<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Chart&#x27;s not working]]></title><description><![CDATA[<p dir="auto">Hello, I have a question. I have 2 MangoES and I have on them same data source and the same custom dashboard which has some pop-ups and in every pop-up are some graphics. The graphics are from the amchart.</p>
<p dir="auto">On one of the MangoES all the graphics works on the other one the graphics work only if I hide three of the graphic points.</p>
<p dir="auto">I know it's really weird that is happening this but I want to know if someone has some idea about that.</p>
]]></description><link>https://forum.mango-os.com/topic/3705/chart-s-not-working</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 23:45:28 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3705.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Aug 2018 11:28:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Chart&#x27;s not working on Tue, 21 Aug 2018 13:57:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Hi, I've disconnected the other MangoES from the network, now I have only one that is getting data from the PLC, and I let it to run a while and I don't have any discarded polls.</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.mango-os.com/post/19619</link><guid isPermaLink="true">https://forum.mango-os.com/post/19619</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Tue, 21 Aug 2018 13:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 17 Aug 2018 17:12:21 GMT]]></title><description><![CDATA[<p dir="auto">That sounds like something might be getting stuck somewhere, maybe? Can you go to the <code>/rest/v1/threads?asFile=true&amp;stackDepth=40</code> API endpoint a few time when you are experiencing the aborted polls and email the resulting json files to <a href="mailto:support@infiniteautomation.com" rel="nofollow ugc">support@infiniteautomation.com</a> ?</p>
<p dir="auto">If you expand the runtime status of the data source (above the properties on the data source edit page), do you see it having a completed poll recently? What is the typical poll time?</p>
]]></description><link>https://forum.mango-os.com/post/19571</link><guid isPermaLink="true">https://forum.mango-os.com/post/19571</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 17 Aug 2018 17:12:21 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 17 Aug 2018 09:39:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Yes, is reading the values when is not discarding the polls.</p>
<p dir="auto">I've noticed that if I change the Data Source XID, 6 minutes after I've changed the XID the Data Source is working and I have successful polls but after that I get only Discarded polls.</p>
]]></description><link>https://forum.mango-os.com/post/19566</link><guid isPermaLink="true">https://forum.mango-os.com/post/19566</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 17 Aug 2018 09:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 16 Aug 2018 15:43:54 GMT]]></title><description><![CDATA[<p dir="auto">Is it reading the values when it is not discarding the polls? Is it reliably the same device discarding the polls? If so I would encourage you check the wiring of the whole setup. If you disconnect the one that is not discarding polls, does anything change for the one that is?</p>
]]></description><link>https://forum.mango-os.com/post/19552</link><guid isPermaLink="true">https://forum.mango-os.com/post/19552</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 16 Aug 2018 15:43:54 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 16 Aug 2018 15:22:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Hi, I've made the changes in the /system_settings.shtm page, I changed the Device ID and the Data Source XID but I get a lot of discarded polls...</p>
<p dir="auto">Any idea why?</p>
]]></description><link>https://forum.mango-os.com/post/19551</link><guid isPermaLink="true">https://forum.mango-os.com/post/19551</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Thu, 16 Aug 2018 15:22:20 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 20:16:04 GMT]]></title><description><![CDATA[<p dir="auto">Did you fix the BACnet local device issue? You would do that on the /system_settings.shtm page in the BACnet Local Devices section. They should not have the same device ID.</p>
