<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How does Use multiple write commands only option really work?]]></title><description><![CDATA[<p dir="auto">I've read the help page and several forum posts describing things that the "Use multiple write commands only" option has helped fix, but what I am still unsure of, is how it actually works.</p>
<p dir="auto">When we chose that option while troubleshooting why commands being issued to a pump were being overwritten we didn't see any differences in the results.  That may be because it just wasn't the fix, or we are trying to send the commands in a way that is incompatible with the multiple write option.</p>
<p dir="auto">For our setup we have a scripting data source that uses multiple .set commands in a row to turn a modbus water pump on and set several addresses as we need.  Will checking the multiple commands box spool up a certain number of commands, or wait a few milliseconds for the various set commands to be issued and spit out the consecutive registers as one command to the pump?</p>
<p dir="auto">Or, would we have to change the way we set the register values in our scripting data source to better suit the multiple write commands option?</p>
<p dir="auto">Thanks,<br />
Chad</p>
]]></description><link>https://forum.mango-os.com/topic/5036/how-does-use-multiple-write-commands-only-option-really-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 20:16:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5036.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Dec 2020 13:31:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How does Use multiple write commands only option really work? on Mon, 21 Dec 2020 19:25:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmusselm" aria-label="Profile: cmusselm">@<bdi>cmusselm</bdi></a> that setting may help depending on what you are doing.  That setting will effectively send a short value to a register if it is 2 bytes according to the point locator's modbus data type.  If it is &gt; 2 bytes then no matter what it will send an array to the slave and likely will write &gt; 1 register.</p>
]]></description><link>https://forum.mango-os.com/post/26125</link><guid isPermaLink="true">https://forum.mango-os.com/post/26125</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 21 Dec 2020 19:25:52 GMT</pubDate></item></channel></rss>
