<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Couldn&#x27;t get session with PLC]]></title><description><![CDATA[<p dir="auto">I had my data source and datapoints all setup and working in my development network and when I moved everything to my production network I am now getting this message. Couldn't get session with PLC.</p>
<p dir="auto"><img src="https://camo.nodebb.org/26d35802a25df0939dc39e53c4bae2fc0cb65d44?url=https%3A%2F%2Fi.imgur.com%2FG4STTGN.png" alt="0_1558363262496_2e92e57e-ca83-41fe-a8f8-d778596de983-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Mango is running on a different PC and there is a different PLC on the production network. The PLC is the same type (AB). I tried turning off the anti-virus program running on the new PC but still get the error.</p>
<p dir="auto">I created a new device and called it PBR and it also is coming up with the same session error.<br />
I also pinged the PLC IP address from the PC and it responds.</p>
<p dir="auto">Not sure what else to check.</p>
]]></description><link>https://forum.mango-os.com/topic/4218/couldn-t-get-session-with-plc</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:08:11 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4218.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 May 2019 14:35:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Wed, 07 Apr 2021 18:29:44 GMT]]></title><description><![CDATA[<p dir="auto">Having the same issue currently. Was anyone able to figure this out? Thanks!</p>
]]></description><link>https://forum.mango-os.com/post/26508</link><guid isPermaLink="true">https://forum.mango-os.com/post/26508</guid><dc:creator><![CDATA[henry.hollis]]></dc:creator><pubDate>Wed, 07 Apr 2021 18:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Mon, 20 May 2019 17:11:57 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">I also pinged the PLC IP address from the PC and it responds.</p>
<p dir="auto">Are you able to netcat or telnet to the port that you're expecting to connect to? There could be some sort of firewalling involved.</p>
<p dir="auto">Unfortunately I do not have access to the source code for the AB modules, so I can't look into the exact meaning of that message. If it's not the firewall I'll try to get someone who does have access to that code to have a look at this.</p>
]]></description><link>https://forum.mango-os.com/post/22206</link><guid isPermaLink="true">https://forum.mango-os.com/post/22206</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 20 May 2019 17:11:57 GMT</pubDate></item><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Mon, 20 May 2019 16:01:27 GMT]]></title><description><![CDATA[<p dir="auto">yes it has a license for the ABIP</p>
]]></description><link>https://forum.mango-os.com/post/22197</link><guid isPermaLink="true">https://forum.mango-os.com/post/22197</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 16:01:27 GMT</pubDate></item><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Mon, 20 May 2019 15:56:59 GMT]]></title><description><![CDATA[<p dir="auto">Does your production system have a licence for the AB ip data source? Whenever pasting code please put it in a <code>code element &lt;/&gt;</code> it will makes it scrollable.  You are welcome to edit your post above.</p>
]]></description><link>https://forum.mango-os.com/post/22196</link><guid isPermaLink="true">https://forum.mango-os.com/post/22196</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 20 May 2019 15:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Mon, 20 May 2019 16:00:51 GMT]]></title><description><![CDATA[<pre><code>code element &lt;&gt;
INFO  2019-05-20T04:35:19,020 (com.serotonin.m2m2.Main.main:101) - Starting Mango 3.5.6 with Schema Version: 26
INFO  2019-05-20T04:35:19,429 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'abeip', v3.5.1 by Deltamation Software
INFO  2019-05-20T04:35:19,446 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'asciiFile', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,450 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'BACnet', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,456 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'controlcore', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,460 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'dashboardDesigner', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,462 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\Salcedo\enterprise-m2m2-core-3.5.6\web\modules\dashboardDesigner\web\dox\manifest.xml
INFO  2019-05-20T04:35:19,466 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'dataFile', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,482 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'dataImport', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,486 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'deviceConfig', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,488 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\Salcedo\enterprise-m2m2-core-3.5.6\web\modules\deviceConfig\web\dox\manifest.xml
INFO  2019-05-20T04:35:19,492 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'dnp3', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,498 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'egauge', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,502 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'envcands', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,505 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'excelReports', v3.5.3 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,517 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'graphicalViews', v3.5.2 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,542 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'Haystack', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,549 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'http', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,555 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'jsonFileImport', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,558 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'log4jDS', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,562 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'log4JReset', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,564 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'loggingConsole', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,568 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'maintenanceEvents', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,573 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'mangoApi', v3.5.2 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,581 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'mangoNoSqlDatabase', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,585 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'mangoUI', v3.5.5 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,587 (com.serotonin.m2m2.util.DocumentationManifest.parseManifestFile:60) - Documentation manifest file not found: C:\Salcedo\enterprise-m2m2-core-3.5.6\web\modules\mangoUI\web\dox\manifest.xml
