<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Its possible load a jsp file from meta data source script?]]></title><description><![CDATA[<p dir="auto">Hello for all.</p>
<p dir="auto">I'm reading into ScadaBR some SNMP tags and I need create a Alert System using email and or Telegram. My doubt is about if possible from datapoint script of the meta data source make something neat like:</p>
<ul>
<li>Run's a JSP file.</li>
<li>Send a email</li>
<li>Raise an Alert</li>
</ul>
<p dir="auto">this are my script for now...</p>
<pre><code>CS_3B - BatteryLow          p513
CS_3B - BatteryTestFail     p514
CS_3B - FanFail             p515
CS_3B - FuseFailure         p516
CS_3B - InverterAbnormal    p517
CS_3B - LoadOnBypass        p518
CS_3B - OutputOff           p519
CS_3B - OutputOverload      p520
CS_3B - OverTemperature     p521
CS_3B - PowerFail           p522
CS_3B - TestInProgress      p523
CS_3B - UPSFault            p524
<p dir="auto">This are the Script</p>
<pre><code>var alarme = 0;
var msg-email="Nobreak CS_3D Informa:";
var msg-teleg="Nobreak CS_3D Informa:";
if(p513.value &gt; alarme ){
   msg-teleg.concat("\nBateria Baixa");
   msg-email.concat("\nBateria Baixa");
else if(p515.value &gt; alarme ){
   msg-email.concat("\nFalha Ventiladores");
else if(p514.value &gt; alarme ){
   msg-email.concat("\nFalha teste Baterias");
else if(p516.value &gt; alarme ){
   msg-email.concat("\nFusíveis Aberto");
else if(p517.value &gt; alarme ){
   msg-email.concat("\nFalha Inversor");
else if(p518.value &gt; alarme ){
   msg-email.concat("\nNobreak em Bypass");
else if(p519.value &gt; alarme ){
   msg-email.concat("\nSaida Desligada");
else if(p520.value &gt; alarme ){
   msg-email.concat("\nSobrecarga na Saida");
else if(p521.value &gt; alarme ){
   msg-email.concat("\nSuperaquecimento");
else if(p522.value &gt; alarme ){
   msg-email.concat("\nAusência de Rede");
else if(p523.value &gt; alarme ){
   msg-email.concat("\nTeste em progresso");
   msg-teleg.concat("\nTeste em Progresso");
else if(p524.value &gt; alarme ){
   msg-email.concat("\nNobreak em Falha");
else { msg-email.concat("\nSistema Normal");
       msg-teleg.concat("\nSistema Normal");
if msg-teleg.len()&gt;44 {
// get sendtelegram.jsp?group=100&amp;msg=$(msg-teleg)
if msg-email.len() &gt;44 {
// sendmail(msg=$(msg-email)
return msg-email;
]]></description><link>https://forum.mango-os.com/topic/4851/its-possible-load-a-jsp-file-from-meta-data-source-script</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 18:33:54 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4851.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2020 16:55:05 GMT</pubDate><ttl>60</ttl></channel></rss>
