<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modbus Coil Status]]></title><description><![CDATA[<p dir="auto">I am not getting the correct values...<br />
I had to check the Contiguous batches only and the analogs started working properly.<br />
The controller I'm talking to is a Siemens 353, in the opc server on other systems I have to set the max coil read to 32, or a low number, I can't find it in the newer manual I have...<br />
I have everything working in a KEPserver, and the only thing I have not gotten working in mango is the coils...<br />
any suggestions would be greatly appreciated.</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Jim</p>
]]></description><link>https://forum.mango-os.com/topic/440/modbus-coil-status</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 04:09:42 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/440.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Jul 2010 18:11:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modbus Coil Status on Wed, 21 Jul 2010 17:48:01 GMT]]></title><description><![CDATA[<p dir="auto">not yet, I was on my laptop with verizon wireless connection at a meeting the other night.<br />
A couple of them took about 5 to 10 seconds to update when switching between them.<br />
although we are also running a virtual box with the old wonderware polling the same points on the same computer...<br />
I'll know better next week.<br />
I'm on vacation right now...</p>
]]></description><link>https://forum.mango-os.com/post/4015</link><guid isPermaLink="true">https://forum.mango-os.com/post/4015</guid><dc:creator><![CDATA[jmo]]></dc:creator><pubDate>Wed, 21 Jul 2010 17:48:01 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Wed, 21 Jul 2010 17:11:02 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, that shouldn't be much load if the Mango host is a decent box. Can you quantify the watch list slowdown?</p>
]]></description><link>https://forum.mango-os.com/post/4014</link><guid isPermaLink="true">https://forum.mango-os.com/post/4014</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 21 Jul 2010 17:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Wed, 21 Jul 2010 16:35:38 GMT]]></title><description><![CDATA[<p dir="auto">6 controllers with about 20 tags each.<br />
2 local and 4 radio.<br />
will be adding about 4 more on the radios, and about 20 more tags to each.<br />
now polling every 30 sec, will probably change the radio sites to 1 min...</p>
]]></description><link>https://forum.mango-os.com/post/4010</link><guid isPermaLink="true">https://forum.mango-os.com/post/4010</guid><dc:creator><![CDATA[jmo]]></dc:creator><pubDate>Wed, 21 Jul 2010 16:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Wed, 21 Jul 2010 15:38:06 GMT]]></title><description><![CDATA[<p dir="auto">How many points are you updating, and how often?</p>
]]></description><link>https://forum.mango-os.com/post/4005</link><guid isPermaLink="true">https://forum.mango-os.com/post/4005</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 21 Jul 2010 15:38:06 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Tue, 20 Jul 2010 14:46:12 GMT]]></title><description><![CDATA[<p dir="auto">no, no problems at all.<br />
as we added more sites and more tags, the watch list update is a little slower sometimes, but that is to be expected.</p>
]]></description><link>https://forum.mango-os.com/post/3995</link><guid isPermaLink="true">https://forum.mango-os.com/post/3995</guid><dc:creator><![CDATA[jmo]]></dc:creator><pubDate>Tue, 20 Jul 2010 14:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Tue, 20 Jul 2010 14:05:01 GMT]]></title><description><![CDATA[<p dir="auto">I've seen those errors too. I don't know how to get rid of them, but i also don't recall that they actually caused any problems. Are you seeing otherwise?</p>
]]></description><link>https://forum.mango-os.com/post/3993</link><guid isPermaLink="true">https://forum.mango-os.com/post/3993</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 20 Jul 2010 14:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Tue, 20 Jul 2010 14:01:11 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the quick reply!<br />
That was it...<br />
I had added all our analog tags first, and they all worked fine, so I didn't think about it..<br />
I do have another small issue though,<br />
Getting a lot of these...<br />
Exception from modbus master: Unrecognized Windows Sockets error: -1: socket available<br />
Now, I am running this on their server 2008 64 out there, I can run this on anything I want...<br />
Thanks,</p>
]]></description><link>https://forum.mango-os.com/post/3992</link><guid isPermaLink="true">https://forum.mango-os.com/post/3992</guid><dc:creator><![CDATA[jmo]]></dc:creator><pubDate>Tue, 20 Jul 2010 14:01:11 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus Coil Status on Mon, 19 Jul 2010 14:42:15 GMT]]></title><description><![CDATA[<p dir="auto">I'll need a bit more technical info. Can you provide message traces and such? Also, you know that Mango's Modbus is 0-based?</p>
]]></description><link>https://forum.mango-os.com/post/3974</link><guid isPermaLink="true">https://forum.mango-os.com/post/3974</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 19 Jul 2010 14:42:15 GMT</pubDate></item></channel></rss>
