<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No restart flag found, not restarting MA]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">Having a bit of trouble with a mango of mine at a remote site. Noticed the web server wasn't working so i ssh'd into it to restart it but i keep on getting an error when i attempt to do that.</p>
<p dir="auto"><img src="https://camo.nodebb.org/c78b1fc81236a37c28e7269a7fc6efeac10a5610?url=https%3A%2F%2Fi.imgur.com%2FpHhwEsO.png" alt="0_1557456850226_eedd0126-1466-46d1-99e6-5d275e2a8cd3-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have tried rebooting the mango and clearing space on it which didn't work and can't quite think of anything else to try. Any help would be appreciated.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mango-os.com/topic/4199/no-restart-flag-found-not-restarting-ma</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 01:17:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4199.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 May 2019 02:45:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Mon, 13 May 2019 16:51:15 GMT]]></title><description><![CDATA[<p dir="auto">In your first post you provided the output from the command line.  It looks like you got a <code>2112 Bus error</code> when it was executing <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> at line 142.  That leads me to believe there is a hardware problem.  I thought perhaps the files in the ext-enabled folder were corrupt or on a bad sector of the HD but that is just a guess.</p>
]]></description><link>https://forum.mango-os.com/post/22088</link><guid isPermaLink="true">https://forum.mango-os.com/post/22088</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Mon, 13 May 2019 16:51:15 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Mon, 13 May 2019 11:42:04 GMT]]></title><description><![CDATA[<p dir="auto">You could mail it to <a href="mailto:support@infiniteautomation.com" rel="nofollow ugc">support@infiniteautomation.com</a></p>
]]></description><link>https://forum.mango-os.com/post/22085</link><guid isPermaLink="true">https://forum.mango-os.com/post/22085</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 13 May 2019 11:42:04 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Mon, 13 May 2019 08:31:10 GMT]]></title><description><![CDATA[<p dir="auto">It seems like my <a href="http://memory-small.sh" rel="nofollow ugc">memory-small.sh</a> is executable, didn't come up with a error at least when i tried to execute it.</p>
<p dir="auto">Below is my ma-script.log</p>
<pre><code>Fri Feb 5 15:53:54 UTC 2016 ma-start: running init extensions...
Fri Feb 5 15:53:54 UTC 2016 ma-start: running start extensions...
Fri Feb 5 15:53:54 UTC 2016 ma-start: starting MA
Fri Feb 5 15:53:54 UTC 2016 ma-start: MA started with Process ID 523
Fri Feb 5 18:15:14 UTC 2016 ma-start: running stop extensions...
Fri Feb 5 18:15:14 UTC 2016 ma.stop: stop initiated...
Fri Feb 5 18:15:22 UTC 2016 ma-start: MA explicitly stopped. Exiting restart loop
Fri Feb 5 18:15:22 UTC 2016 ma-start: MA done
Tue Jan 1 00:00:09 UTC 2013 ma-start: running init extensions...
Tue Jan 1 00:00:09 UTC 2013 ma-start: running start extensions...
Tue Jan 1 00:00:09 UTC 2013 ma-start: starting MA
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 520
Mon Feb 8 22:18:34 UTC 2016 ma-start: running stop extensions...
Mon Feb 8 22:18:34 UTC 2016 ma.stop: stop initiated...
Tue Jan 1 00:08:54 UTC 2013 ma-start: running init extensions...
Tue Jan 1 00:08:54 UTC 2013 ma-start: running start extensions...
Tue Jan 1 00:08:54 UTC 2013 ma-start: MA removing pid file for dead pid: 520
Tue Jan 1 00:08:54 UTC 2013 ma-start: starting MA
Tue Jan 1 00:08:54 UTC 2013 ma-start: MA started with Process ID 534
Tue Jan 1 00:00:08 UTC 2013 ma-start: running init extensions...
Tue Jan 1 00:00:08 UTC 2013 ma-start: running start extensions...