<p dir="auto">I believe DiagramCtrl is your code, yes? That array where you are taking an index of an then assessing the .value of something that is undefined, have you tried to examine how that array got populated? It's generally not sustainable for us to log into customer systems to troubleshoot customer code for free, but if you want to email the credentials to <a href="mailto:support@infiniteautomation.com" rel="nofollow ugc">support@infiniteautomation.com</a> we may choose to look without making any guarantees implied or otherwise.</p>
<p dir="auto">I suggest focusing on why the array you think has things in it does not. And fixing the BACnet local device IDs to be different. It doesn't sound like it's an issue with our code, since you can fetch the values from the tools we provided to get the data. It's in the array you've built that the issue is, it seems.</p>
]]></description><link>https://forum.mango-os.com/post/19513</link><guid isPermaLink="true">https://forum.mango-os.com/post/19513</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 10 Aug 2018 20:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 19:48:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> What do you suggest? I can give you access to both MangoES if you want to.</p>
]]></description><link>https://forum.mango-os.com/post/19512</link><guid isPermaLink="true">https://forum.mango-os.com/post/19512</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 10 Aug 2018 19:48:03 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 19:21:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Yes, it's literally the same PLC an they are on the same network.</p>
]]></description><link>https://forum.mango-os.com/post/19510</link><guid isPermaLink="true">https://forum.mango-os.com/post/19510</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 10 Aug 2018 19:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 16:23:14 GMT]]></title><description><![CDATA[<p dir="auto">So one of your data sets is much sparser?</p>
<p dir="auto">Literally the same PLC or just the exact same model of PLC? If literally the same PLC and they're on the same network it would be an error to have your local devices using the same local device ID. I'm not sure exactly how that would manifest, but I wouldn't think that it having sparse data is the answer to why it is null in your code, unless your setup requires there to be values to populate that array (not using a rollup that would have a value even without a value in the period? Not checking that values exist?). But, I would expect no issues polling the same BACnet IP device provided the Local Device on both ES's was configured to have a different device ID. As your data sources do have the same XID for the BACnet local device config, I guess this seems somewhat probable to be an issue.</p>
]]></description><link>https://forum.mango-os.com/post/19507</link><guid isPermaLink="true">https://forum.mango-os.com/post/19507</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 10 Aug 2018 16:23:14 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 16:01:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> I'm working a lot with the developer tools, and I clear the cash often.</p>
<p dir="auto">Just now I've noticed that on that MangoES where the points are not working properly I have a lot of discarded polls, 99%.</p>
<p dir="auto">Both MangoES get the data from the same PLC via BACnet IP, it's this a problem?</p>
]]></description><link>https://forum.mango-os.com/post/19505</link><guid isPermaLink="true">https://forum.mango-os.com/post/19505</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 10 Aug 2018 16:01:21 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 15:56:59 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">By downloading a failing series you are referring to that function to download the point data from the data_point_detail page, from mango interface? I've downloaded an excel document for the both points, from both MangoES, and I don't have any NaN or Infinity, only numbers.</p>
<p dir="auto">Yeah, or the watchlist or the new data point details page. Any place would have worked. The /data_points_details.shtm page does let you download the raw data.</p>
<p dir="auto">Hmm. Then let's consider maybe your browser has cached something on the unit that is not working. Have you tried clearing your site data? If you do a hard refresh or open the page with the developer tools open and 'disable cache when developer tools are open' checked, that would work too.</p>
<p dir="auto">After that there's really not a lot left than checking your Mango/overrides/ directory to see if anything is different. Or dropping a breakpoint where you're populating that array and stepping around to see which call is getting you different arrays.</p>
