<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release Notes for 3.6.0-beta.3]]></title><description><![CDATA[<p dir="auto"><strong>core</strong> - Version 3.6.0</p>
<ul>
<li>Add missing convenience methods for getStats in Numeric and Alphanumeric script context points, third argument cache defaults false</li>
<li>Fixing debug logging in serial server input stream</li>
<li>Fix quantize data source poll and interval logging delays to avoid a currentTimeMillis() call</li>
<li>Add IP whitelist for virtual serial server sockets</li>
<li>Add debug log of incoming IPs on virtual serial server sockets</li>
<li>Improve handling of exception in data point listeners on initialize or terminate when only 1 listener is present</li>
<li>Modify email FTL Model for events, references to evt.alarmLevel in overridden templates should be changed to evt.alarmLevel.value()</li>
<li>Expose connection description and data source type translations in Data Source REST models</li>
<li>Add SMTP mail server connection/read/write timeout system setting</li>
<li>Fixing bug in process log that would not allow Error level logging for Mango Java Script</li>
<li>Changing Java Script Script Permissions from multiple permissions groups into a single group.  Note the REST models will reflect this.</li>
<li>Fix bug in legacy UI data source edit page that would not track a new data source?s ID after initial save, this would effect some data source tools</li>
<li>Adding validation to User to notify when creating a user with a username that is already used</li>
<li>Restricting non-admin users from executing JavaScript that has access to Java classes. This means for anything with Script Permissions the ?superadmin? permission must be present to access any Java Classes.</li>
<li>Add publisher control to RuntimeManager script utility</li>
<li>Upgrade Apache POI to 4.0.1 for Excel file generation</li>
<li>Upgrade Spring Framework to 5.1.5</li>
<li>Fix bug in RealTimeDataPointValueCache where tags/permissions could become out of sync with the database during point save/restarts</li>
<li>Fix bug in RealTimeDataPointValueCache where the data source permission was not checked to see if a User has access to see the point</li>
<li>Users cannot update their password to the same thing</li>
<li>IMPORTANT a default role has been added named user.  This means that if anything has a permission of user added to it any valid User can access it.  This also means that the role of user is pointless to add to any User because they inherently have it.</li>
<li>No longer store or export/import units with Text Renderer, the data point?s unit is always used</li>
<li>Fix bug where Script Permissions could have ended up with spaces on the ends</li>
<li>Cleanup Data Point Attribute publishing api</li>
<li>Removing log messages from startup/shutdown status api</li>
<li>Improve error handling for legacy data point, data source, publisher controllers</li>
<li>Ensure text renderers are always validated for data points</li>
<li>Add missing EventInstanceWrapper to email handler scripts</li>
<li>Bugfix for NPE in deprecated EmailEventHandlerModel in REST v1, suggest using v2 endpoints instead</li>
<li>ScriptPermissions? four permissions types unified into one permission set via taking the union of the four permissions sets.</li>
<li>Make JSON Imports more robust when importing invalid/missing values for fields</li>
<li>adding env properties serial.port.linux.readPeriods and serial.port.linux.readPeriodType to allow adjusting the rate at which the port is polled for incoming data in Linux</li>
<li>adding env property serial.port.eventQueueSize to limit the size of the queue to hold generated serial port events before they are processed</li>
<li>Purge RX/TX buffers on serial port immediately after opening it</li>
<li>Event detector XID length expanded to 100 chars</li>
<li>Add subject property to Email Event Handler to allow choosing what goes into the email subject.  All Email event handlers are upgraded to keep legacy operation.  i.e. if you previously had a name/alias set then the subject will include that</li>
<li>Adding an HTTP session timeout override setting to the User</li>
<li>Improve performance for publishing data point attributes i.e. Reliability</li>
<li>Show last password change date when editing a user</li>
<li>Show last login date when editing a user</li>