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA removing pid file for dead pid: 534
Tue Jan 1 00:00:08 UTC 2013 ma-start: starting MA
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA started with Process ID 533
Mon Feb 22 21:11:55 UTC 2016 ma-start: running stop extensions...
Mon Feb 22 21:11:55 UTC 2016 ma.stop: stop initiated...
Mon Feb 22 21:12:05 UTC 2016 ma-start: MA explicitly stopped. Exiting restart loop
Mon Feb 22 21:12:05 UTC 2016 ma-start: MA done
Mon Feb 22 21:15:07 UTC 2016 ma-start: running init extensions...
Mon Feb 22 21:15:07 UTC 2016 ma-start: upgrading core...
Mon Feb 22 21:15:25 UTC 2016 ma-start: running init extensions...
Mon Feb 22 21:15:25 UTC 2016 ma-start: running start extensions...
Mon Feb 22 21:15:25 UTC 2016 ma-start: starting MA
Mon Feb 22 21:15:25 UTC 2016 ma-start: MA started with Process ID 3097
Mon Feb 22 21:18:27 UTC 2016 ma-restart: restart initiated...
Mon Feb 22 21:18:37 UTC 2016 ma-start: running restart extentions
Mon Feb 22 21:18:37 UTC 2016 ma-start: running start extensions...
Mon Feb 22 21:18:37 UTC 2016 ma-start: starting MA
Mon Feb 22 21:18:37 UTC 2016 ma-start: MA started with Process ID 4503
Mon Feb 22 21:20:51 UTC 2016 ma-start: running stop extensions...
Mon Feb 22 21:20:51 UTC 2016 ma.stop: stop initiated...
Mon Feb 22 21:21:02 UTC 2016 ma-start: MA explicitly stopped. Exiting restart loop
Mon Feb 22 21:21:02 UTC 2016 ma-start: MA done
Mon Feb 22 21:21:22 UTC 2016 ma-start: running stop extensions...
Mon Feb 22 21:21:22 UTC 2016 ma.stop: No PID file found. Java process not stopped...
Tue Mar 22 17:47:19 UTC 2016 ma-start: running init extensions...
Tue Mar 22 17:47:19 UTC 2016 ma-start: running start extensions...
Tue Mar 22 17:47:19 UTC 2016 ma-start: starting MA
Tue Mar 22 17:47:19 UTC 2016 ma-start: MA started with Process ID 516
Tue Mar 22 17:57:21 UTC 2016 ma-start: running restart extentions
Tue Mar 22 17:57:21 UTC 2016 ma-start: upgrading core...
Tue Mar 22 17:57:41 UTC 2016 ma-start: running init extensions...
Tue Mar 22 17:57:41 UTC 2016 ma-start: running start extensions...
Tue Mar 22 17:57:41 UTC 2016 ma-start: starting MA
Tue Mar 22 17:57:41 UTC 2016 ma-start: MA started with Process ID 5160
Tue Mar 22 17:58:39 UTC 2016 ma-start: running stop extensions...
Tue Mar 22 17:58:39 UTC 2016 ma.stop: stop initiated...
Tue Mar 22 17:58:48 UTC 2016 ma-start: MA explicitly stopped. Exiting restart loop
Tue Mar 22 17:58:48 UTC 2016 ma-start: MA done
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 532
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA removing pid file for dead pid:
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 541
Wed Mar 30 20:44:13 UTC 2016 ma-start: running restart extentions
Wed Mar 30 20:44:13 UTC 2016 ma-start: running start extensions...
Wed Mar 30 20:44:13 UTC 2016 ma-start: starting MA
Wed Mar 30 20:44:13 UTC 2016 ma-start: MA started with Process ID 2108
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA removing pid file for dead pid: 2108
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 556
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA removing pid file for dead pid: 556
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA started with Process ID 563
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA removing pid file for dead pid: 563
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 578
Tue Jan 1 00:00:10 UTC 2013 ma-start: running init extensions...
Tue Jan 1 00:00:10 UTC 2013 ma-start: running start extensions...
