<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing MangoES to use DHCP via USB key not working]]></title><description><![CDATA[<p dir="auto">Mango software version (core): 3.5.6 (current at 28/5/2019)</p>
<p dir="auto">I have tried to change a couple of MangoES's from Static IP (on eth0, IPv4) to DHCP. When I plug in the USB stick, the LED's flash on then off.  I then power cycle the device, but the settings aren't changed. I have successfully used the USB stick to change from dhcp to static, so I know the process works in general. I am using the same file - '\script-enabled\networking.properties'. The read_me file on the drive has an example for changing to static, but not one for changing to DHCP. It looks pretty straightforward - I believe I have followed the syntax rules in the READ_ME  file, but can't get it to work. If I go into System Settings -&gt; MangoES configuration on the old UI, I can manually change to dchp without a problem.  I checked the mango log files, but couldn't see anything logged about this. I have attached screenshots of files and config I'm using.</p>
<p dir="auto">The settings I'm starting with:<br />
<img src="https://camo.nodebb.org/05f09324d6fcf097988c740e340e3fffb873ede2?url=https%3A%2F%2Fi.imgur.com%2FyGyWu65.jpg" alt="0_1559264292575_Before - static IP.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The file I'm using to change to dhcp - does NOT work:<br />
<img src="https://camo.nodebb.org/6041c96412f148fccab9665f200973a10b02a927?url=https%3A%2F%2Fi.imgur.com%2FtcA2qQS.jpg" alt="0_1559264628935_change-to-dhcp - this does NOT work.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Another file I have tried with more fields - still doesn't work:<br />
<img src="https://camo.nodebb.org/4037bdee2b7c06fc485dc0527d7f604f3f53b76a?url=https%3A%2F%2Fi.imgur.com%2FbPPHr2C.jpg" alt="0_1559264638262_change-to-dhcp with all fields - this does NOT work.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is a file I use to change the other way (ie to a static address) - it works fine:<br />
<img src="https://camo.nodebb.org/f25e8119b194aa0b18c0347ab35dc1aace3b53b8?url=https%3A%2F%2Fi.imgur.com%2FsjxcIZy.jpg" alt="0_1559264644829_change-to-static IP - this works.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/4235/changing-mangoes-to-use-dhcp-via-usb-key-not-working</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 00:34:42 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4235.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 May 2019 00:55:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing MangoES to use DHCP via USB key not working on Thu, 31 Oct 2019 01:32:49 GMT]]></title><description><![CDATA[<p dir="auto">This is working now. I think the main issue was simply that 'DHCP' needs to be upper case. Other things I noticed were that the script takes about 1 minute to complete, the LED's do NOT go off (even after about an hour) and the mango needs to be rebooted (it does not need a reboot when changing to a fixed IP address).</p>
]]></description><link>https://forum.mango-os.com/post/23948</link><guid isPermaLink="true">https://forum.mango-os.com/post/23948</guid><dc:creator><![CDATA[andrewh]]></dc:creator><pubDate>Thu, 31 Oct 2019 01:32:49 GMT</pubDate></item><item><title><![CDATA[Reply to Changing MangoES to use DHCP via USB key not working on Tue, 04 Jun 2019 17:47:11 GMT]]></title><description><![CDATA[<p dir="auto">Without that folder I would have expected the USB utility script to abort due to an improper file structure.</p>
]]></description><link>https://forum.mango-os.com/post/22299</link><guid isPermaLink="true">https://forum.mango-os.com/post/22299</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 04 Jun 2019 17:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to Changing MangoES to use DHCP via USB key not working on Tue, 04 Jun 2019 10:29:22 GMT]]></title><description><![CDATA[<p dir="auto">I checked the USB key and it does NOT have a /MangoES folder. I checked another key and it does have the folder. I have created a /MangoES folder on the key and will try again tomorrow. I'll let you know what happens.</p>
]]></description><link>https://forum.mango-os.com/post/22294</link><guid isPermaLink="true">https://forum.mango-os.com/post/22294</guid><dc:creator><![CDATA[andrewh]]></dc:creator><pubDate>Tue, 04 Jun 2019 10:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to Changing MangoES to use DHCP via USB key not working on Fri, 31 May 2019 17:42:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi andrewh,</p>
<p dir="auto">There should be an output log in the MangoES/ directory on the USB utility, but it looks like there may not be a message if there was an error status on attempting to set it to DHCP. The interesting thing about what you report is that the USB utility uses the scripts from the ES Configuration module to make its changes to the operating system. So, I would expect it to work if the ES Configuration module is and the utility is running. Can you share the output of the /MangoES/esUsbUtility-{date}.log file?</p>
]]></description><link>https://forum.mango-os.com/post/22281</link><guid isPermaLink="true">https://forum.mango-os.com/post/22281</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 31 May 2019 17:42:48 GMT</pubDate></item></channel></rss>