<li>File store definitions which do not supply permissions and no permissions definitions are found default to admin only</li>
<li>Change default admin email address to <a href="mailto:admin@mango.example.com" rel="nofollow ugc">admin@mango.example.com</a></li>
<li>Expose char(1) columns in database as boolean for RQL queries, i.e. /rest/v1/users?disabled=false or /rest/v1/users?disabled=N</li>
<li>Adding settable column to data points table, this allows for RQL queries on the settable field of a data point locator</li>
<li>Upgrade commons-io library to version 2.6</li>
<li>Upgrade javax.mail library to version 1.6.2 and use com.sun.mail implementation</li>
<li>Upgrade apache-poi library to version 4.0.1 for Excel file support</li>
<li>Upgrade commons-beanutils library to version 1.9.3</li>
<li>Fix bug in RQL queries over in-memory lists where not having a sign on the sort parameter would cause the query to fail</li>
<li>Fix bug in RQL queries where empty IN clause would fail on MySQL</li>
<li>Fix bug introduced in 3.6.0-beta.1 where the JavaScript POINTS global variable was an ever-growing list of strings added to at each run of the script</li>
</ul>
<p dir="auto"><strong>advancedComponents</strong> - Version 3.6.0</p>
<ul>
<li>Upgraded to work with core version 3.6.x</li>
</ul>
<p dir="auto"><strong>advancedScheduler</strong> - Version 3.6.0</p>
<ul>
<li>Bugfix for wildcard rules that had a day of month set that could be greater than the smallest month (28 days in Feb) producing invalid dates</li>
</ul>
<p dir="auto"><strong>asciiFile</strong> - Version 3.6.0</p>
<ul>
<li>Add REST endpoint to test if a file exists and is readable by the data source</li>
<li>Add REST endpoint to validate example ASCII as per the data source settings</li>
<li>Change regex validation to allow an empty catch group for point identifier</li>
</ul>
<p dir="auto"><strong>BACnet</strong> - Version 3.6.0</p>
<ul>
<li>Adding REST endpoints to manage Local Devices</li>
<li>Fix misspelled IpLocalDeviceConfig.foreignBBMDAddres REST model property to foreignBBMDAddress</li>
<li>Adding locking to ensure concurrent edits of Local Devices is thread safe</li>
<li>Adding WhoIs request to REST api bacnet/bulk endpoint</li>
<li>Adding option to make BACnet read requests individually without using Mango BACnet property cache via REST api</li>
<li>Fix bug in publisher where Multistate points with a Multistate Renderer would not work</li>
<li>Add endpoint to get possible properties of an Object and the Mango data types that support them GET rest/v2/bacnet/object-properties/</li>
<li>Improve validation message when creating duplicate local devices when they are on the same comm port or IP address</li>
<li>Expanding data source support for all BACnet primitive data types, raise event when BACnet data type cannot be converted to a Mango data type during runtime.</li>
<li>Adding option to re-use address for IP Local Devices</li>
</ul>
<p dir="auto"><strong>brewersdashboard</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>cloudConnect</strong> - Version 3.6.0</p>
<ul>
<li>Upgrade Apache MINA SSHD library to v2.2.0</li>
<li>Improved connection reliability</li>
<li>Ability to forward remote ports from server to client</li>
<li>Ability to forward additional local ports from client to server</li>
<li>Ability to  open a port for SOCKS proxying over the SSH tunnel</li>
</ul>
<p dir="auto"><strong>controlcore</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>dashboardDesigner</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>dataFile</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>dataImport</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>dataPointDetailsView</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>deviceConfig</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>dnp3</strong> - Version 3.6.0</p>
<ul>
<li>Remove un-used static poll periods setting</li>
<li>Change JSON import/export to use updatePeriods and updatePeriodType instead of rbePollPeriods and eventsPeriodType</li>
<li>Improve data point validation</li>
</ul>
<p dir="auto"><strong>egauge</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>envcands</strong> - Version 3.6.0</p>
<ul>
<li>Bugfix where Parse Exception alarm level was being exported in JSON configuration as No Temperature Data</li>
<li>Bugfix for legacy UI where selecting ?weather? for the point attribute would not work.</li>