Tue Jan 1 00:00:10 UTC 2013 ma-start: MA removing pid file for dead pid: 578
Tue Jan 1 00:00:10 UTC 2013 ma-start: starting MA
Tue Jan 1 00:00:10 UTC 2013 ma-start: MA started with Process ID 560
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA removing pid file for dead pid: 560
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA started with Process ID 565
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA removing pid file for dead pid: 565
Tue Jan 1 00:00:08 UTC 2013 ma-start: MA started with Process ID 562
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA removing pid file for dead pid: 562
Tue Jan 1 00:00:09 UTC 2013 ma-start: MA started with Process ID 620
Mon May 30 02:18:04 UTC 2016 ma-start: no restart flag found, not restarting MA
Mon May 30 02:18:04 UTC 2016 ma-start: MA done
Mon May 30 02:25:01 UTC 2016 ma-start: running stop extensions...
Mon May 30 02:25:01 UTC 2016 ma.stop: No PID file found. Java process not stopped...
Mon May 30 02:25:27 UTC 2016 ma-start: running init extensions...
Mon May 30 02:25:27 UTC 2016 ma-start: running start extensions...
Mon May 30 02:25:27 UTC 2016 ma-start: starting MA
Mon May 30 02:25:27 UTC 2016 ma-start: MA started with Process ID 576
Tue Jan 1 08:00:09 AWST 2013 ma-start: running init extensions...
Tue Jan 1 08:00:09 AWST 2013 ma-start: running start extensions...
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 576
Tue Jan 1 08:00:09 AWST 2013 ma-start: starting MA
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 606
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 606
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 612
Tue Jan 1 08:00:08 AWST 2013 ma-start: running init extensions...
Tue Jan 1 08:00:08 AWST 2013 ma-start: running start extensions...
Tue Jan 1 08:00:08 AWST 2013 ma-start: MA removing pid file for dead pid: 612
Tue Jan 1 08:00:08 AWST 2013 ma-start: starting MA
Tue Jan 1 08:00:08 AWST 2013 ma-start: MA started with Process ID 605
Tue Jan 1 08:00:10 AWST 2013 ma-start: running init extensions...
Tue Jan 1 08:00:10 AWST 2013 ma-start: running start extensions...
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 605
Tue Jan 1 08:00:10 AWST 2013 ma-start: starting MA
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 601
Tue Jan 1 08:00:08 AWST 2013 ma-start: MA removing pid file for dead pid: 601
Tue Jan 1 08:00:08 AWST 2013 ma-start: MA started with Process ID 600
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 600
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 601
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 601
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 614
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 614
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 610
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 610
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 601
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 605
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 605
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 611
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 611
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 605
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 596
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 596
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 603
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 603
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 622
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 622
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 613
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 613
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 598
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 598
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 602
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 602
Tue Jan 1 08:00:08 AWST 2013 ma-start: MA started with Process ID 617
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 617
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 607
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 607
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 599
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 599
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 612
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 603
Fri Jun 23 13:06:14 AWST 2017 ma-start: running restart extentions
Fri Jun 23 13:06:14 AWST 2017 ma-start: running start extensions...
Fri Jun 23 13:06:14 AWST 2017 ma-start: starting MA
Fri Jun 23 13:06:14 AWST 2017 ma-start: MA started with Process ID 11320
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 11320
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 600
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 609
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 595
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 595
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA started with Process ID 609
Tue Jan 1 08:00:10 AWST 2013 ma-start: MA removing pid file for dead pid: 609
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 598
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 620
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA removing pid file for dead pid: 620
Tue Jan 1 08:00:09 AWST 2013 ma-start: MA started with Process ID 599
Tue Jan 29 16:03:42 AWST 2019 ma-start: running stop extensions...
Tue Jan 29 16:03:42 AWST 2019 ma.stop: stop initiated...
