<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Video Player]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I have a video that I want to start and stop at certain points based on values from data points. How best would I do that?</p>
<p dir="auto">In dashboard designer, I can load my video and load my data points but not sure how to link the two together so the video will stop at either a certain time index or certain frame based on a value from my data point.<br />
Was also having trouble finding detail component documentation. Can someone point me to where I should look?</p>
<p dir="auto">Jim.</p>
]]></description><link>https://forum.mango-os.com/topic/4100/video-player</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 19:29:45 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4100.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Mar 2019 21:38:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Video Player on Fri, 15 Mar 2019 15:55:49 GMT]]></title><description><![CDATA[<p dir="auto">Ok I did that and will recheck to see where I missed the documentation.</p>
<p dir="auto">I will have a look also at the user module. That seems like a good candidate.</p>
<p dir="auto">Thanks for the pointer</p>
]]></description><link>https://forum.mango-os.com/post/21538</link><guid isPermaLink="true">https://forum.mango-os.com/post/21538</guid><dc:creator><![CDATA[realmooseman]]></dc:creator><pubDate>Fri, 15 Mar 2019 15:55:49 GMT</pubDate></item><item><title><![CDATA[Reply to Video Player on Thu, 14 Mar 2019 16:04:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/realmooseman" aria-label="Profile: realmooseman">@<bdi>realmooseman</bdi></a> have you enabled the API documentation menu item? See <a href="https://help.infiniteautomation.com/editing-the-menu" rel="nofollow ugc">https://help.infiniteautomation.com/editing-the-menu</a></p>
<p dir="auto">There are no components that help you control a video. You will probably have to use a user module to do so - <a href="https://help.infiniteautomation.com/getting-started-with-a-user-module" rel="nofollow ugc">https://help.infiniteautomation.com/getting-started-with-a-user-module</a></p>
<p dir="auto">I would suggest creating a component which contains a <code>&lt;video&gt;</code> element and takes a point value as an input binding. Let me know if you need more direction.</p>
]]></description><link>https://forum.mango-os.com/post/21532</link><guid isPermaLink="true">https://forum.mango-os.com/post/21532</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 14 Mar 2019 16:04:45 GMT</pubDate></item></channel></rss>
