<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Re-creating Slave Points]]></title><description><![CDATA[<p dir="auto">I had deleted the slave points from a modbus data source; Will this method work to recreate them: Create a new duplicate data source with a new xid and export the slaves to JSON then change the DS xid to the original and re-importing the points. Would this work to add them back into the data source?</p>
]]></description><link>https://forum.mango-os.com/topic/4029/re-creating-slave-points</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 12:25:57 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/4029.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Jan 2019 02:54:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Re-creating Slave Points on Tue, 05 Feb 2019 04:38:59 GMT]]></title><description><![CDATA[<p dir="auto">strange I tested it before I posted is your data source modbusIP or modbus serial ? Make sure you have a binary bit data point on that data source with the slave ID that you want to be monitored.</p>
]]></description><link>https://forum.mango-os.com/post/21266</link><guid isPermaLink="true">https://forum.mango-os.com/post/21266</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Tue, 05 Feb 2019 04:38:59 GMT</pubDate></item><item><title><![CDATA[Reply to Re-creating Slave Points on Tue, 05 Feb 2019 00:45:41 GMT]]></title><description><![CDATA[<p dir="auto">I tried unchecking the modbus IP Data Source create slave box;  saving the data source and rechecking the option and saving again.  I also did it after disabling and re-enabling. Sadly No slave points were created from this method..</p>
]]></description><link>https://forum.mango-os.com/post/21263</link><guid isPermaLink="true">https://forum.mango-os.com/post/21263</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Tue, 05 Feb 2019 00:45:41 GMT</pubDate></item><item><title><![CDATA[Reply to Re-creating Slave Points on Thu, 24 Jan 2019 13:38:53 GMT]]></title><description><![CDATA[<p dir="auto">I believe your method will work, havn't tested it but I dont see why it will not work...<br />
Try un-check the create slave monitor checkbox then save the data source.<br />
check it again and then save again.  Mine recreated it when I did this.</p>
]]></description><link>https://forum.mango-os.com/post/21128</link><guid isPermaLink="true">https://forum.mango-os.com/post/21128</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 24 Jan 2019 13:38:53 GMT</pubDate></item></channel></rss>