Tue Jan 29 16:03:48 AWST 2019 ma-start: MA explicitly stopped. Exiting restart loop
Tue Jan 29 16:03:48 AWST 2019 ma-start: MA done
Tue Jan 29 16:03:49 AWST 2019 ma-start: running init extensions...
Tue Jan 29 16:03:49 AWST 2019 ma-start: running start extensions...
Tue Jan 29 16:03:49 AWST 2019 ma-start: starting MA
Tue Jan 29 16:03:49 AWST 2019 ma-start: MA started with Process ID 6735
Tue Jan 1 08:00:11 AWST 2013 ma-start: running init extensions...
Tue Jan 1 08:00:11 AWST 2013 ma-start: running start extensions...
Tue Jan 1 08:00:11 AWST 2013 ma-start: MA removing pid file for dead pid: 6735
Tue Jan 1 08:00:11 AWST 2013 ma-start: starting MA
Tue Jan 1 08:00:11 AWST 2013 ma-start: MA started with Process ID 605
Tue Jan 1 08:00:15 AWST 2013 ma-start: no restart flag found, not restarting MA
Tue Jan 1 08:00:15 AWST 2013 ma-start: MA done
Fri May 10 10:35:19 AWST 2019 ma-start: running init extensions...
Fri May 10 10:35:19 AWST 2019 ma-start: running start extensions...
Fri May 10 10:35:19 AWST 2019 ma-start: starting MA
Fri May 10 10:35:19 AWST 2019 ma-start: MA started with Process ID 1945
Fri May 10 10:35:22 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:35:22 AWST 2019 ma-start: MA done
Fri May 10 10:35:49 AWST 2019 ma-start: running stop extensions...
Fri May 10 10:35:49 AWST 2019 ma.stop: No PID file found. Java process not stopped...
Fri May 10 10:35:55 AWST 2019 ma-start: running init extensions...
Fri May 10 10:35:55 AWST 2019 ma-start: running start extensions...
Fri May 10 10:35:55 AWST 2019 ma-start: starting MA
Fri May 10 10:35:55 AWST 2019 ma-start: MA started with Process ID 2200
Fri May 10 10:35:58 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:35:58 AWST 2019 ma-start: MA done
Fri May 10 10:42:27 AWST 2019 ma-start: running init extensions...
Fri May 10 10:42:27 AWST 2019 ma-start: running start extensions...
Fri May 10 10:42:27 AWST 2019 ma-start: starting MA
Fri May 10 10:42:27 AWST 2019 ma-start: MA started with Process ID 4508
Fri May 10 10:42:30 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:42:30 AWST 2019 ma-start: MA done
Fri May 10 10:42:39 AWST 2019 ma-start: running stop extensions...
Fri May 10 10:42:39 AWST 2019 ma.stop: No PID file found. Java process not stopped...
Fri May 10 10:43:07 AWST 2019 ma-start: running init extensions...
Fri May 10 10:43:07 AWST 2019 ma-start: running start extensions...
Fri May 10 10:43:07 AWST 2019 ma-start: starting MA
Fri May 10 10:43:07 AWST 2019 ma-start: MA started with Process ID 603
Fri May 10 10:43:10 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:43:10 AWST 2019 ma-start: MA done
Fri May 10 10:44:15 AWST 2019 ma-start: running stop extensions...
Fri May 10 10:44:15 AWST 2019 ma.stop: No PID file found. Java process not stopped...
Fri May 10 10:44:43 AWST 2019 ma-start: running init extensions...
Fri May 10 10:44:43 AWST 2019 ma-start: running start extensions...
Fri May 10 10:44:43 AWST 2019 ma-start: starting MA
Fri May 10 10:44:43 AWST 2019 ma-start: MA started with Process ID 1624
Fri May 10 10:44:46 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:44:46 AWST 2019 ma-start: MA done
Fri May 10 10:44:58 AWST 2019 ma-start: running init extensions...
Fri May 10 10:44:58 AWST 2019 ma-start: running start extensions...
