<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Virtual Datapoints being turned off by mango]]></title><description><![CDATA[<p dir="auto">I've got datapoints in a virtual datasource. They're used for forwarding control commands to a remote mango unit. I also update tags when i do this. Because of that I've got a $interval which checks the datapoint details every ten seconds.</p>
<p dir="auto">However the problem I'm having is mango is disabling these points. I need them to work, and yet cannot set them because mango keeps disabling them.<br />
Any thoughts as to what can be causing this?</p>
<p dir="auto">I know I'm using 3.5.6 but I am not in a position to upgrade at this time.</p>
<p dir="auto">Fox</p>
<p dir="auto">EDIT: I did check the logs and I found an old publisher not going to anywhere (the unit died) using the same points. Data was regularly getting discarded. Could that be the reason??</p>
<p dir="auto">EDIT 2: Nope, points still got disabled... customer's getting frazzled, i'm equally confused...</p>
]]></description><link>https://forum.mango-os.com/topic/4682/virtual-datapoints-being-turned-off-by-mango</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 06:51:27 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4682.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jan 2020 03:44:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Virtual Datapoints being turned off by mango on Fri, 31 Jan 2020 16:49:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: craigweb">@<bdi>craigweb</bdi></a> said in <a href="/post/24564">Virtual Datapoints being turned off by mango</a>:</p>
<p dir="auto">When you say updating the tags, do you mean changing them and then saving the changes? A point will get temporally disabled when it is saved</p>
<p dir="auto">Yes but that doesn't explain why they stay off. Yes when a button is pressed, I update tags and use the $update() command. After some time I end up having to go back into the system to re-enable the points.</p>
]]></description><link>https://forum.mango-os.com/post/24567</link><guid isPermaLink="true">https://forum.mango-os.com/post/24567</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Fri, 31 Jan 2020 16:49:31 GMT</pubDate></item><item><title><![CDATA[Reply to Virtual Datapoints being turned off by mango on Fri, 31 Jan 2020 13:44:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattfox" aria-label="Profile: mattfox">@<bdi>mattfox</bdi></a> said in <a href="/post/24562">Virtual Datapoints being turned off by mango</a>:</p>
<p dir="auto">roblem I'm having is mango is disabling these point</p>
<p dir="auto">When you say updating the tags, do you mean changing them and then saving the changes? A point will get temporally disabled when it is saved.</p>
]]></description><link>https://forum.mango-os.com/post/24564</link><guid isPermaLink="true">https://forum.mango-os.com/post/24564</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Fri, 31 Jan 2020 13:44:16 GMT</pubDate></item></channel></rss>
