<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Edit datapoints value simultaneously]]></title><description><![CDATA[<p dir="auto">Hello, I would like to change 4 data points at the same time but I can't find a way to do it.</p>
<p dir="auto">Is there any possible way to change the value of these datapoints at once?</p>
<p dir="auto">Thanks!!</p>
]]></description><link>https://forum.mango-os.com/topic/4926/edit-datapoints-value-simultaneously</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 04:59:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4926.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Sep 2020 15:25:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Edit datapoints value simultaneously on Tue, 08 Sep 2020 17:50:19 GMT]]></title><description><![CDATA[<p dir="auto">The ways I showed you there is using mangoUI within the web interface. This can be implemented from the dashboard designer.<br />
Assuming you are using a version 3 mango system.</p>
<p dir="auto">Look at the API exanples which have to be turned on via the menu settings to see what I mean.<br />
If you are still without a paddle give me the overall picture of what you want to achieve and I can take you through it.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/25737</link><guid isPermaLink="true">https://forum.mango-os.com/post/25737</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Tue, 08 Sep 2020 17:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to Edit datapoints value simultaneously on Tue, 08 Sep 2020 06:50:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: mattfox">@<bdi>mattfox</bdi></a><br />
Thanks for your answer, I am using the web application only, no code. Is there a way to do it without touching code?</p>
]]></description><link>https://forum.mango-os.com/post/25736</link><guid isPermaLink="true">https://forum.mango-os.com/post/25736</guid><dc:creator><![CDATA[aosc98]]></dc:creator><pubDate>Tue, 08 Sep 2020 06:50:39 GMT</pubDate></item><item><title><![CDATA[Reply to Edit datapoints value simultaneously on Mon, 07 Sep 2020 19:33:47 GMT]]></title><description><![CDATA[<p dir="auto">Assuming you are clicking on a button or something...</p>
<pre><code>&lt;ma-button label="Set Four points" ng-click="pt1.setValue(value);pt2.setValue(value);pt3.setValue(value);pt4.setValue(value);"&gt;
&lt;/ma-button&gt;
<p dir="auto">You can set a value with the timestamp as well if necessary:</p>
<pre><code>pt1.setValue({"value":value,"timestamp":timestamp,"annotation":anno});
]]></description><link>https://forum.mango-os.com/post/25734</link><guid isPermaLink="true">https://forum.mango-os.com/post/25734</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 07 Sep 2020 19:33:47 GMT</pubDate></item></channel></rss>
