<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UpgradeCheck Invalid response code 302 causing Mango to die at startup]]></title><description><![CDATA[<p dir="auto">Mango is suddenly crashing at startup, with the following log message:</p>
<pre><code>ERROR 2020-09-30T14:06:03,185 (com.serotonin.m2m2.rt.maint.UpgradeCheck.run:65) - Invalid response code 302, reason=Found:
org.apache.http.HttpException: Invalid response code 302, reason=Found:
        at com.serotonin.web.http.HttpUtils4.getTextContent(HttpUtils4.java:136) ~[mango-3.6.6.jar:?]
        at com.serotonin.m2m2.web.dwr.ModulesDwr.getAvailableUpgrades(ModulesDwr.java:420) ~[mango-3.6.6.jar:?]
        at com.serotonin.m2m2.web.dwr.ModulesDwr.upgradesAvailable(ModulesDwr.java:298) ~[mango-3.6.6.jar:?]
        at com.serotonin.m2m2.rt.maint.UpgradeCheck.run(UpgradeCheck.java:53) ~[mango-3.6.6.jar:?]
        at com.serotonin.timer.Task.runTask(Task.java:179) ~[mango-3.6.6.jar:?]
        at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23) ~[mango-3.6.6.jar:?]
        at com.serotonin.timer.OrderedThreadPoolExecutor$OrderedTaskCollection.run(OrderedThreadPoolExecutor.java:336) ~[mango-3.6.6.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) ~[?:1.8.0_131]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) ~[?:1.8.0_131]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
<p dir="auto">This is running version 3.6.6 and was running fine on Monday. Is it that unhappy about a 302?</p>
<p dir="auto">Thanks in advance,</p>
<p dir="auto">Aldo</p>
]]></description><link>https://forum.mango-os.com/topic/4956/upgradecheck-invalid-response-code-302-causing-mango-to-die-at-startup</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 06:19:16 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4956.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Sep 2020 22:16:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UpgradeCheck Invalid response code 302 causing Mango to die at startup on Thu, 01 Oct 2020 06:42:46 GMT]]></title><description><![CDATA[<p dir="auto">I purged the <code>work</code> directory, and the 302 error went away. Turns out the fact that it was the last message didn't connect it to the cause of the crash.</p>
<p dir="auto">I have sent the database and log files separately. Hopefully we can learn what's going on.</p>
]]></description><link>https://forum.mango-os.com/post/25843</link><guid isPermaLink="true">https://forum.mango-os.com/post/25843</guid><dc:creator><![CDATA[AldoRamos]]></dc:creator><pubDate>Thu, 01 Oct 2020 06:42:46 GMT</pubDate></item></channel></rss>
