<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unexpected date/time display behavior]]></title><description><![CDATA[<p dir="auto">We are querying some epoch times via Modbus/tcp, and are experiencing some unexpected behavior:</p>
<p dir="auto">modbus register (a double word, 2 input registers) contains: 1551356992;<br />
data point as 4 byte signed integer, interprets the value differently as 1551302656 with plain formatting, but displays "Jan 18, 1970 14:55:02" when using date/time formatting;</p>
<p dir="auto">further, another register contains the value 0; data point interprets correctly as zero, but displays "Dec 31, 1969 16:00:00".</p>
<p dir="auto">No doubt serious pilot error here, but I'm at a loss to make any sense of it.</p>
]]></description><link>https://forum.mango-os.com/topic/4088/unexpected-date-time-display-behavior</link><generator>RSS for Node</generator><lastBuildDate>Thu, 17 Sep 2026 01:21:04 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4088.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Feb 2019 20:23:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unexpected date/time display behavior on Fri, 01 Mar 2019 14:06:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">to your third point, actually on GMT-08:00, which does explain that!</p>
<p dir="auto">Wait, there aren't 22 hours in a day? Whoops :P</p>
<p dir="auto">The offsets are right - still trying to sort why the epoch value is off by a couple of days +/-. Will keep mucking about here.</p>
<p dir="auto">How did you know the value in the register before reading it? Perhaps it's not sync'ed to the right time. The bit banging to decode registers into data types can be found here, but it's quite unlikely there's an issue there: <a href="https://github.com/infiniteautomation/modbus4j/blob/master/src/com/serotonin/modbus4j/locator/NumericLocator.java" rel="nofollow ugc">https://github.com/infiniteautomation/modbus4j/blob/master/src/com/serotonin/modbus4j/locator/NumericLocator.java</a></p>
]]></description><link>https://forum.mango-os.com/post/21477</link><guid isPermaLink="true">https://forum.mango-os.com/post/21477</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 01 Mar 2019 14:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to Unexpected date/time display behavior on Thu, 28 Feb 2019 21:38:28 GMT]]></title><description><![CDATA[<p dir="auto">@bullitbd said in <a href="/post/21471">Unexpected date/time display behavior</a>:</p>
<p dir="auto">Jan 18, 1970 14:55:02</p>
<p dir="auto">Thanks for the quick response, Phil. Right you are on number 2...<br />
]]></description><link>https://forum.mango-os.com/post/21476</link><guid isPermaLink="true">https://forum.mango-os.com/post/21476</guid><dc:creator><![CDATA[BobDay]]></dc:creator><pubDate>Thu, 28 Feb 2019 21:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to Unexpected date/time display behavior on Thu, 28 Feb 2019 20:55:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi bullitbd,</p>
<p dir="auto">I'm not understanding.</p>
<p dir="auto">data point as 4 byte signed integer, interprets the value differently as 1551302656 with plain formatting</p>
<p dir="auto">Meaning this is the value the point is reading? Have you checked to see if perhaps the register offsets are off by one (and then also check the 4 byte signed integer swapped types at those offsets)? Mango is 0-offset, but some begin their offsets at 1.</p>
<p dir="auto">but displays "Jan 18, 1970 14:55:02" when using date/time formatting;</p>
<p dir="auto">That's because it's expecting a time value in epoch milliseconds, while a four byte integer can only really provide epoch time in seconds. So, put a multiplier of 1000 on the point, or set the conversion exponent on the time renderer to 3.</p>
<p dir="auto">That would suggest to me that you're at GMT-06:00 and have a time text renderer on the point.</p>
]]></description><link>https://forum.mango-os.com/post/21474</link><guid isPermaLink="true">https://forum.mango-os.com/post/21474</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 28 Feb 2019 20:55:00 GMT</pubDate></item></channel></rss>
