<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setting up&#x2F;debugging mqtt data source]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I'v published some data point (from Niagara) through mqtt to broker <a href="http://test.mosquittio.org" rel="nofollow ugc">test.mosquittio.org</a>.<br />
I can see the published that through MQTT explorer mqtt client as in bellow screen-shot.</p>
<p dir="auto"><img src="https://camo.nodebb.org/0c402cd93beaec509fe14f66c613b94e40458723?url=https%3A%2F%2Fi.imgur.com%2F6oDwEMY.png" alt="0_1575290188149_8abff02e-ef3c-4a8e-81db-7c9d198d05e6-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now I am trying to setup a mqtt client data source in Mango to read the points sineWave and zoneTemp.<br />
First of I as set up a data source as bellow<br />
<img src="https://camo.nodebb.org/7085bb51f58ca73a2f385caa88dc6166eb7c7366?url=https%3A%2F%2Fi.imgur.com%2FvJDndAI.png" alt="0_1575290279651_5e7d1d77-c094-48eb-8c9a-0238ddb4d0af-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The broker connection is without encryption and without user authorization so I left those fields blank,</p>
<p dir="auto">After that I added data point sinWave as bellow<br />
<img src="https://camo.nodebb.org/d97ae2066880a611a948851b778198dec71be7b5?url=https%3A%2F%2Fi.imgur.com%2FQVHBw65.png" alt="0_1575290405948_085e9c75-d4f1-4b33-ac6c-918165519c1d-image.png" class=" img-fluid img-markdown" /><br />
<img src="https://camo.nodebb.org/178c8d4ae4cf01c73e9751db86ae91dcd1c1ba13?url=https%3A%2F%2Fi.imgur.com%2FyHi50Hq.png" alt="0_1575293217540_fad6018b-f2e3-42fe-9c6c-a6ae7e042594-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">However I don't get any data.<br />
In the console it says that data-source is opened and closed.<br />
<img src="https://camo.nodebb.org/c5493838cee5e9a6963b0a02280a2cb78ea89774?url=https%3A%2F%2Fi.imgur.com%2FujiVux0.png" alt="0_1575290506837_37a1dcba-5152-40e3-bc37-47a1b43b2c5e-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Could someone pleas help in getting it working and how to debug it. Unlike for SQL data source I don't find any tools in Mango that let you test the connection, or see what goes wrong.</p>
<p dir="auto">Many Thanks<br />
Nathan</p>
]]></description><link>https://forum.mango-os.com/topic/4600/setting-up-debugging-mqtt-data-source</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 12:36:11 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4600.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Dec 2019 12:28:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setting up&#x2F;debugging mqtt data source on Mon, 02 Dec 2019 14:28:16 GMT]]></title><description><![CDATA[<p dir="auto">Found how to set it up, The issue was Tag filter that should be "reception/#" i.w. the # was missing,</p>
]]></description><link>https://forum.mango-os.com/post/24186</link><guid isPermaLink="true">https://forum.mango-os.com/post/24186</guid><dc:creator><![CDATA[nathanRona]]></dc:creator><pubDate>Mon, 02 Dec 2019 14:28:16 GMT</pubDate></item></channel></rss>
