<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About Delay quest?]]></title><description><![CDATA[<p dir="auto">I have a metal datapoint script like this</p>
<pre><code>var triggerSMSAction = false;
var thisText = "";
var NL = "\r\n";
var S = my.value;
print('my.value= '+my.value);
//print(my);
var resendMsgTimeDelay = 300;
var Ptr = -1;
var txt = "";
var theSecondsDelyforSignalVerification = 30;
//--mango timestamp value in milliseconds since the epoch
var now = new Date().getTime();
//print("now=",now);
var o1lastValue,o1_isLeak,o1;
o1 = getDataPointByXID("XID_MainDC_Leak_A");
// print(o1);
o1lastValue = o1.lastValue();
print ("o1lastValue =",o1lastValue);
o1_isLeak = o1lastValue.value;
print("o1_isLeak =",o1_isLeak);
if (o1_isLeak === true) {
    print ("now =",now);
    print ("o1LastValueTime =",o1lastValue.time);
	timeDiff = (now - o1lastValue.time)/1000;
	print("timeDiff =",timeDiff);
	if (timeDiff &lt;= theSecondsDelyforSignalVerification) {o1_isLeak=false;}
Ptr = Ptr + 1;
if (o1_isLeak === true){
         print("o1_isLeak=",o1_isLeak);
         print ("Debug it !!");
         if (!(S &amp; Mask[Ptr])) { // 0101 &amp; 0100 =&gt; 0100 =&gt; true
            // do stuff
            txt = 'Delay-Alarm';
            LOG.info(txt);
			S = S | Mask[Ptr] ;
			triggerSMSAction = true;
			thisText = thisText + txt + NL;
 }else{
        if (S &amp; Mask[Ptr]) { // 0101 &amp; 0100 =&gt; 0100 =&gt; true
            // from true to false
            txt = 'Delay-reCover';
            LOG.info(txt);
			S = S ^ Mask[Ptr] ;
function getDataPointByXID(xid) {
  var dataPoints = DataPointQuery.query("eq(xid,"+xid+")");
  if( dataPoints.length !== 1 )
  throw LOG.info("Data point with xid '" + xid + "' not found.");
  return dataPoints[0].runtime;
<p dir="auto">I turn the datapoint "XID_MainDC_Leak_A" value to true but in the if (o1_isLeak === true) script will not work?<br />
How do I do fix it?</p>
]]></description><link>https://forum.mango-os.com/topic/4927/about-delay-quest</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 02:36:40 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4927.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Sep 2020 09:57:43 GMT</pubDate><ttl>60</ttl></channel></rss>
