<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removing a Bacnet Object present value property]]></title><description><![CDATA[<p dir="auto">Matthew,</p>
<p dir="auto">I'm trying to publish sensor values via BACnet.  There are occasions when I cannot contact the sensor and I want to remove the current value for the bacnet object.</p>
<p dir="auto">I had tried to remove the present value property of the bacnet object and an exception was promptly thrown.  I traced this back to the fact that the present value property is required.  Ok, so I looked at the other primitive data types and saw Null.  So my next thought was to set the present value to a Null value however the BACnet code doesn't like that for analog inputs.</p>
<p dir="auto">Is there a concept of an input not having a present value in BACnet?</p>
<p dir="auto">As always, thanks for the help.</p>
<p dir="auto">Fred</p>
]]></description><link>https://forum.mango-os.com/topic/393/removing-a-bacnet-object-present-value-property</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 14:22:47 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/393.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 May 2010 18:52:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removing a Bacnet Object present value property on Thu, 13 May 2010 20:53:35 GMT]]></title><description><![CDATA[<p dir="auto">Ah, I got it.  Similar to the quality property in OPC.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/3752</link><guid isPermaLink="true">https://forum.mango-os.com/post/3752</guid><dc:creator><![CDATA[Fred]]></dc:creator><pubDate>Thu, 13 May 2010 20:53:35 GMT</pubDate></item><item><title><![CDATA[Reply to Removing a Bacnet Object present value property on Thu, 13 May 2010 19:43:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi Fred,</p>
<p dir="auto">The reliability property can be used to indicate such conditions.</p>
]]></description><link>https://forum.mango-os.com/post/3750</link><guid isPermaLink="true">https://forum.mango-os.com/post/3750</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 13 May 2010 19:43:23 GMT</pubDate></item></channel></rss>
