<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 3.5.1 Released!]]></title><description><![CDATA[<p dir="auto"><strong>core</strong> - Version 3.5.1</p>
<ul>
<li>Fix bug in Event Manager’s Event Listeners where listers were getting lost and not being removed when necessary</li>
<li>Fix bug where generic validation failure messages did not make it into the REST response</li>
<li>Relax requirement for email event handlers to have active/inactive/escalation recipients.  If no recipients exist then no email is sent.</li>
<li>Fix backup work items race conditions in system settings listeners</li>
<li>Publishers now publish attribute changes if configured to during snapshot send</li>
<li>Fix bug in very narrow case where if an exception occurred in a streamed REST query, failing to close a result set could leave a database connection zombied</li>
<li>Fix bug in Module.webPath()</li>
<li>Fix for returning error messages when switching user</li>
<li>Add edit-ui-pages as a default permission for creating JSON data items</li>
<li>Fix synchronization issue in virtual server serial sockets.</li>
<li>Ensure Global Scripts are imported first so that Meta point and Scripting data sources that are imported at the same time can use the scripts</li>
<li>Allow emails event handlers to run without recipients to allow thier scripts to execute even though no email is sent</li>
<li>Fix bug where when only 1 User is logged in they recieve Audit and Do Not Log Events in the UI</li>
<li>Fix for NPE getting runtime context during startup</li>
</ul>
]]></description><link>https://forum.mango-os.com/topic/3839/core-3-5-1-released</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 03:40:57 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3839.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Oct 2018 22:14:56 GMT</pubDate><ttl>60</ttl></channel></rss>
