<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding Text to point values in Dashboard Designer]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">When I add a point value for instance, in dashboard designer,<br />
it does not show the point name, I have to add another text box<br />
to label it. I have tried adding the name to text and font, but the<br />
text disappears after a save.</p>
<p dir="auto">I must be missing something simple..</p>
<p dir="auto">Please</p>
]]></description><link>https://forum.mango-os.com/topic/4348/adding-text-to-point-values-in-dashboard-designer</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 14:03:34 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4348.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Jul 2019 07:41:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 22:37:41 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Jared, you guys are awesome!</p>
<p dir="auto">Great response time, much appreciated.</p>
]]></description><link>https://forum.mango-os.com/post/22914</link><guid isPermaLink="true">https://forum.mango-os.com/post/22914</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 22:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 17:22:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayden_aus" aria-label="Profile: hayden_AUS">@<bdi>hayden_AUS</bdi></a> I've added the option for displaying a label to  <code>&lt;ma-switch&gt;</code> I've also made it possible to display the tags. See screenshot below.</p>
<p dir="auto"><img src="https://camo.nodebb.org/1ebb6beb137d9d29de31b7b615c0e248acfa22b4?url=https%3A%2F%2Fi.imgur.com%2FU76kdHQ.png" alt="0_1564421620906_a74efd14-6d04-4192-8721-ce44cb3e1fe7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This will be released in UI module v3.6.3 which should go out today.</p>
]]></description><link>https://forum.mango-os.com/post/22903</link><guid isPermaLink="true">https://forum.mango-os.com/post/22903</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 29 Jul 2019 17:22:23 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:52:56 GMT]]></title><description><![CDATA[<p dir="auto">I'm sure with enough motivation the component can be changed.  might help to give an exact description of what you would like.</p>
<p dir="auto">My 2 cents is that the component should be able to have the same attribute as the <code>&lt;ma-point-value&gt;</code> to include the name or device name before the switch.  As well as being able to choose to show the point value or not,</p>
]]></description><link>https://forum.mango-os.com/post/22891</link><guid isPermaLink="true">https://forum.mango-os.com/post/22891</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:25:05 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Craig, That's what I have already been doing, except I drag from the Basic Components section.</p>
<p dir="auto">Anyways, thanks for the help, I will wait to see if IA do a fix, or just keep doing the two elements.</p>
]]></description><link>https://forum.mango-os.com/post/22889</link><guid isPermaLink="true">https://forum.mango-os.com/post/22889</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:20:56 GMT]]></title><description><![CDATA[<pre><code>&lt;div class="ma-designer-root" id="2a377d42-b2ca-48dc-b763-b1ab6bf93f90" style="width: 1366px; height: 768px; position: relative;"&gt;
    &lt;label id="4bdbe665-0230-4cc4-890f-e29e72942c9d" style="position: absolute; left: 0px; top: 12px;"&gt;my binary point:&lt;/label&gt;
    &lt;ma-switch id="08959504-fe1d-4fe8-b19d-5b197e7cd3b8" style="position: absolute; left: 130.438px; top: 0px;" point-xid="LGCY_OZ2_AMB_O3HIGH"&gt;&lt;/ma-switch&gt;
&lt;/div&gt;
<p dir="auto">Here I used the drag and drop, the <code>&lt;label&gt;</code> is in the  HTML elements drop down.</p>
]]></description><link>https://forum.mango-os.com/post/22888</link><guid isPermaLink="true">https://forum.mango-os.com/post/22888</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:20:56 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:16:42 GMT]]></title><description><![CDATA[<p dir="auto">Where do you use Label?</p>
<p dir="auto">I added label to be "NAME' like in the Point Value Element, it didn't work.</p>
<pre><code>&lt;ma-switch id="c7d1c0f3-cf43-489c-a51c-719830aba9cc" style="position: absolute; left: 0px; top: 0px;" point-xid="DP_e73a38ec-004f-447c-b527-90d7ef73c6ec" label="NAME"&gt;&lt;/ma-switch&gt;&lt;/ma-switch&gt;
