<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[User component menu not showing up in dashboard designer]]></title><description><![CDATA[<p dir="auto">Placeholder thread.</p>
]]></description><link>https://forum.mango-os.com/topic/4221/user-component-menu-not-showing-up-in-dashboard-designer</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 01:05:59 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4221.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 May 2019 16:17:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Thu, 23 May 2019 05:43:05 GMT]]></title><description><![CDATA[<p dir="auto">I added the component with the + and now User Components is visible and i can drag them from the menu</p>
]]></description><link>https://forum.mango-os.com/post/22222</link><guid isPermaLink="true">https://forum.mango-os.com/post/22222</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Thu, 23 May 2019 05:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 21:21:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wallobee" aria-label="Profile: wallobee">@<bdi>wallobee</bdi></a> said in <a href="/post/22203">User component menu not showing up in dashboard designer</a>:</p>
<p dir="auto">How do I define the components/directives in my user module?</p>
<p dir="auto">By adding this to your user module code as per the example.<br />
<code>userModule.component('myComponent', {options...});</code></p>
<p dir="auto">How do i work around and add them manually to the page?</p>
<p dir="auto"><img src="https://camo.nodebb.org/6949de65fb68b887280dc70fb6ea78cecb944399?url=https%3A%2F%2Fi.imgur.com%2FI7wvCdF.png" alt="0_1558387939192_c48d4369-f5fa-40d9-9602-b9df99c0f48d-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then enter the component name e.g. <code>myComponent</code> or <code>my-component</code></p>
]]></description><link>https://forum.mango-os.com/post/22209</link><guid isPermaLink="true">https://forum.mango-os.com/post/22209</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 20 May 2019 21:21:50 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 19:42:07 GMT]]></title><description><![CDATA[<p dir="auto">I trust that you've added the userModule in the UI Settings otherwise the component won't show.<br />
2) once under page editor you can add them by typing them in.<br />
In this case:</p>
<pre><code>&lt;my-component name="'Foxtrot'"&gt;&lt;/mycomponent&gt;
<p dir="auto">I believe you can also drag and drop them in the dashboard editor from the user components drop down.</p>
<p dir="auto">How do I define the components/directives in my user module?<br />
I copied the example from the tutorial<br />
<img src="https://camo.nodebb.org/b1ffd1349643ec856a669e3ebd073313b5be1a07?url=https%3A%2F%2Fi.imgur.com%2F1Ph9cGS.png" alt="0_1558371833489_853e5e9a-ae9a-46b7-bc6d-dc211fbe5208-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">If by manually you mean with your own dashboard page templates you'll need to move away from using the public file store and break everything out into files. If you've looked at the dialogue component I wrote that you commented on you'll see how it's all laid out.</p>
]]></description><link>https://forum.mango-os.com/post/22207</link><guid isPermaLink="true">https://forum.mango-os.com/post/22207</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Mon, 20 May 2019 19:42:07 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 16:53:02 GMT]]></title><description><![CDATA[<p dir="auto">How do I define the components/directives in my user module?<br />
]]></description><link>https://forum.mango-os.com/post/22203</link><guid isPermaLink="true">https://forum.mango-os.com/post/22203</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 16:53:02 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 16:18:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wallobee" aria-label="Profile: wallobee">@<bdi>wallobee</bdi></a> Please create a new thread in the future.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wallobee" aria-label="Profile: wallobee">@<bdi>wallobee</bdi></a> said in <a href="/post/22187">Pop up window (face plate)</a>:</p>
<p dir="auto">I am trying to setup a similar userModule and ran through the example here<br />
<a href="https://help.infiniteautomation.com/getting-started-with-a-user-module/" rel="nofollow ugc">https://help.infiniteautomation.com/getting-started-with-a-user-module/</a><br />
but I don't get a UserComponents dropdown in my designer</p>
<p dir="auto">This most obvious thing I need to ask is, do you have components/directives defined in your user module? I seem to remember there was a bug around this that I fixed, so it may not be working in the currently released version. You can still manually add them to the page by name.</p>
]]></description><link>https://forum.mango-os.com/post/22200</link><guid isPermaLink="true">https://forum.mango-os.com/post/22200</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 20 May 2019 16:18:39 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 15:41:12 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/f900e3bf9d5da27be1d3945d2a07bc707a3ba398?url=https%3A%2F%2Fi.imgur.com%2F52GlEPc.png" alt="0_1558367546623_7bf20c2b-4c4b-4c60-a9c1-1c415012cbbd-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/22193</link><guid isPermaLink="true">https://forum.mango-os.com/post/22193</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 15:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 15:36:41 GMT]]></title><description><![CDATA[<p dir="auto">When in the dashboard designer page right click on click inspect.  This will open your browser debug tools.  Look for the console tab to see if there are any errors.</p>
]]></description><link>https://forum.mango-os.com/post/22192</link><guid isPermaLink="true">https://forum.mango-os.com/post/22192</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 20 May 2019 15:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 15:11:59 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/01c7d40ab0c02ab9611624449c4580a1b0054cf8?url=https%3A%2F%2Fi.imgur.com%2FktC0zfe.png" alt="0_1558365792518_165ce55d-0a6b-4def-b5bc-b837aa61c896-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/22189</link><guid isPermaLink="true">https://forum.mango-os.com/post/22189</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 15:11:59 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 15:09:55 GMT]]></title><description><![CDATA[<p dir="auto">Are there any errors in your browsers console ?</p>
]]></description><link>https://forum.mango-os.com/post/22188</link><guid isPermaLink="true">https://forum.mango-os.com/post/22188</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 20 May 2019 15:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to User component menu not showing up in dashboard designer on Mon, 20 May 2019 15:07:20 GMT]]></title><description><![CDATA[<p dir="auto">I am trying to setup a similar userModule and ran through the example here<br />
but I don't get a UserComponents dropdown in my designer<br />
<img src="https://camo.nodebb.org/069c9c702ee4a0c55533eb2eaeb9725a1845e2a4?url=https%3A%2F%2Fi.imgur.com%2FxfFypVv.png" alt="0_1558365511501_82ba9bd3-cee4-496d-8a4c-6d89a716de87-image.png" class=" img-fluid img-markdown" /><br />
<img src="https://camo.nodebb.org/ba815e7ed4e0b198244c349ed443320f6e828d9c?url=https%3A%2F%2Fi.imgur.com%2Fak6sO4j.png" alt="0_1558365470674_b66d118b-c7c3-4c46-a510-9993cb950c26-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/22187</link><guid isPermaLink="true">https://forum.mango-os.com/post/22187</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 15:07:20 GMT</pubDate></item></channel></rss>
