink="true">https://forum.mango-os.com/post/26191</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 18 Jan 2021 16:11:51 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Mon, 18 Jan 2021 08:40:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a> tolerance config is set 0.1. The difference between the data point log shown in red box on the picture is 0.01.</p>
<p dir="auto">If interval is set to 5 minutes and 0.1 tolerance for point value changes, point should be logged maximum 5 minutes intervals. But there are some logs with 6 minutes interval.</p>
<p dir="auto">We have some other points with the same issue.</p>
]]></description><link>https://forum.mango-os.com/post/26189</link><guid isPermaLink="true">https://forum.mango-os.com/post/26189</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Mon, 18 Jan 2021 08:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Tue, 12 Jan 2021 16:33:32 GMT]]></title><description><![CDATA[<p dir="auto">@Nurr never mind about the timestamps.  You are using "Interval logging and point value changes".  This type of logging will log every 5 minutes AND when the value changes.</p>
]]></description><link>https://forum.mango-os.com/post/26173</link><guid isPermaLink="true">https://forum.mango-os.com/post/26173</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Tue, 12 Jan 2021 16:33:32 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Tue, 12 Jan 2021 12:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a>,</p>
<p dir="auto">We faced with the same situation on different Modbus datasources. What do you mean for exact timestamps?</p>
]]></description><link>https://forum.mango-os.com/post/26172</link><guid isPermaLink="true">https://forum.mango-os.com/post/26172</guid><dc:creator><![CDATA[Malaguena]]></dc:creator><pubDate>Tue, 12 Jan 2021 12:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to Data Point different logging then configuration on Mon, 11 Jan 2021 18:41:38 GMT]]></title><description><![CDATA[<p dir="auto">@Nurr what type of data source is this?  It could be from restarting the data point (or source).  Also can you get the exact timestamps of the values?</p>
]]></description><link>https://forum.mango-os.com/post/26167</link><guid isPermaLink="true">https://forum.mango-os.com/post/26167</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 11 Jan 2021 18:41:38 GMT</pubDate></item></channel></rss>