INFO  2019-05-20T04:35:19,636 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'mbus', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,636 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'meta', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,636 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'modbus', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,652 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'onewire', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,652 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'opcda', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,652 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'pakbus', v3.5.4 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,652 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'persistent', v3.5.6 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,668 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'pointLinks', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,674 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'pop3', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,678 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'reports', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,684 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'scheduledEvents', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,689 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'scripting', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,689 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'serial', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,689 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'snmp', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,689 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'sqlConsole', v3.5.1 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,689 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'sqlds', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,705 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'ssh', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,705 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'sstGlobalScripts', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,705 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'sstGraphics', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,736 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'TCPIP', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,736 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'templateConfig', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,752 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'twilio', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,752 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'virtualDS', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,752 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'vmstat', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,752 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'watchlists', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:19,767 (com.serotonin.m2m2.Main.loadModules:588) - Loading module 'internal', v3.5.0 by Infinite Automation Systems Inc.
INFO  2019-05-20T04:35:21,596 (com.serotonin.m2m2.Lifecycle.loadLic:604) - Checking license...
INFO  2019-05-20T04:35:21,721 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
INFO  2019-05-20T04:35:22,684 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:38) - Starting instance with core version 3.5.6, db 26
INFO  2019-05-20T04:35:22,684 (com.infiniteautomation.nosql.MangoNoSqlProxy.initialize:77) - Starting MangoNoSql Database
INFO  2019-05-20T04:35:22,721 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:147) - Database at C:\Salcedo\enterprise-m2m2-core-3.5.6\databases\mangoTSDB started
INFO  2019-05-20T04:35:22,832 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:178) - Empty dir delete for database at C:\Salcedo\enterprise-m2m2-core-3.5.6\databases\mangoTSDB took 64ms
INFO  2019-05-20T04:35:22,848 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:147) - Database at C:\Salcedo\enterprise-m2m2-core-3.5.6\databases\mangoTSDBAux started
INFO  2019-05-20T04:35:22,879 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:178) - Empty dir delete for database at C:\Salcedo\enterprise-m2m2-core-3.5.6\databases\mangoTSDBAux took 0ms
INFO  2019-05-20T04:35:24,383 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:120) - Spring context 'runtimeContext' refreshed: org.springframework.context.annotation.AnnotationConfigApplicationContext@2cde651b
INFO  2019-05-20T04:35:24,389 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextStarted:134) - Spring context 'runtimeContext' started: org.springframework.context.annotation.AnnotationConfigApplicationContext@2cde651b
INFO  2019-05-20T04:35:24,483 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:77) - Initializing 3 NORMAL priority data sources in 8 threads.
INFO  2019-05-20T04:35:24,671 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:380) - Data source 'PBR' initialized
INFO  2019-05-20T04:35:24,671 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:385) - Data source 'PBR' took 181.402316ms to start
INFO  2019-05-20T04:35:24,764 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:380) - Data source 'Mango Internal' initialized
INFO  2019-05-20T04:35:24,764 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:385) - Data source 'Mango Internal' took 273.859687ms to start
INFO  2019-05-20T04:35:24,889 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:380) - Data source 'PBR-PLC' initialized
INFO  2019-05-20T04:35:24,889 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initializeDataSourceStartup:385) - Data source 'PBR-PLC' took 397.13596ms to start
INFO  2019-05-20T04:35:24,920 (com.serotonin.m2m2.rt.DataSourceGroupInitializer.initialize:109) - Initialization of 3 NORMAL priority data sources took 437ms
INFO  2019-05-20T04:35:24,951 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:156) - Starting 0 Publishers...
