<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SQL DB data source connection issues]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have some trouble with the SQL data source due the DB connection:</p>
<p dir="auto">For example, if a configure first the SQL data source and the DB is not up, when I import a DB json configuration or I save the data source manually it takes so much time ( &gt; 100 sec) . I try with MSSQL database type.<br />
My question : I want to know if there is an issue of all DB connection or only MSSQL?</p>
<p dir="auto">An other issue:  if you restart mango and you dont have connection with the data base each data source took so much time to start , 100 to 300 seconds per data source in the initi proccess. Is this normal?</p>
<p dir="auto">I don´t know if I´m doing something bad or threre is a way to avoid this behaivour.</p>
<p dir="auto">Some help or advice are welcome.<br />
Thanks!</p>
]]></description><link>https://forum.mango-os.com/topic/4983/sql-db-data-source-connection-issues</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 18:48:36 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4983.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Oct 2020 18:14:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SQL DB data source connection issues on Thu, 29 Oct 2020 08:37:52 GMT]]></title><description><![CDATA[<p dir="auto">OK, I generate an easy generic topic for the problem....</p>
]]></description><link>https://forum.mango-os.com/post/25956</link><guid isPermaLink="true">https://forum.mango-os.com/post/25956</guid><dc:creator><![CDATA[jmatesanz]]></dc:creator><pubDate>Thu, 29 Oct 2020 08:37:52 GMT</pubDate></item><item><title><![CDATA[Reply to SQL DB data source connection issues on Wed, 28 Oct 2020 22:32:53 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://forum.mango-os.com/topic/4973/msmssql-connection-exception-not-allowed-to-disable-data-sources-and-import-json-configuration">https://forum.mango-os.com/topic/4973/msmssql-connection-exception-not-allowed-to-disable-data-sources-and-import-json-configuration</a></p>
<p dir="auto">Please don't double up on posts.</p>
]]></description><link>https://forum.mango-os.com/post/25951</link><guid isPermaLink="true">https://forum.mango-os.com/post/25951</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Wed, 28 Oct 2020 22:32:53 GMT</pubDate></item></channel></rss>