Fri May 10 10:44:58 AWST 2019 ma-start: starting MA
Fri May 10 10:44:58 AWST 2019 ma-start: MA started with Process ID 1699
Fri May 10 10:45:01 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:45:01 AWST 2019 ma-start: MA done
Fri May 10 10:45:14 AWST 2019 ma-start: running init extensions...
Fri May 10 10:45:14 AWST 2019 ma-start: running start extensions...
Fri May 10 10:45:14 AWST 2019 ma-start: starting MA
Fri May 10 10:45:14 AWST 2019 ma-start: MA started with Process ID 1894
Fri May 10 10:45:17 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:45:17 AWST 2019 ma-start: MA done
Fri May 10 10:45:20 AWST 2019 ma-start: running init extensions...
Fri May 10 10:45:20 AWST 2019 ma-start: running start extensions...
Fri May 10 10:45:20 AWST 2019 ma-start: starting MA
Fri May 10 10:45:20 AWST 2019 ma-start: MA started with Process ID 1945
Fri May 10 10:45:23 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:45:23 AWST 2019 ma-start: MA done
Fri May 10 10:46:27 AWST 2019 ma-start: running init extensions...
Fri May 10 10:46:27 AWST 2019 ma-start: running start extensions...
Fri May 10 10:46:27 AWST 2019 ma-start: starting MA
Fri May 10 10:46:27 AWST 2019 ma-start: MA started with Process ID 2401
Fri May 10 10:46:30 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:46:30 AWST 2019 ma-start: MA done
Fri May 10 10:47:53 AWST 2019 ma-start: running stop extensions...
Fri May 10 10:47:53 AWST 2019 ma.stop: No PID file found. Java process not stopped...
Fri May 10 10:48:19 AWST 2019 ma-start: running init extensions...
Fri May 10 10:48:19 AWST 2019 ma-start: running start extensions...
Fri May 10 10:48:19 AWST 2019 ma-start: starting MA
Fri May 10 10:48:19 AWST 2019 ma-start: MA started with Process ID 612
Fri May 10 10:48:22 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:48:22 AWST 2019 ma-start: MA done
Fri May 10 10:51:32 AWST 2019 ma-start: running init extensions...
Fri May 10 10:51:32 AWST 2019 ma-start: running start extensions...
Fri May 10 10:51:32 AWST 2019 ma-start: starting MA
Fri May 10 10:51:32 AWST 2019 ma-start: MA started with Process ID 2112
Fri May 10 10:51:36 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 10:51:36 AWST 2019 ma-start: MA done
Fri May 10 11:55:50 AWST 2019 ma-start: running init extensions...
Fri May 10 11:55:50 AWST 2019 ma-start: running start extensions...
Fri May 10 11:55:50 AWST 2019 ma-start: starting MA
Fri May 10 11:55:50 AWST 2019 ma-start: MA started with Process ID 23778
Fri May 10 11:55:53 AWST 2019 ma-start: no restart flag found, not restarting MA
Fri May 10 11:55:53 AWST 2019 ma-start: MA done
Mon May 13 14:27:20 AWST 2019 ma-start: running init extensions...
Mon May 13 14:27:20 AWST 2019 ma-start: running start extensions...
Mon May 13 14:27:20 AWST 2019 ma-start: starting MA
Mon May 13 14:27:20 AWST 2019 ma-start: MA started with Process ID 18871
Mon May 13 14:27:23 AWST 2019 ma-start: no restart flag found, not restarting MA
Mon May 13 14:27:23 AWST 2019 ma-start: MA done
Mon May 13 16:25:25 AWST 2019 ma-start: running stop extensions...
Mon May 13 16:25:25 AWST 2019 ma.stop: No PID file found. Java process not stopped...
Mon May 13 16:25:29 AWST 2019 ma-start: running init extensions...
Mon May 13 16:25:29 AWST 2019 ma-start: running start extensions...
