<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango server error]]></title><description><![CDATA[<p dir="auto">My mango es has stopped twice this week with the same error. Can someone look at it for me?<br />
ORU zigbee central<br />
Thanks<br />
<img src="https://camo.nodebb.org/d0cfb6cdda42d50a0cc75e4ac97632d4b7e1eef1?url=https%3A%2F%2Fi.imgur.com%2FBEB1dyu.png" alt="0_1576604011475_4986cdf1-77b9-4efc-84bc-498619a9fefb-image.png" class=" img-fluid img-markdown" /> )</p>
]]></description><link>https://forum.mango-os.com/topic/4641/mango-server-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 04:25:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4641.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Dec 2019 17:19:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango server error on Wed, 18 Dec 2019 22:04:11 GMT]]></title><description><![CDATA[<p dir="auto">That is great news. I really appreciate you doing that. Thanks</p>
]]></description><link>https://forum.mango-os.com/post/24372</link><guid isPermaLink="true">https://forum.mango-os.com/post/24372</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Wed, 18 Dec 2019 22:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Wed, 18 Dec 2019 19:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oru_david" aria-label="Profile: ORU_david">@<bdi>ORU_david</bdi></a> ,</p>
<p dir="auto">I just freed up over 1G of space by deleting some very old backups.  It seems the bulk of your disk space is being taken up by Mango's NoSQL data and its incremental backups.  Since you are pushing data out of this system over the Persistent publisher I suggest you change those settings to only keep a few days of data, especially if you are backing up data at the publish destination.  Basically just keep enough data locally to persist across network outages.</p>
<p dir="auto">The current state of affairs:</p>
<pre><code>mango@MangoES:/$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p2  7.1G  5.9G  861M  88% /
<pre><code>mango@MangoES:/opt$ du -sh mango/
3.6G	mango/
mango@MangoES:/opt/mango$ du -sh backup/
698M	backup/
mango@MangoES:/opt/mango$ du -sh databases/
2.4G	databases/
mango@MangoES:/opt/mango/databases$ du -sh mangoTSDB/
2.3G	mangoTSDB/
]]></description><link>https://forum.mango-os.com/post/24370</link><guid isPermaLink="true">https://forum.mango-os.com/post/24370</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Wed, 18 Dec 2019 19:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Wed, 18 Dec 2019 17:46:05 GMT]]></title><description><![CDATA[<p dir="auto">Would someone please connect to it, it has my meters offline again. Thanks</p>
]]></description><link>https://forum.mango-os.com/post/24369</link><guid isPermaLink="true">https://forum.mango-os.com/post/24369</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Wed, 18 Dec 2019 17:46:05 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Wed, 18 Dec 2019 15:09:03 GMT]]></title><description><![CDATA[<p dir="auto">I turned the NoSQL, but having problems with the purge setting. Any changes shows failed.</p>
<p dir="auto"><img src="https://camo.nodebb.org/85c8fa255b153c293cc5ff5d66e1aae95fa7e505?url=https%3A%2F%2Fi.imgur.com%2FNNX0WqH.png" alt="0_1576682706866_b198eae1-f9aa-4435-bf74-9a2396a25d4a-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/24364</link><guid isPermaLink="true">https://forum.mango-os.com/post/24364</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Wed, 18 Dec 2019 15:09:03 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Wed, 18 Dec 2019 13:58:49 GMT]]></title><description><![CDATA[<p dir="auto">Hey David, this article should help you. <a href="https://help.infiniteautomation.com/managing-disk-space" rel="nofollow ugc">https://help.infiniteautomation.com/managing-disk-space</a></p>
<p dir="auto">I would check the settings and turn off the NoSQL backups and set the device to purge data sooner.  All data is synced to your central server so you don't need to keep the data on the device for more than a month.  Purge settings for events are also good to make sure are set to purge after a week is probably fine.</p>
]]></description><link>https://forum.mango-os.com/post/24363</link><guid isPermaLink="true">https://forum.mango-os.com/post/24363</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 18 Dec 2019 13:58:49 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 22:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oru_david" aria-label="Profile: ORU_david">@<bdi>ORU_david</bdi></a> yes your drive is full.  You will need to clear out some disk space and this is very system dependent.  I would start by checking <code>/opt/mango/logs</code> and <code>/opt/mango/backup</code></p>
<p dir="auto">It does not appear that you have much in your databases so this will be due to files accumulating somewhere on the file system outside the database.</p>
]]></description><link>https://forum.mango-os.com/post/24360</link><guid isPermaLink="true">https://forum.mango-os.com/post/24360</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Tue, 17 Dec 2019 22:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 21:45:57 GMT]]></title><description><![CDATA[<p dir="auto">Im not sure what to remove. This es reports to a server, so wouldn't the history be stored there? Joel set it up 4 yrs ago.</p>
