<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[heartbeat  in mango, to send it every five seconds to each controller]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I want to create heartbeat  in mango, to send it every five seconds to each controller. (TCP / IP Modbus)</p>
<p dir="auto">Thus, in case of loss of this bit of life, the automaton can go into fallback mode.</p>
<p dir="auto">I think that must be achievable.</p>
<p dir="auto">The simplest way to create this bit of life seems to me to be to create a schedule event with a cron pattern.</p>
<p dir="auto">But I found nowhere, indication on this cron pattern.<br />
The links to a tutorial are no longer active.</p>
<p dir="auto">Best regards</p>
]]></description><link>https://forum.mango-os.com/topic/4392/heartbeat-in-mango-to-send-it-every-five-seconds-to-each-controller</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 05:42:50 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4392.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Aug 2019 14:39:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Fri, 16 Aug 2019 16:32:58 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Where to find the syntax to control with that script, the points (coils) of the IP modbus device?</p>
<p dir="auto">I'm not sure I understand - in your image is the help for the scripting data source with examples of setting values to context points. There is also a help document available in the upper right corner of the script entry area in your screenshot. All you would need to do is add the point to the scripting data source's context and set values to it.</p>
]]></description><link>https://forum.mango-os.com/post/23172</link><guid isPermaLink="true">https://forum.mango-os.com/post/23172</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 16 Aug 2019 16:32:58 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Thu, 15 Aug 2019 19:57:56 GMT]]></title><description><![CDATA[<p dir="auto">Good evening Phil,</p>
<p dir="auto">Thank you for your answer.<br />
]]></description><link>https://forum.mango-os.com/post/23153</link><guid isPermaLink="true">https://forum.mango-os.com/post/23153</guid><dc:creator><![CDATA[JF89]]></dc:creator><pubDate>Thu, 15 Aug 2019 19:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Thu, 15 Aug 2019 16:30:02 GMT]]></title><description><![CDATA[<p dir="auto">You certainly don't always need to know scripting, but it does enable the full flexibility Mango provides in many features. And certainly mastery isn't required either for simple tasks.</p>
<p dir="auto">Without help adapted to the variables that are used in the mango software, or with examples, it will be very difficult for me to master these scripts</p>
<p dir="auto">Fortunately there is help as your screenshot shows, and there is this forum where many examples of things have been provided, and others are often only a question away!</p>
<p dir="auto">The Dashboard Designer can alleviate a lot of the need to be an AngularJS master, but again the forum is here to help.</p>
<p dir="auto">Thanks for the kind words!</p>
]]></description><link>https://forum.mango-os.com/post/23133</link><guid isPermaLink="true">https://forum.mango-os.com/post/23133</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 15 Aug 2019 16:30:02 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Thu, 15 Aug 2019 07:46:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello Phil,</p>
<p dir="auto">Thank you for your answer for setting a CRON Patern variable with a script.</p>
<p dir="auto">From now on, I understand how it will work.</p>
<p dir="auto">The problem is that you have to master the scripts (apparently JavaScript), master their syntax and their language with the mango software.</p>
<p dir="auto"><img src="https://camo.nodebb.org/c6cef8d98eb1535d188ecfb511408692437f16b2?url=https%3A%2F%2Fi.imgur.com%2FjByf3PM.png" alt="0_1565855799856_Screenshot_cron pattern script.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The mango Software is very powerful, with its widgets and associated functions (time program, excel report, bulk data point edit, Watchlist etc .. that I hadexperimented.<br />
I have not yet approached angular JS, which actually seems as very powerful.</p>
<p dir="auto">The problem is that I am an PLC programmer and not a computer programmer.</p>
<p dir="auto">It is possible to copy, pieces of scripts, provided that it is commented, and incorporate them into the program, or to modify a little theses scripts,  but not to invent scripts. (It becomes the work of a real computer programmer<br />
).</p>
]]></description><link>https://forum.mango-os.com/post/23129</link><guid isPermaLink="true">https://forum.mango-os.com/post/23129</guid><dc:creator><![CDATA[JF89]]></dc:creator><pubDate>Thu, 15 Aug 2019 07:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Wed, 14 Aug 2019 21:03:51 GMT]]></title><description><![CDATA[<p dir="auto">If you are up to date nothing would be required, simply create / edit a scripting data source in the new UI and click the icon to open the widget:</p>
<p dir="auto"><img src="https://camo.nodebb.org/e303f1d3d40c7fc8e4f5920cf5b122a340f746d9?url=https%3A%2F%2Fi.imgur.com%2FalQkdID.png" alt="0_1565817440104_cronWidget.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/23120</link><guid isPermaLink="true">https://forum.mango-os.com/post/23120</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 14 Aug 2019 21:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Wed, 14 Aug 2019 20:36:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello Phil, thank you for your answer.<br />
You said: instead there is a widget to help craft cron patterns.</p>
<p dir="auto">But where are those widgets ? and how works cron patterns ?<br />
Does it requires a new module ?</p>
<p dir="auto">best regards</p>
]]></description><link>https://forum.mango-os.com/post/23118</link><guid isPermaLink="true">https://forum.mango-os.com/post/23118</guid><dc:creator><![CDATA[JF89]]></dc:creator><pubDate>Wed, 14 Aug 2019 20:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to heartbeat  in mango, to send it every five seconds to each controller on Wed, 14 Aug 2019 16:36:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi JF89,</p>
<p dir="auto">I would use a scripting data source on a cron pattern of <code>0/5 * * * * ?</code> and the modbus point you'll be setting the value to in the context.</p>
<p dir="auto">The links to a tutorial are no longer active.</p>
<p dir="auto">And that help dialogue isn't provided in the new UI, instead there is a widget to help craft cron patterns.</p>
]]></description><link>https://forum.mango-os.com/post/23113</link><guid isPermaLink="true">https://forum.mango-os.com/post/23113</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 14 Aug 2019 16:36:20 GMT</pubDate></item></channel></rss>
