<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoGT running out of memory?]]></title><description><![CDATA[<p dir="auto">Catching a few MangoGT units hanging, to find Out Of Memory errors in the logs:</p>
<pre><code>Dec 06 01:00:43 mangoGT5176 start-mango.sh[529]: Exception in thread "high-pool-2-thread-5894" com.infiniteautomation.tsdb.IasTsdbException: java.io.IOException: Map failed
Dec 06 01:00:43 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.IasTsdbImpl.count(IasTsdbImpl.java:1124)
Dec 06 01:00:43 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.nosql.InternalGenericDao.rangeCount(InternalGenericDao.java:393)
[snipped]
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.m2m2.persistent.pub.SyncHandler$PointSync.checkRangeImpl(SyncHandler.java:514)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.m2m2.persistent.pub.SyncHandler$PointSync.checkRange(SyncHandler.java:345)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.m2m2.persistent.pub.SyncHandler$PointSync.checkPoint(SyncHandler.java:326)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.m2m2.persistent.pub.SyncHandler$PointSync.run(SyncHandler.java:276)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.timer.sync.Synchronizer$TaskWrapper.run(Synchronizer.java:150)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.timer.Task.runTask(Task.java:179)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/java.lang.Thread.run(Thread.java:830)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]: Caused by: java.io.IOException: Map failed
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/sun.nio.ch.FileChannelImpl.map(FileChannelImpl.java:1017)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.ChecksumMappedByteBufferInputStream.&lt;init&gt;(ChecksumMappedByteBufferInputStream.java:41)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.ReversibleShard.openDataIn(ReversibleShard.java:250)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.Shard.query(Shard.java:473)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.CompressibleShard.query(CompressibleShard.java:391)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.Series.query(Series.java:532)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at com.infiniteautomation.tsdb.impl.IasTsdbImpl.count(IasTsdbImpl.java:1095)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         ... 48 more
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]: Caused by: java.lang.OutOfMemoryError: Map failed
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/sun.nio.ch.FileChannelImpl.map0(Native Method)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         at java.base/sun.nio.ch.FileChannelImpl.map(FileChannelImpl.java:1014)
Dec 06 01:02:22 mangoGT5176 start-mango.sh[529]:         ... 54 more
<p dir="auto">Suggestions? Adjust thread pools? Swap?</p>
]]></description><link>https://forum.mango-os.com/topic/5016/mangogt-running-out-of-memory</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 04:45:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/5016.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Dec 2020 03:24:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MangoGT running out of memory? on Fri, 19 Feb 2021 21:32:13 GMT]]></title><description><![CDATA[<p dir="auto">Either get more memory or try this env property:</p>
<pre><code>#Set the number of files the database can have open at one time
db.nosql.maxOpenFiles=500
<p dir="auto">It will close/unmap files at the expense of cpu use.  If this problem persists then try another stream type:</p>
<pre><code>#Query Performance Tuning, File Access Type:Available[INPUT_STREAM,FILE_CHANNEL,RANDOM_ACCESS_FILE,MAPPED_BYTE_BUFFER]
db.nosql.shardStreamType=MAPPED_BYTE_BUFFER
]]></description><link>https://forum.mango-os.com/post/26332</link><guid isPermaLink="true">https://forum.mango-os.com/post/26332</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 19 Feb 2021 21:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to MangoGT running out of memory? on Wed, 17 Feb 2021 21:28:31 GMT]]></title><description><![CDATA[<p dir="auto">Was this ever fixed?</p>
]]></description><link>https://forum.mango-os.com/post/26324</link><guid isPermaLink="true">https://forum.mango-os.com/post/26324</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 17 Feb 2021 21:28:31 GMT</pubDate></item></channel></rss>