Mon May 13 16:25:29 AWST 2019 ma-start: starting MA
Mon May 13 16:25:29 AWST 2019 ma-start: MA started with Process ID 25895
Mon May 13 16:25:32 AWST 2019 ma-start: no restart flag found, not restarting MA
Mon May 13 16:25:32 AWST 2019 ma-start: MA done
<p dir="auto">My ma.log is very sizable. 1400kB to be exact which makes it too large to put in this post. Did you want me to try and cut it down to a more manageable size?</p>
]]></description><link>https://forum.mango-os.com/post/22084</link><guid isPermaLink="true">https://forum.mango-os.com/post/22084</guid><dc:creator><![CDATA[PSpivey]]></dc:creator><pubDate>Mon, 13 May 2019 08:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Mon, 13 May 2019 08:15:14 GMT]]></title><description><![CDATA[<p dir="auto">can you paste your ma.log file and ma-script.log files here in a  <code>code</code> element after you have tried to restart it.</p>
<p dir="auto">Also, can you make sure that your memory-small,sh is executable?</p>
]]></description><link>https://forum.mango-os.com/post/22083</link><guid isPermaLink="true">https://forum.mango-os.com/post/22083</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 13 May 2019 08:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Mon, 13 May 2019 06:20:54 GMT]]></title><description><![CDATA[<p dir="auto">The MangoES is using core version 2.7.10 according to MA_HOME/lib.<br />
The folder MA_HOME/bin/ext-enabled is not missing and contains one script posted below.<br />
<img src="https://camo.nodebb.org/4fe01d5ccdf4b9d7eb6e359d3ed6ebe78a228e09?url=https%3A%2F%2Fi.imgur.com%2FA1iUZro.png" alt="0_1557728986993_b5acb902-57de-4228-b7f7-221904801294-image.png" class=" img-fluid img-markdown" /><br />
Any help?</p>
]]></description><link>https://forum.mango-os.com/post/22081</link><guid isPermaLink="true">https://forum.mango-os.com/post/22081</guid><dc:creator><![CDATA[PSpivey]]></dc:creator><pubDate>Mon, 13 May 2019 06:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Fri, 10 May 2019 17:16:40 GMT]]></title><description><![CDATA[<p dir="auto">I took a look at the source for <a href="http://ma-start.sh" rel="nofollow ugc">ma-start.sh</a> and it looks like it is trying to execute one of your extension from MA_HOME/bin/ext-enabled</p>
<p dir="auto">Perhaps that folder is missing, or has a corrupt file in it?</p>
]]></description><link>https://forum.mango-os.com/post/22073</link><guid isPermaLink="true">https://forum.mango-os.com/post/22073</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 10 May 2019 17:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Fri, 10 May 2019 17:14:52 GMT]]></title><description><![CDATA[<p dir="auto">Look at the name of the mango-[version].jar file in MA_HOME/lib. All recent versions of Mango include the version in that filename.</p>
]]></description><link>https://forum.mango-os.com/post/22072</link><guid isPermaLink="true">https://forum.mango-os.com/post/22072</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 10 May 2019 17:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Fri, 10 May 2019 03:47:02 GMT]]></title><description><![CDATA[<p dir="auto">I believe it's a V3 mango. I don't know what version of the core is being used. Is there a way to find out that from the back end?</p>
]]></description><link>https://forum.mango-os.com/post/22056</link><guid isPermaLink="true">https://forum.mango-os.com/post/22056</guid><dc:creator><![CDATA[PSpivey]]></dc:creator><pubDate>Fri, 10 May 2019 03:47:02 GMT</pubDate></item><item><title><![CDATA[Reply to No restart flag found, not restarting MA on Fri, 10 May 2019 03:16:56 GMT]]></title><description><![CDATA[<p dir="auto">What version of Mango are you trying to start.  That error looks like a hardware/os problem but knowing the version will help us find the right version of the startup script and from that the command on line 142.</p>
]]></description><link>https://forum.mango-os.com/post/22055</link><guid isPermaLink="true">https://forum.mango-os.com/post/22055</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Fri, 10 May 2019 03:16:56 GMT</pubDate></item></channel></rss>
