<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bulk edit is giving Validation Error]]></title><description><![CDATA[<p dir="auto">I am trying to bulk edit the rendering properties of a point and it is saying an error is the XID is already in use?? So am I doing something incorrect here?</p>
<p dir="auto">No BULK edit feature working is a pain since I the export for csv was removed .</p>
]]></description><link>https://forum.mango-os.com/topic/4620/bulk-edit-is-giving-validation-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 14:05:45 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4620.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Dec 2019 16:30:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bulk edit is giving Validation Error on Tue, 10 Dec 2019 15:45:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phillip-weeks" aria-label="Profile: phillip-weeks">@<bdi>phillip-weeks</bdi></a> said in <a href="/post/24271">Bulk edit is giving Validation Error</a>:</p>
<ul>
<li>There is a bulk edit feature</li>
<li>It does work</li>
</ul>
<p dir="auto">So am I doing something incorrect here?</p>
<p dir="auto">Yes, it sounds like you are. Check the value of the action column is set to the correct value, it should be CREATE, UPDATE or DELETE. For CREATE you can either set the xid column or leave it blank to autocreate an XID. For UPDATE you should set the originalXid column and the xid column (this is so you can change the XID of points). For DELETE you only need to set the originalXid column.</p>
]]></description><link>https://forum.mango-os.com/post/24284</link><guid isPermaLink="true">https://forum.mango-os.com/post/24284</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 10 Dec 2019 15:45:55 GMT</pubDate></item><item><title><![CDATA[Reply to Bulk edit is giving Validation Error on Mon, 09 Dec 2019 23:28:48 GMT]]></title><description><![CDATA[<p dir="auto">What version of Mango and UI module are you using?</p>
]]></description><link>https://forum.mango-os.com/post/24277</link><guid isPermaLink="true">https://forum.mango-os.com/post/24277</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 09 Dec 2019 23:28:48 GMT</pubDate></item></channel></rss>