<li>Bugfix for using correct data start time, previously the month requested was one more than expected, i.e. May in the UI would request June data</li>
</ul>
<p dir="auto"><strong>excelReports</strong> - Version 3.6.0</p>
<ul>
<li>Moving /v1/excel-report-templates/upload to /v2/excel-report-templates/upload</li>
<li>Expose reportInstance object to post processing script under var name ?report?</li>
<li>Make drop downs for named ranges searchable</li>
<li>Improve validation messages for time periods</li>
</ul>
<p dir="auto"><strong>galil</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>graphicalViews</strong> - Version 3.6.0</p>
<ul>
<li>Remove ?user? role from default image upload permissions</li>
</ul>
<p dir="auto"><strong>Haystack</strong> - Version 3.6.0</p>
<ul>
<li>Upgrade to use 3.0.2 Haystack-Java library to ensure Basic Auth is always attempted</li>
<li>Adding permission definition to restrict access to Haystack server at /haystack</li>
<li>Added support to the new UI data sources page</li>
</ul>
<p dir="auto"><strong>http</strong> - Version 3.6.0</p>
<ul>
<li>Adding REST tools to test/validate points and data sources</li>
<li>Ensuring a time is set to non-zero when receiving GET and POST requests</li>
<li>Adding validation endpoints to make requests and validate point locator settings</li>
<li>Fix bug where JSON Receiver was exporting its recieveType field as an integer and not Export Code</li>
<li>Adding url and overlayPoints to point locator REST model</li>
</ul>
<p dir="auto"><strong>internal</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>jmxds</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>jsonFileImport</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>log4jDS</strong> - Version 3.6.0</p>
<ul>
<li>Adding validate regex REST endpoint</li>
<li>Adding get test message REST endpoint</li>
<li>IMPORTANT, we are trimming the messages before parsing so all the newlines will be removed from the messages.  Check your pattern matching.</li>
</ul>
<p dir="auto"><strong>log4JReset</strong> - Version 3.6.0</p>
<ul>
<li>Moving log4jUtil action REST endpoint to /rest/v2/system-actions/log4jUtil</li>
<li>Add to new UI</li>
</ul>
<p dir="auto"><strong>loggingConsole</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>maintenanceEvents</strong> - Version 3.6.0</p>
<ul>
<li>improve new UI</li>
</ul>
<p dir="auto"><strong>mangoApi</strong> - Version 3.6.0</p>
<ul>
<li>Add LOGGED as point value websocket event type</li>
<li>Fix event type in returned messages for BACKDATE point value websocket events</li>
<li>Fix NPE from sending a notification while a point was terminating in point value websocket</li>
<li>Add /rest/v2/server/serial-ports endpoint to allow getting serial ports</li>
<li>Add /rest/v2/server/cors-settings endpoint to allow admins to see the settings</li>
<li>Add /rest/v2/system-actions endpoints to use websockets</li>
<li>Modify /rest/v2/virtual-serial-ports/ endpoint to be an RQL query with items and total as response body</li>
<li>Add smtpSessionLog member to errors reported from /v2/server/email/test endpoint</li>
<li>Removing /v2/script/test endpoint, replaced with new format at /v2/script/validate</li>
<li>Changed /v2/script/run endpoint with new Body and Response objects that contain more information</li>
<li>Removed units from text renderer models, always use unit from data point</li>
<li>Restrict stack trace and cause about from last exception for a User that is non-admin</li>
<li>Add data source edit roles into data point models</li>
<li>Add granted permissions to user models</li>
<li>Add JSON export endpoints for data points at /v2/data-points/export/{xids}</li>
<li>Add JSON export endpoints for data source at /v2/data-sources/export/{xid}</li>
<li>Ensure Data Point v2 model requires a purge period if purge override is true the model</li>
<li>Fix bug where point locators were not returned in the reference fields for event types returned by v2/event-types</li>
<li>Expose Data Point v2 model into the v1 context for legacy support</li>
</ul>
<p dir="auto"><strong>mangoESConfiguration</strong> - Version 3.6.0</p>
<ul>
<li>Upgrade jmdns library to 3.5.5 to improve shutdown time</li>
<li>Adding <a href="http://mango-browser.sh" rel="nofollow ugc">mango-browser.sh</a> script to run manually and open GUI application to discover Mango instances on your network</li>
</ul>
