<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango Src]]></title><description><![CDATA[<p dir="auto">What version of Eclipse do you use to compile the src?<br />
I have tried Eclipse  3.6.0 Classic and the latest version.<br />
Also tried NetBeans but no luck. There are many errors generated that I have tried to work through but I can't seem to make any progress. A list of Jar libraries and versions would be a great help too if you have one because some of the current jar library downloads seems to have depreciated some function calls.</p>
<p dir="auto">My goal is to try to get something working with BlackBerry web access as the current version 1.9 does not display data on the browser.</p>
<p dir="auto">thanks,<br />
OldSmokey</p>
]]></description><link>https://forum.mango-os.com/topic/449/mango-src</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 19:18:41 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/449.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Jul 2010 14:06:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango Src on Tue, 20 Jul 2010 19:18:56 GMT]]></title><description><![CDATA[<p dir="auto">Welll not long after I had placed the post I had discovered that I was missing the env.properties file under classes. So I copied it over from the working web installation and things began to happen as expected. That was a couple of weeks lost trying to figure it out and it is my fault that I did not ask the question earlier. I did learn that checking the "choose the createconfigfiles target" checkbox also fixed the problem so many thanks for your reply. Life is good now.  :D</p>
]]></description><link>https://forum.mango-os.com/post/3998</link><guid isPermaLink="true">https://forum.mango-os.com/post/3998</guid><dc:creator><![CDATA[OldSmokey]]></dc:creator><pubDate>Tue, 20 Jul 2010 19:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Src on Tue, 20 Jul 2010 18:43:39 GMT]]></title><description><![CDATA[<p dir="auto">You can follow the steps below for building Mango:</p>
<p dir="auto">(Thanks to Andras)</p>
<p dir="auto">-get Eclipse IDE for Java EE Developers (I'm using "Eclipse Helios release")<br />
-get Mango source code, unpack it (into your "workspace")<br />
-add empty subdirectories lib, src_gen and src_test to Mango source folder<br />
-in file build.properties, edit tomcat.home to point at the tomcat location on your system. For windows, make sure forward slashes "/" are used in the tomcat.home path<br />
-In Eclipse choose import --&gt; Existing projects into workspace --&gt; browse to the mango source folder<br />
-Remove the last WDSL related part of the build.xml as well. It's not needed for the "deploy" build target.<br />
-right-click build.xml in the project explorer and choose run as-&gt;2.ant-build... -&gt; choose the createconfigfiles target and run.<br />
-right-click build.xml again and choose run as-&gt;2.ant-build...<br />
choose the default deploy and run.</p>
<p dir="auto">That's it, your brand new Mango will be placed into tomcat_dir&gt;/webapps/test</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.mango-os.com/post/3997</link><guid isPermaLink="true">https://forum.mango-os.com/post/3997</guid><dc:creator><![CDATA[ftomiBR]]></dc:creator><pubDate>Tue, 20 Jul 2010 18:43:39 GMT</pubDate></item></channel></rss>