<p dir="auto"><img src="https://camo.nodebb.org/a5b35c7b8358403c0d3cc61cc4901a99ee5dd3f0?url=https%3A%2F%2Fi.imgur.com%2FTtPL41c.png" alt="0_1576620057404_a1c7ed66-2d54-41e6-8c00-8c5ede6932c7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/24359</link><guid isPermaLink="true">https://forum.mango-os.com/post/24359</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Tue, 17 Dec 2019 21:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 21:41:52 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/8a1e4f5735a140fa8b3b2d1948b79599fbb769a6?url=https%3A%2F%2Fi.imgur.com%2FWvom2VB.png" alt="0_1576619915052_89c8d7a5-d2a8-4bde-a3b0-a669c4b6e91c-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/24356</link><guid isPermaLink="true">https://forum.mango-os.com/post/24356</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Tue, 17 Dec 2019 21:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 21:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Found it</p>
<p dir="auto">Server error</p>
<pre><code>java.lang.IllegalStateException: No output folder
	at org.apache.jasper.servlet.JspServletWrapper.handleJspException (JspServletWrapper.java:601)
	at org.apache.jasper.servlet.JspServletWrapper.service (JspServletWrapper.java:402)
	at org.apache.jasper.servlet.JspServlet.serviceJspFile (JspServlet.java:386)
	at org.apache.jasper.servlet.JspServlet.service (JspServlet.java:330)
	at org.eclipse.jetty.jsp.JettyJspServlet.service (JettyJspServlet.java:112)
	at javax.servlet.http.HttpServlet.service (HttpServlet.java:790)
	at org.eclipse.jetty.servlet.ServletHolder.handle (ServletHolder.java:865)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle (ServletHandler.java:535)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle (ScopedHandler.java:146)
	at org.eclipse.jetty.security.SecurityHandler.handle (SecurityHandler.java:566)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle (HandlerWrapper.java:132)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle (ScopedHandler.java:257)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle (SessionHandler.java:1595)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle (ScopedHandler.java:255)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle (ContextHandler.java:1340)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope (ScopedHandler.java:203)
	at org.eclipse.jetty.servlet.ServletHandler.doScope (ServletHandler.java:473)
	at org.eclipse.jetty.server.session.SessionHandler.doScope (SessionHandler.java:1564)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope (ScopedHandler.java:201)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope (ContextHandler.java:1242)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle (ScopedHandler.java:144)
	at org.eclipse.jetty.server.Dispatcher.forward (Dispatcher.java:203)
	at org.eclipse.jetty.server.Dispatcher.forward (Dispatcher.java:73)
	at org.springframework.security.web.header.HeaderWriterFilter$HeaderWriterRequestDispatcher.forward (HeaderWriterFilter.java:143)
	at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel (InternalResourceView.java:170)
	at org.springframework.web.servlet.view.AbstractView.render (AbstractView.java:316)
	at org.springframework.web.servlet.DispatcherServlet.render (DispatcherServlet.java:1371)
	at org.springframework.web.servlet.DispatcherServlet.processDispatchResult (DispatcherServlet.java:1117)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch (DispatcherServlet.java:1056)
	at org.springframework.web.servlet.DispatcherServlet.doService (DispatcherServlet.java:942)
	at org.springframework.web.servlet.FrameworkServlet.processRequest (FrameworkServlet.java:1005)
	at org.springframework.web.servlet.FrameworkServlet.doGet (FrameworkServlet.java:897)
	at javax.servlet.http.HttpServlet.service (HttpServlet.java:687)
	at org.springframework.web.servlet.FrameworkServlet.service (FrameworkServlet.java:882)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter (ServletHandler.java:1655)
	at com.serotonin.m2m2.web.filter.WebContextFilter.doFilter (WebContextFilter.java:43)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter (ServletHandler.java:1642)
	at com.serotonin.m2m2.web.filter.UrlSecurityFilter.doFilter (UrlSecurityFilter.java:191)
	at com.serotonin.web.filter.CharacterSetFilter.doFilter (CharacterSetFilter.java:37)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter (ServletHandler.java:1634)
	at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal (ShallowEtagHeaderFilter.java:108)
	at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal (MangoShallowEtagHeaderFilter.java:95)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter (OncePerRequestFilter.java:107)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter (FilterChainProxy.java:320)
	at org.springframework.security.web.authentication.switchuser.SwitchUserFilter.doFilter (SwitchUserFilter.java:200)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter (FilterChainProxy.java:334)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke (FilterSecurityInterceptor.java:127)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter (FilterSecurityInterceptor.java:91)
	at com.serotonin.m2m2.web.mvc.spring.security.RateLimitingFilter.doFilterInternal (RateLimitingFilter.java:56)
	at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter (PermissionExceptionFilter.java:34)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter (ExceptionTranslationFilter.java:119)