<p dir="auto"><strong>MangoIOTools</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>mangoNoSqlDatabase</strong> - Version 3.6.0</p>
<ul>
<li>Adding HTML5 UI for tools to import data/restore</li>
</ul>
<p dir="auto"><strong>mangoUI</strong> - Version 3.6.0</p>
<ul>
<li>Add ?Data sources? page for creating/updating/deleting data sources and data points. Note: not all data source types supported yet.</li>
<li>Update ?Bulk data point edit? page to use same data point editor dialog as ?Data sources? page</li>
<li>Add ?Event handlers? page for creating/updating/deleting event handlers</li>
<li>Add dialog for for creating/updating/deleting event detectors (opened from ?Data point details? or ?Data sources? page)</li>
<li>Clean up menu, moved some menu items to ?Utilities? section of ?Admin home?</li>
<li>Add more help pages and update existing help content</li>
<li>Ability to open sidebar help in new window</li>
<li>Add HTTP server system settings</li>
<li>Ability to set session expiration per user on the ?Users? page</li>
<li>Better feedback when saving system settings</li>
<li>Add ma-data-point-editor component for creating/updating/deleting data points</li>
<li>Add ma-data-source-editor component for creating/updating/deleting data sources</li>
<li>Add ma-data-point-tags-editor component for editing tags on data points</li>
<li>Add ma-color-picker component for showing a color preview and color picker dialog</li>
<li>Add ma-duration-editor component for editing durations in REST models</li>
<li>Add ma-email-recipients component for editing lists of emails recipients in REST models</li>
<li>Add ma-data-source-status component for displaying data source status information</li>
<li>Add ma-event-handler-checklist component for displaying and selecting event handlers</li>
<li>Add ma-event-handler-list component for displaying a list of event handlers</li>
<li>Add ma-event-handler-select component for displaying a drop down list of event handlers</li>
<li>Add ma-event-type-list component for displaying a tree view of event types</li>
<li>Add ma-mailing-list-list component for displaying a list of mailing lists</li>
<li>Add ma-mailing-list-select component for displaying a drop down of mailing lists</li>
<li>Add ma-mailing-list-setup component for creating/updating/deleting mailing lists</li>
<li>Add ma-purge-point-values component for purging point values</li>
<li>Add ma-script-context component editing scripting contexts</li>
<li>Add ma-scriping-editor component for editing backend JS scripts</li>
<li>Add ma-tree-view component for displaying arbitrary tree views</li>
<li>Add ma-unit-list component for displaying drop down of units which are available for data points</li>
<li>Add ma-virtual-serial-port-list component for displaying a list of virtual serial ports</li>
<li>Add ma-virtual-serial-port-select component for displaying a drop down of virtual serial ports</li>
<li>Add ma-dialog component for easily creating pop-up dialogs from the markup</li>
<li>Remove constants from ngMango module ? MA_INSERT_CSS, MA_ROLLUP_TYPES, MA_DATE_TIME_FORMATS, MA_TIME_PERIOD_TYPES, MA_CHART_TYPES, MA_EVENT_LINK_INFO, and MA_RELATIVE_DATE_TYPES</li>
<li>Remove constant from ngMangoServices module ? MA_EVENT_HANDLER_TYPES</li>
<li>Add constants to ngMangoServices module ? MA_DATE_TIME_FORMATS, MA_TIME_PERIOD_TYPES, MA_CHART_TYPES, MA_SIMPLIFY_TYPES, and MA_EVENT_LINK_INFO</li>
<li>Data point on ?Data point details? is kept up to date via WebSocket</li>
<li>Update data source drop down menus via WebSocket</li>
<li>Add ?LED indicator? example</li>
<li>Update license page, add checkboxes for checking for upgrades and sending usage information</li>
<li>Fix bugs in cron expression component</li>
<li>Replace uses of jQuery find() with maFind()</li>
<li>Replace uses of jQuery extend() with maUtil.deepMerge()</li>
<li>Update JavaScript libraries to latest versions</li>
<li>Remove <a href="http://plot.ly" rel="nofollow ugc">plot.ly</a> JS library and component</li>
<li>Various bug fixes and improvements</li>
</ul>
<p dir="auto"><strong>mbus</strong> - Version 3.6.0</p>
<ul>
<li>Adding REST endpoints for scan tool</li>
</ul>
<p dir="auto"><strong>measurlogicDTSCell</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>meta</strong> - Version 3.6.0</p>
<ul>
<li>Change ScriptPermissions in REST model to Set&lt;String&gt;</li>
<li>Add REST endpoints for data source tools</li>
