<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Status Code 406 - Future dated points not acceptable]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">We are developing a client application (in java) to set the data points . We use the REST API to set data values ​​but we are faced with the error:</p>
<p dir="auto"><em>status code: 406 - message: error - resp.Headers: {Server=[Jetty(9.2.12.v20150709)], messages=[], Content-Length=[0], errors=[<strong>Future dated points not acceptable</strong>.], Date=[Fri, 19 Apr 2019 20:42:17 GMT]} - respBody null</em></p>
<p dir="auto">We tried to use the CURL command but we not received any response.</p>
<p dir="auto"><em>curl -X PUT http://&lt;ip-mango&gt;:8080/rest/v1/point-values/q21?unitConversion=false -H 'Accept: application/json' -H 'Content-Type: application/json' -H 'Cookie: MANGO8080=imueqd0n5ol71c45xym5mobm' -H 'User-Agent: Java-Swagger' -d '{ "dataType": "NUMERIC", "value": 1, "timestamp": 1561455736049, "annotation": "from ESF" }'</em></p>
<p dir="auto">The version of Mango Automation is 2.7.12.</p>
<p dir="auto">Any ideas?<br />
Are there the configurations (or check) that we can cunsult directly on Mango Automation UI?</p>
<p dir="auto">Tnks and BR.</p>
]]></description><link>https://forum.mango-os.com/topic/4290/status-code-406-future-dated-points-not-acceptable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 19:03:31 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4290.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Jul 2019 13:40:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Status Code 406 - Future dated points not acceptable on Tue, 02 Jul 2019 18:05:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi giovanni.persia, welcome to the forum!</p>
<p dir="auto">Is the error correct, that the data values you are trying to set are in the future?</p>
<p dir="auto">If yes, you can change how far into the future new values may be. This setting is under the Purge Settings in the system settings page, under administration.</p>
<p dir="auto"><img src="https://camo.nodebb.org/80d9b83e6f47930d7ac92ab6f161fd89df947694?url=https%3A%2F%2Fi.imgur.com%2FCWTD9sN.png" alt="0_1562091498350_discard-future-values-limit.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/22599</link><guid isPermaLink="true">https://forum.mango-os.com/post/22599</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 02 Jul 2019 18:05:59 GMT</pubDate></item></channel></rss>