]]></description><link>https://forum.mango-os.com/post/22887</link><guid isPermaLink="true">https://forum.mango-os.com/post/22887</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:16:42 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:11:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayden_aus" aria-label="Profile: hayden_aus">@<bdi>hayden_aus</bdi></a><br />
I actually agree I was using this element a few days ago and was running into the same problem.  I think we could also add another attribute to choose to display the rendered value or not.  it is not always necessary.</p>
]]></description><link>https://forum.mango-os.com/post/22885</link><guid isPermaLink="true">https://forum.mango-os.com/post/22885</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:11:51 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:09:19 GMT]]></title><description><![CDATA[<p dir="auto">Ye for the <code>&lt;ma-switch&gt;</code> you will need to add a <code>&lt;label&gt;</code> in before/after it as  It shows the points rendered value after the switch.</p>
]]></description><link>https://forum.mango-os.com/post/22884</link><guid isPermaLink="true">https://forum.mango-os.com/post/22884</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:09:19 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:09:11 GMT]]></title><description><![CDATA[<p dir="auto">The "Point Value" element, there is an attribute "label", where you can choose "NAME".<br />
I think IA could add this to the other elements such as "Binary Switch Button" to avoid<br />
the extra step to name using code.</p>
]]></description><link>https://forum.mango-os.com/post/22883</link><guid isPermaLink="true">https://forum.mango-os.com/post/22883</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:09:11 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 08:05:48 GMT]]></title><description><![CDATA[<p dir="auto">Thanks FOX, just thought I should be able to do it using the drag and drop method.</p>
]]></description><link>https://forum.mango-os.com/post/22882</link><guid isPermaLink="true">https://forum.mango-os.com/post/22882</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 08:05:48 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 07:54:36 GMT]]></title><description><![CDATA[<p dir="auto">You need the actual point itself rather than the pointValue. The two are different in the fact that the value relates to the point in question.<br />
Typing from my phone here, so excuse the brevity...</p>
<pre><code>&lt;ma-get-point-value point-xid="xidOfYourPoint" point="point"&gt;&lt;/ma-get-point-value&gt;
&lt;label&gt;{{point.deviceName}} : {{point.value}}&lt;/label&gt;
<p dir="auto">I strongly suggest you look at the mangoUi api. To view it enable it in the edit menu page under administration. It will explain how each component works and what is required to get/set the data you require.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/22879</link><guid isPermaLink="true">https://forum.mango-os.com/post/22879</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 29 Jul 2019 07:54:36 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 07:53:39 GMT]]></title><description><![CDATA[<p dir="auto">Craig,</p>
<p dir="auto">When I simply drag a "Binary switch button" and label it in "text and font", this is the code<br />
that is generated:</p>
<pre><code>&lt;div class="ma-designer-root" style="width: 1366px; height: 768px; position: relative;" id="b4938982-c168-42f1-b9f2-701c51d0b541"&gt;
    &lt;ma-switch id="c7d1c0f3-cf43-489c-a51c-719830aba9cc" style="position: absolute; left: 0px; top: 0px;" point-xid="DP_e73a38ec-004f-447c-b527-90d7ef73c6ec"&gt;Yellow inlet valve&lt;/ma-switch&gt;
&lt;/div&gt;
<p dir="auto">When I save and view the page, the text is gone.</p>
<p dir="auto">I just want to keep this simple, so either automatically naming the point or naming it some other way.</p>
]]></description><link>https://forum.mango-os.com/post/22878</link><guid isPermaLink="true">https://forum.mango-os.com/post/22878</guid><dc:creator><![CDATA[hayden_AUS]]></dc:creator><pubDate>Mon, 29 Jul 2019 07:53:39 GMT</pubDate></item><item><title><![CDATA[Reply to Adding Text to point values in Dashboard Designer on Mon, 29 Jul 2019 07:47:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi Hayden</p>
<p dir="auto">if you are using a <code>&lt;ma-point-value&gt;</code> you can either add <code>label="DEVICE_AND_NAME"</code>  or <code>label="NAME"</code></p>
]]></description><link>https://forum.mango-os.com/post/22877</link><guid isPermaLink="true">https://forum.mango-os.com/post/22877</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 29 Jul 2019 07:47:15 GMT</pubDate></item></channel></rss>