<li>Change JSON export of script permissions to an array of roles, legacy format supported for import</li>
</ul>
<p dir="auto"><strong>modbus</strong> - Version 3.6.0</p>
<ul>
<li>Modify v1 data source REST model to use Enums for serial settings</li>
<li>Remove unsupported ?concurrency? modes from serial data source</li>
</ul>
<p dir="auto"><strong>mqttClientDataSource</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>onewire</strong> - Version 3.6.0</p>
<ul>
<li>Combine REST v1 model rescanPeriodType and rescanPeriods fields into rescanPeriod</li>
<li>Add REST tools to read network</li>
</ul>
<p dir="auto"><strong>opcda</strong> - Version 3.6.0</p>
<ul>
<li>Adding REST endpoints for tools</li>
</ul>
<p dir="auto"><strong>openv4j</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>pachube</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>pakbus</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>persistent</strong> - Version 3.6.0</p>
<ul>
<li>Expose settable as configurable property on received points</li>
<li>More reliably attribute publishing on failed attempts to publish point attributes</li>
</ul>
<p dir="auto"><strong>pid</strong> - Version 3.6.0</p>
<ul>
<li>Fix NaN being computed when I is set to 0</li>
<li>Add demo configuration to explore at web/demo-configuration.json</li>
</ul>
<p dir="auto"><strong>pointLinks</strong> - Version 3.6.0</p>
<ul>
<li>Combining all 3 script permission group into a single permission group used globally throughout the script</li>
</ul>
<p dir="auto"><strong>pop3</strong> - Version 3.6.0</p>
<ul>
<li>Adding REST tools to validate data point settings</li>
</ul>
<p dir="auto"><strong>reports</strong> - Version 3.6.0</p>
<ul>
<li>Add audit event tracking to non REST initiated changes to Report configurations</li>
</ul>
<p dir="auto"><strong>scheduledEvents</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>scripting</strong> - Version 3.6.0</p>
<ul>
<li>Using new MangoJavaScriptService to standardize how all scripts are executed, no changes in how the scripts function should be observed</li>
<li>Fix bug where Context Change data source settings was exported and imported as context update</li>
<li>Add new property to data source for ?polling? so we can now use an update period or cron pattern to poll</li>
</ul>
<p dir="auto"><strong>serial</strong> - Version 3.6.0</p>
<ul>
<li>Modify v1 data source model to use Enums for serial settings</li>
</ul>
<p dir="auto"><strong>slackPublisher</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>snmp</strong> - Version 3.6.0</p>
<ul>
<li>Added permissions definitions for filestore read / write</li>
</ul>
<p dir="auto"><strong>sqlConsole</strong> - Version 3.6.0</p>
<ul>
<li>Add CSV download button</li>
<li>Separate inputs for query and update</li>
<li>Store last used queries in local storage</li>
</ul>
<p dir="auto"><strong>sqlds</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>ssh</strong> - Version 3.6.0</p>
<ul>
<li>Fix bug where the JSON export of Point Write Exception was using Point Read Exception</li>
</ul>
<p dir="auto"><strong>sstGlobalScripts</strong> - Version 3.6.0</p>
<ul>
<li>New AngularJS UI</li>
</ul>
<p dir="auto"><strong>sstGraphics</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>sstTheme</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>TCPIP</strong> - Version 3.6.0</p>
<ul>
<li>Bugfix where Point Write Event alarm levels were being exported as Point Read Event alarm levels</li>
</ul>
<p dir="auto"><strong>templateConfig</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>twilio</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>virtualDS</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>vmstat</strong> - Version 3.6.0</p>
<ul>
</ul>
<p dir="auto"><strong>watchlists</strong> - Version 3.6.0</p>
<ul>
<li>Bugfix to allow a user to save their own watchlist regardless of edit permissions</li>
<li>Bugfix for static point watchlists not returning point locator in REST request</li>
</ul>
<p dir="auto"><strong>zwave</strong> - Version 3.6.0</p>
<ul>
</ul>
]]></description><link>https://forum.mango-os.com/topic/4176/release-notes-for-3-6-0-beta-3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:07:19 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4176.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Apr 2019 17:25:54 GMT</pubDate><ttl>60</ttl></channel></rss>