INFO  2019-05-20T04:35:24,951 (com.serotonin.m2m2.rt.RuntimeManagerImpl.initialize:168) - 0 Publisher's started in 0ms
INFO  2019-05-20T04:35:25,697 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:32) - Mango Automation context starting
INFO  2019-05-20T04:35:25,697 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:40) - Mango Automation context started
INFO  2019-05-20T04:35:26,878 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:120) - Spring context 'rootWebContext' refreshed: Root WebApplicationContext
WARN  2019-05-20T04:35:27,678 (org.springframework.web.servlet.handler.SimpleUrlHandlerMapping.registerHandlers:114) - Neither 'urlMap' nor 'mappings' set on SimpleUrlHandlerMapping
INFO  2019-05-20T04:35:27,724 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:120) - Spring context 'jspDispatcherContext' refreshed: WebApplicationContext for namespace 'JSP_DISPATCHER-servlet'
INFO  2019-05-20T04:35:28,647 (com.serotonin.m2m2.web.mvc.rest.v1.BacnetDiscoveryRestController.&lt;init&gt;:54) - Creating Discovery Rest Controller
INFO  2019-05-20T04:35:29,084 (com.serotonin.m2m2.web.mvc.rest.v1.DataPointRestController.&lt;init&gt;:76) - Creating Data Point Rest Controller.
INFO  2019-05-20T04:35:29,240 (com.serotonin.m2m2.web.mvc.rest.v1.DataSourceRestController.&lt;init&gt;:62) - Creating DS Rest Controller
INFO  2019-05-20T04:35:29,520 (com.infiniteautomation.mango.rest.v2.MetaRestController.&lt;init&gt;:52) - Creating meta rest controller.
INFO  2019-05-20T04:35:29,663 (com.infiniteautomation.mango.rest.v2.DataPointRestController.&lt;init&gt;:96) - Creating Data Point v2 Rest Controller.
INFO  2019-05-20T04:35:30,146 (com.infiniteautomation.mango.spring.MangoRuntimeContextConfiguration.contextRefreshed:120) - Spring context 'restDispatcherContext' refreshed: WebApplicationContext for namespace 'REST_DISPATCHER-servlet'
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: EnvCanEditDwr
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: HttpDataSourceDwr
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: TcpIpDataSourceEditDwr
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: Pop3EditDwr
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: HaystackDataSourceDwr
INFO  2019-05-20T04:35:30,146 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: DataFileDataSourceEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: OPCDAEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: BACnetMSTPEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: PakBusEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: MBusEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: com.infiniteautomation.mango.pakbus.dwr.PakBusEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: ABEipEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: SNMPEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: InternalEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: SerialEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: MetaEditDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: PersistentDataSourceDwr
INFO  2019-05-20T04:35:30,162 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: DnpEditDwr
INFO  2019-05-20T04:35:30,178 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: ModbusEditDwr
INFO  2019-05-20T04:35:30,180 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: Log4jEditDwr
INFO  2019-05-20T04:35:30,181 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: ScriptingEditDwr
INFO  2019-05-20T04:35:30,182 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: SshDataSourceEditDwr
INFO  2019-05-20T04:35:30,183 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: AsciiFileEditDwr
INFO  2019-05-20T04:35:30,183 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
INFO  2019-05-20T04:35:30,184 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: OneWireEditDwr
INFO  2019-05-20T04:35:30,185 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: SqlEditDwr
INFO  2019-05-20T04:35:30,186 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: VMStatEditDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: EgaugeDataSourceDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.http.dwr.HttpDataSourceDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: BACnetIPEditDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: br.org.scadabr.dnp3.dwr.DnpEditDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: ControlCoreEditDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1242) - Duplicate definition of DWR class ignored: com.serotonin.m2m2.modbus.dwr.ModbusEditDwr
INFO  2019-05-20T04:35:30,187 (com.serotonin.m2m2.Lifecycle.configureDwr:1249) - Added DWR definition for: VirtualEditDwr
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/pending_alarms.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/event_handlers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_sources.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/point_hierarchy.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/mailing_lists.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/publishers.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/system_settings.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/modules.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/emport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/error.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/not-found.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/unauthorized.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/upload.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/mobile_data_point_details.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/csvDataImport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/dataImport.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/excel-reports.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/views.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/public_view.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/logging_console.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/maintenance_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/mango_no_sql.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/point_links.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/m2m_report_import.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/reportChart.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/reports.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/templateConfig.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/mobile/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/watch_list.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/internal/status.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/internal/threads.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/internal/workItems.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/internal/queueStats.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/internal/tasks.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_point_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.DataPointEditController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_source_properties.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.DataSourcePropertiesController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_source_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.DataSourceEditController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/data_source_properties_error.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.DataSourceEditController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/help.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.HelpController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/startup.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.StartupController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/shutdown.htm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.ShutdownController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/publisher_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.PublisherEditController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/users.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.controller.UsersController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/view_edit.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/scheduled_events.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/sqlConsole.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
INFO  2019-05-20T04:35:30,218 (org.springframework.web.servlet.handler.AbstractUrlHandlerMapping.registerHandler:373) - Mapped URL path [/globalScripts.shtm] onto handler of type [class com.serotonin.m2m2.web.mvc.UrlHandlerController]
WARN  2019-05-20T04:52:06,931 (com.serotonin.m2m2.rt.dataSource.PollingDataSource.incrementUnsuccessfulPolls:157) - Data Source PBR-PLC aborted 1 polls since it started.
