<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Has HTTP JSON Retriever properties changed in 3.7.3? - Solved]]></title><description><![CDATA[<p dir="auto">After upgrade from 3.4 to 3.7.3 HTTP JSON Retriever points started throwing events.</p>
<pre><code>Timestamp was not parsable, value= for point L1 Volt
<p dir="auto">In point properties the Value JSON pointer is of course defined.<br />
The Time JSON pointer is not, simply because the JSON does not have it. This was not an issue before, and events were not thrown in 3.4. In 3.7.3 it does.</p>
<p dir="auto">What is the best way to set properties without a Time pointer?</p>
]]></description><link>https://forum.mango-os.com/topic/4625/has-http-json-retriever-properties-changed-in-3-7-3-solved</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 02:30:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4625.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Dec 2019 06:44:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Has HTTP JSON Retriever properties changed in 3.7.3? - Solved on Wed, 11 Dec 2019 23:33:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. New version solved issue.</p>
]]></description><link>https://forum.mango-os.com/post/24301</link><guid isPermaLink="true">https://forum.mango-os.com/post/24301</guid><dc:creator><![CDATA[Balistar]]></dc:creator><pubDate>Wed, 11 Dec 2019 23:33:54 GMT</pubDate></item><item><title><![CDATA[Reply to Has HTTP JSON Retriever properties changed in 3.7.3? - Solved on Wed, 11 Dec 2019 19:47:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/balistar" aria-label="Profile: Balistar">@<bdi>Balistar</bdi></a> version 3.7.1 of the HTTP module is now available with a fix for your problem.</p>
]]></description><link>https://forum.mango-os.com/post/24300</link><guid isPermaLink="true">https://forum.mango-os.com/post/24300</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:47:55 GMT</pubDate></item><item><title><![CDATA[Reply to Has HTTP JSON Retriever properties changed in 3.7.3? - Solved on Tue, 10 Dec 2019 16:23:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/balistar" aria-label="Profile: Balistar">@<bdi>Balistar</bdi></a> it looks like this is a bug, I'll fix up the code and release a new module as soon as possible.</p>
]]></description><link>https://forum.mango-os.com/post/24287</link><guid isPermaLink="true">https://forum.mango-os.com/post/24287</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Tue, 10 Dec 2019 16:23:51 GMT</pubDate></item></channel></rss>
