<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newbie with scripting data source]]></title><description><![CDATA[<p dir="auto">Hello,<br />
So i want to try using scripting data source. I try to make a tank level system, which fill itself 1 by 1, with a max value of 20, then go back to 0 all of this by pressing a button. If the button is disable, then the tank level value is 0. If I'm able to do that, next I want to be able to control the tank level max value using a slider. If someone has any idea how i should proceed it's awesome, for now here is my code and data points settings :<br />
<a href="https://imgur.com/a/ljOhdyA" rel="nofollow ugc">https://imgur.com/a/ljOhdyA</a><br />
Thanks to anyone that would help me !</p>
]]></description><link>https://forum.mango-os.com/topic/4826/newbie-with-scripting-data-source</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 05:58:05 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4826.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jun 2020 17:14:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newbie with scripting data source on Sat, 06 Jun 2020 11:12:35 GMT]]></title><description><![CDATA[<p dir="auto">For a start, your for loop needs to have<br />
<code>var i=0; i&lt;=421.value; i++</code><br />
Secondly, to set a value as can be read under "Mango JavaScript" you use the set function:</p>
<pre><code>if ( p420.value == true )
  for (var i=0; i&lt;=421.value; i++)
//1st case
    p422.set( p422.value + 1); //current value + 1*value of slider + 1
else //else if not needed since you're either true or not true (==false)
  p422.set( 0 ); //Set to 0
<p dir="auto">Try rereading the docs provided by Joel to get a better grasp of what I have written and how it relates to the documentation provided.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/25266</link><guid isPermaLink="true">https://forum.mango-os.com/post/25266</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sat, 06 Jun 2020 11:12:35 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie with scripting data source on Fri, 05 Jun 2020 16:42:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: joelhaggar">@<bdi>joelhaggar</bdi></a> Well.. no that's the problem :/ I might have missed a step or something. I mean, i added my binary button, the tank level and the slider (which from 0 to 20) and link all together using Data Points' XIDs but... nothing is happening, so yeah i'm kinda lost. But thanks a lot</p>
]]></description><link>https://forum.mango-os.com/post/25264</link><guid isPermaLink="true">https://forum.mango-os.com/post/25264</guid><dc:creator><![CDATA[ClaireP]]></dc:creator><pubDate>Fri, 05 Jun 2020 16:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie with scripting data source on Fri, 05 Jun 2020 15:37:02 GMT]]></title><description><![CDATA[<p dir="auto">I think it makes sense but I'm not much of a coder myself.  Does it work?</p>
]]></description><link>https://forum.mango-os.com/post/25263</link><guid isPermaLink="true">https://forum.mango-os.com/post/25263</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 05 Jun 2020 15:37:02 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie with scripting data source on Fri, 05 Jun 2020 09:11:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: joelhaggar">@<bdi>joelhaggar</bdi></a> Thanks a lot, i edit my first post because image where not displaying properly. So i looked at your link but i'm very new to all of this so i'm kinda lost. Do you have any idea if what i've done so far make sens or not ?</p>
]]></description><link>https://forum.mango-os.com/post/25261</link><guid isPermaLink="true">https://forum.mango-os.com/post/25261</guid><dc:creator><![CDATA[ClaireP]]></dc:creator><pubDate>Fri, 05 Jun 2020 09:11:05 GMT</pubDate></item><item><title><![CDATA[Reply to Newbie with scripting data source on Thu, 04 Jun 2020 18:03:56 GMT]]></title><description><![CDATA[<p dir="auto">This should be pretty easy.  You can create Data Points on the Scripting Data Source for the Disable button and the max level setting and use those in your script.  I would start by reading these links to start with and then ask any specific questions if you run into trouble</p>
<p dir="auto"><a href="https://help.infiniteautomation.com/scripting-data-source" rel="nofollow ugc">https://help.infiniteautomation.com/scripting-data-source</a></p>
<p dir="auto"><a href="https://help.infiniteautomation.com/about-mango-java-script" rel="nofollow ugc">https://help.infiniteautomation.com/about-mango-java-script</a></p>
<p dir="auto"><a href="https://help.infiniteautomation.com/script-examples" rel="nofollow ugc">https://help.infiniteautomation.com/script-examples</a></p>
]]></description><link>https://forum.mango-os.com/post/25257</link><guid isPermaLink="true">https://forum.mango-os.com/post/25257</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 04 Jun 2020 18:03:56 GMT</pubDate></item></channel></rss>