INFO  2019-05-20T04:58:15,725 (com.serotonin.m2m2.Lifecycle.terminate:422) - Mango Lifecycle terminating...
INFO  2019-05-20T04:58:15,815 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:72) - Terminating 3 NORMAL priority data sources in 8 threads.
INFO  2019-05-20T04:58:15,833 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:423) - Data source 'PBR' stopped
INFO  2019-05-20T04:58:15,837 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:423) - Data source 'Mango Internal' stopped
INFO  2019-05-20T04:58:15,838 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:423) - Data source 'PBR-PLC' stopped
INFO  2019-05-20T04:58:15,928 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:102) - Termination of 3 NORMAL priority data sources took 113ms
INFO  2019-05-20T04:58:15,928 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:550) - All high priority tasks exited gracefully.
INFO  2019-05-20T04:58:15,928 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:556) - All medium priority tasks exited gracefully.
INFO  2019-05-20T04:58:15,928 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:561) - All low priority tasks exited gracefully.
INFO  2019-05-20T04:58:15,928 (com.infiniteautomation.mango.spring.components.executors.MangoExecutors.destroy:68) - Shutting down shared executor and scheduled exectutor
INFO  2019-05-20T04:58:15,928 (com.infiniteautomation.mango.spring.components.executors.MangoExecutors.awaitTermination:126) - Executors shutdown successfully
INFO  2019-05-20T04:58:16,349 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:115) - Terminating NoSQL Batch Write Manager.
INFO  2019-05-20T04:58:16,349 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:240) - Terminating NoSQL Point Value Mover.
INFO  2019-05-20T04:58:16,349 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:247) - Terminating 1 Batch Writer Tasks.
INFO  2019-05-20T04:58:16,349 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:256) - 1 Batch Writer Tasks awaiting termination.
INFO  2019-05-20T04:58:16,443 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehind.joinTermination:173) - Batch Writer Task 0 Terminated.
INFO  2019-05-20T04:58:16,443 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:264) - Terminating NoSQL Stale Point Cleaner.
INFO  2019-05-20T04:58:16,443 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:267) - Terminating NoSQL Status Provider.
INFO  2019-05-20T04:58:16,443 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:123) - Closing NoSQL Database: Point Values
INFO  2019-05-20T04:58:16,599 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:131) - Closing NoSQL Database: Point Data
INFO  2019-05-20T04:58:16,599 (com.serotonin.m2m2.Lifecycle.terminate:571) - Mango Lifecycle terminated.</code></pre>
]]></description><link>https://forum.mango-os.com/post/22191</link><guid isPermaLink="true">https://forum.mango-os.com/post/22191</guid><dc:creator><![CDATA[wallobee]]></dc:creator><pubDate>Mon, 20 May 2019 16:00:51 GMT</pubDate></item><item><title><![CDATA[Reply to Couldn&#x27;t get session with PLC on Mon, 20 May 2019 15:12:16 GMT]]></title><description><![CDATA[<p dir="auto">Is there anything in your ma.log file that could give more information.  I seldom connect to AB plcs but could your PLC be blocking mango?</p>
]]></description><link>https://forum.mango-os.com/post/22190</link><guid isPermaLink="true">https://forum.mango-os.com/post/22190</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 20 May 2019 15:12:16 GMT</pubDate></item></channel></rss>