	at org.springframework.security.web.session.SessionManagementFilter.doFilter (SessionManagementFilter.java:137)
	at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter (AnonymousAuthenticationFilter.java:111)
	at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter (SecurityContextHolderAwareRequestFilter.java:170)
	at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter (ConcurrentSessionFilter.java:155)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter (AbstractAuthenticationProcessingFilter.java:200)
	at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter (LogoutFilter.java:116)
	at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal (CsrfFilter.java:100)
	at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal (HeaderWriterFilter.java:74)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter (SecurityContextPersistenceFilter.java:105)
	at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal (WebAsyncManagerIntegrationFilter.java:56)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal (FilterChainProxy.java:215)
	at org.springframework.security.web.FilterChainProxy.doFilter (FilterChainProxy.java:178)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate (DelegatingFilterProxy.java:357)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter (DelegatingFilterProxy.java:270)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle (ServletHandler.java:533)
	at org.eclipse.jetty.security.SecurityHandler.handle (SecurityHandler.java:548)
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle (ContextHandlerCollection.java:220)
	at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle (GzipHandler.java:740)
	at org.eclipse.jetty.server.Server.handle (Server.java:503)
	at org.eclipse.jetty.server.HttpChannel.handle (HttpChannel.java:364)
	at org.eclipse.jetty.server.HttpConnection.onFillable (HttpConnection.java:260)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded (AbstractConnection.java:305)
	at org.eclipse.jetty.io.FillInterest.fillable (FillInterest.java:103)
	at org.eclipse.jetty.io.ChannelEndPoint$2.run (ChannelEndPoint.java:118)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask (EatWhatYouKill.java:333)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce (EatWhatYouKill.java:310)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce (EatWhatYouKill.java:168)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run (EatWhatYouKill.java:126)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run (ReservedThreadExecutor.java:366)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob (QueuedThreadPool.java:765)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run (QueuedThreadPool.java:683)
	at java.lang.Thread.run (Thread.java:748)
Caused by: No output folder
	at org.apache.jasper.JspCompilationContext.createOutputDir (JspCompilationContext.java:687)
	at org.apache.jasper.JspCompilationContext.getOutputDir (JspCompilationContext.java:202)
	at org.apache.jasper.JspCompilationContext.getClassFileName (JspCompilationContext.java:535)
	at org.apache.jasper.compiler.Compiler.isOutDated (Compiler.java:459)
	at org.apache.jasper.compiler.Compiler.isOutDated (Compiler.java:425)
	at org.apache.jasper.JspCompilationContext.compile (JspCompilationContext.java:588)
	at org.apache.jasper.servlet.JspServletWrapper.service (JspServletWrapper.java:368)
]]></description><link>https://forum.mango-os.com/post/24355</link><guid isPermaLink="true">https://forum.mango-os.com/post/24355</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Tue, 17 Dec 2019 21:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 21:23:56 GMT]]></title><description><![CDATA[<p dir="auto">a) Click the message in the events table to see the full message, it is being truncated so I cannot see the full message<br />
b) Check the system status page for the available disk space</p>
]]></description><link>https://forum.mango-os.com/post/24352</link><guid isPermaLink="true">https://forum.mango-os.com/post/24352</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 17 Dec 2019 21:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 20:57:22 GMT]]></title><description><![CDATA[<p dir="auto">I don't find the "show stack trace" so I rebooted. I need to see data. Maybe the drive is full? Phillip use to clean it occasionally for me. My skill are limited with this system. Thanks</p>
<p dir="auto"><img src="https://camo.nodebb.org/bbdd80c3ee64a6fd1c713af08f444267b7f3b8dd?url=https%3A%2F%2Fi.imgur.com%2FouTAjp2.png" alt="0_1576617128051_621012aa-89ec-4482-8fe3-7029cd8d6aab-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/24349</link><guid isPermaLink="true">https://forum.mango-os.com/post/24349</guid><dc:creator><![CDATA[ORU_david]]></dc:creator><pubDate>Tue, 17 Dec 2019 20:57:22 GMT</pubDate></item><item><title><![CDATA[Reply to Mango server error on Tue, 17 Dec 2019 17:59:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oru_david" aria-label="Profile: ORU_david">@<bdi>ORU_david</bdi></a> please click "Show stack trace" then post the text content please. What were you doing when the error occurred?</p>
]]></description><link>https://forum.mango-os.com/post/24348</link><guid isPermaLink="true">https://forum.mango-os.com/post/24348</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 17 Dec 2019 17:59:26 GMT</pubDate></item></channel></rss>
