<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[bulk importing datapoints]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">After watching the tutorial bulk importing datapoints, I tried to create points, but without success.</p>
<p dir="auto">Here are the errors that I have:</p>
<p dir="auto">Do you have any idea of the setup error I was able to make?<br />
Best regards</p>
<p dir="auto"><img src="https://i.imgur.com/coqgNLf.png" alt="0_1565192189538_databulk csv import.png" class=" img-fluid img-markdown" /><br />
<img src="https://i.imgur.com/SDa7u21.png" alt="0_1565192215681_databulk csv import2.png" class=" img-fluid img-markdown" /><br />
and with only one point<br />
<img src="https://i.imgur.com/S0ew9IC.png" alt="0_1565192227049_databulk csv import3.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/4382/bulk-importing-datapoints</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Mar 2026 03:32:47 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4382.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Aug 2019 15:24:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to bulk importing datapoints on Tue, 10 Sep 2019 16:09:09 GMT]]></title><description><![CDATA[<p dir="auto">Removing the row from the CSV is the correct course of action if you do not want to modify that point in any way. The available options are <code>CREATE</code>, <code>UPDATE</code>, and <code>DELETE</code>. I will consider adding something like <code>DO_NOTHING</code> or <code>IGNORE</code> for convenience.</p>
]]></description><link>https://forum.mango-os.com/post/23574</link><guid isPermaLink="true">https://forum.mango-os.com/post/23574</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 10 Sep 2019 16:09:09 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Mon, 09 Sep 2019 12:56:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi cwangv,</p>
<p dir="auto">I tried removing the points (rows) that i didn't need change and only kept the ones that I needed to modify/create in the CSV file. What happened was i lost the ones that i didn't want to change after importing the csv file.</p>
<p dir="auto">So you just removed the rows from the CSV, imported it, and the data points that were not in the CSV no longer exist? Can you provide more explicit steps, as I was not able to replicate with the above steps.</p>
]]></description><link>https://forum.mango-os.com/post/23550</link><guid isPermaLink="true">https://forum.mango-os.com/post/23550</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 09 Sep 2019 12:56:55 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Sun, 08 Sep 2019 17:34:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi cwangv,</p>
<p dir="auto">'UPDATE' is the standard option if you download a csv.</p>
<p dir="auto">If you don't change anything in a object row, you can leave it as it is.</p>
<p dir="auto">I am doing the modifying and adding new data points as a separate operation and I have no errors so far.</p>
]]></description><link>https://forum.mango-os.com/post/23543</link><guid isPermaLink="true">https://forum.mango-os.com/post/23543</guid><dc:creator><![CDATA[Ralf]]></dc:creator><pubDate>Sun, 08 Sep 2019 17:34:40 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Sat, 07 Sep 2019 07:56:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Just a follow-up question:<br />
what are the available options under column 'Action' - so far I know they are: 'Create', 'Modify'.<br />
What if i want to keep a row unchanged? Is there a keyword for that?<br />
<p dir="auto">Any pointer will be appreciated.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/23538</link><guid isPermaLink="true">https://forum.mango-os.com/post/23538</guid><dc:creator><![CDATA[cwangv]]></dc:creator><pubDate>Sat, 07 Sep 2019 07:56:33 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Thu, 08 Aug 2019 15:26:25 GMT]]></title><description><![CDATA[<p dir="auto">HI Craig,</p>
<p dir="auto">It works perfectly with libreoffice  , as you said.</p>
<p dir="auto">Thank you very much.<br />
Best regards</p>
]]></description><link>https://forum.mango-os.com/post/23068</link><guid isPermaLink="true">https://forum.mango-os.com/post/23068</guid><dc:creator><![CDATA[JF89]]></dc:creator><pubDate>Thu, 08 Aug 2019 15:26:25 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Thu, 08 Aug 2019 09:18:26 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/jf89">@<bdi>JF89</bdi></a></p>
<p dir="auto">I tested this today by first creating a single numeric point as a seed, copied down and then changed the names and offsets.  I did not have any issue.  I also think that excel could be changing the format of the CSV.  You should use libre office calc.  It is great for working with CSV.</p>
]]></description><link>https://forum.mango-os.com/post/23061</link><guid isPermaLink="true">https://forum.mango-os.com/post/23061</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 08 Aug 2019 09:18:26 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Wed, 07 Aug 2019 17:26:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi JF89,</p>
<p dir="auto">Can you share the CSV that you're trying to upload as text? Sometimes Excel and other spreadsheet applications can perform some unfortunate reformatting.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomaseinasto">@<bdi>ThomasEinasto</bdi></a><br />
The CSV upload does allow you to leave the columns blank as he has done if the action is <code>"CREATE"</code>. I was using a text editor and I was only able to get it to complain about the XID when I set it to <code>"EMPTY"</code> but it wasn't the same issue pictured in JF89's screenshots.</p>
]]></description><link>https://forum.mango-os.com/post/23055</link><guid isPermaLink="true">https://forum.mango-os.com/post/23055</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 07 Aug 2019 17:26:29 GMT</pubDate></item><item><title><![CDATA[Reply to bulk importing datapoints on Wed, 07 Aug 2019 15:33:56 GMT]]></title><description><![CDATA[<p dir="auto">As I have not used this yet but seeing your pictures I suggest you adding original xid and xid for each point.</p>
<p dir="auto">XIDs are required as they are the unique IDs of the points.</p>
<p dir="auto">On your third picture the error also indicates that property xid must not be null i.e it should have value.</p>
]]></description><link>https://forum.mango-os.com/post/23052</link><guid isPermaLink="true">https://forum.mango-os.com/post/23052</guid><dc:creator><![CDATA[ThomasEinasto]]></dc:creator><pubDate>Wed, 07 Aug 2019 15:33:56 GMT</pubDate></item></channel></rss>
