<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Add a Lightning Detector device to support BACnet. Loaded BACnet4J but need some specs or examples to add IP device with 4 Binary and 2 Calendar and maybe an Alert&#x2F;Alarm.]]></title><description><![CDATA[<p dir="auto">Hi Folks, I successfully downloaded and built the latest BACnet4J code. Our <a href="http://www.mobipax.com" rel="nofollow ugc">www.mobipax.com</a> Lightning Detector uses MQTT (Lightning Detector control App available on Google Play), but I can easily add a BACnet to MQTT interface (when I get past the initial practical code usage).  I cannot find a "How to use" Doc for BACnet4J, and the code examples I find do not match the code downloaded code ver 6.0.0-SNAPSHOT.  For example: One user discusses "List&lt;InterfaceAddress&gt; usable = BacnetIpUtils.listUsableBACnetInterfaces(); " but the method does not exist. Another this "LocalDevice localDevice = new LocalDevice(1, "10.193.224.255", "10.193.224.239");" but that is not an available Construtor.</p>
<p dir="auto">Bottom line: Rather that flailing around trying different things, is there a written guide for BAACnet4J  for adding a Device, or Sample code to add a device that uses available methods and classes in BACnet4J?</p>
<p dir="auto">BTW: I envision these 6' Lightning Detectors in  parking lots and in environments already controlled by BACnet.</p>
]]></description><link>https://forum.mango-os.com/topic/4864/add-a-lightning-detector-device-to-support-bacnet-loaded-bacnet4j-but-need-some-specs-or-examples-to-add-ip-device-with-4-binary-and-2-calendar-and-maybe-an-alert-alarm</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 04:29:41 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4864.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jul 2020 21:36:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Add a Lightning Detector device to support BACnet. Loaded BACnet4J but need some specs or examples to add IP device with 4 Binary and 2 Calendar and maybe an Alert&#x2F;Alarm. on Wed, 15 Jul 2020 03:16:03 GMT]]></title><description><![CDATA[<p dir="auto">Hmm Crickets.  I moved on to the Bacnet Stack (C lang) because they have documentation and examples. Got my first WhoIS/Iam working with the BDT, defined the Device Object etc. Sorry BACnet4j didn't work out for me.</p>
]]></description><link>https://forum.mango-os.com/post/25454</link><guid isPermaLink="true">https://forum.mango-os.com/post/25454</guid><dc:creator><![CDATA[kennelly]]></dc:creator><pubDate>Wed, 15 Jul 2020 03:16:03 GMT</pubDate></item></channel></rss>