]]></description><link>https://forum.mango-os.com/post/19504</link><guid isPermaLink="true">https://forum.mango-os.com/post/19504</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 10 Aug 2018 15:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 15:50:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Yes, I'm logged in with admin.</p>
<p dir="auto">And to your last question, I don't have them in other pages, this is the only page where they are.</p>
]]></description><link>https://forum.mango-os.com/post/19503</link><guid isPermaLink="true">https://forum.mango-os.com/post/19503</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 10 Aug 2018 15:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 15:18:11 GMT]]></title><description><![CDATA[<p dir="auto">That JSON definitely does look to be the same. I assume you are an admin and it can't be a permissions issue with your other user not having 'test' permission.</p>
<p dir="auto">Also, will be a good idea to purge any point values to see if this is the reason? Maybe is there a value that is corrupted or something...</p>
<p dir="auto">That is a distinct possibility. You could check that without purging though, by downloading a failing series's data over the same range. I think NaN, Infinity, and -Infinity could pose problems for the chart. If the download fails then there could be something wrong with the data records and I would have expected the corruption to either fix itself or report a log message about it's inability to do so. If there is no log message and the download fails, you could restart Mango on the command line so that anything that could be going to stderr would be going to your console and try again, or just purge the point's data in that range and be done with it. Do these points chart properly on other pages?</p>
]]></description><link>https://forum.mango-os.com/post/19502</link><guid isPermaLink="true">https://forum.mango-os.com/post/19502</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 10 Aug 2018 15:18:11 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Fri, 10 Aug 2018 10:16:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> I will paste below the JSON code for the data sources:</p>
<p dir="auto">{<br />
"dataSources":[<br />
{<br />
"xid":"DS_4dc309c5-8959-488a-a217-c3d8e26b26e0",<br />
"name":"testBACnet",<br />
"enabled":true,<br />
"type":"BACnetIP",<br />
"alarmLevels":{<br />
"INITIALIZATION_EXCEPTION":"URGENT",<br />
"POLL_ABORTED":"URGENT",<br />
"DEVICE_EXCEPTION":"URGENT",<br />
"MESSAGE_EXCEPTION":"URGENT"<br />
},<br />
"purgeType":"YEARS",<br />
"updatePeriodType":"SECONDS",<br />
"covSubscriptionTimeoutMinutes":60,<br />
"localDeviceConfig":"68e37f9e-7aa7-431f-a9bb-fe2b5d77bce1",<br />
"updatePeriods":5,<br />
"editPermission":"",<br />
"purgeOverride":false,<br />
"purgePeriod":1<br />
}<br />
]<br />
}</p>
<p dir="auto">This is for the MangoES that works, and below I'll put for the one that don't work:</p>
{<br />
},<br />
}<br />
]<br />
}</p>
<p dir="auto">And below is the JSON code for the point:</p>
"dataPoints":[<br />
{<br />
"xid":"A100",<br />
"name":"CTWaterConsumption",<br />
"loggingType":"INTERVAL",<br />
"intervalLoggingPeriodType":"MINUTES",<br />
"intervalLoggingType":"INSTANT",<br />
"pointLocator":{<br />
"dataType":"NUMERIC",<br />
"objectType":"ANALOG_VALUE",<br />
"propertyIdentifier":"present-value",<br />
"objectInstanceNumber":100,<br />
"remoteDeviceInstanceNumber":140,<br />
"settable":false,<br />
"useCovSubscription":false,<br />
"writePriority":16<br />
},<br />
"eventDetectors":[<br />
],<br />
"plotType":"SPLINE",<br />
"rollup":"NONE",<br />
"unit":"",<br />
"templateXid":"Numeric 3min Integer",<br />
"simplifyType":"NONE",<br />
"chartColour":"black",<br />
"chartRenderer":{<br />
"type":"IMAGE",<br />
"timePeriodType":"DAYS",<br />
"numberOfPeriods":1<br />
},<br />
"dataSourceXid":"DS_4dc309c5-8959-488a-a217-c3d8e26b26e0",<br />
"defaultCacheSize":1,<br />
"deviceName":"testBACnet",<br />
"discardExtremeValues":false,<br />
"discardHighLimit":1.7976931348623157E308,<br />
"discardLowLimit":-1.7976931348623157E308,<br />
"intervalLoggingPeriod":3,<br />
"intervalLoggingSampleWindowSize":0,<br />
"overrideIntervalLoggingSamples":false,<br />
"preventSetExtremeValues":false,<br />
"purgePeriod":1,<br />
"readPermission":"test",<br />
"setExtremeHighLimit":1.7976931348623157E308,<br />
"setExtremeLowLimit":-1.7976931348623157E308,<br />
"setPermission":null,<br />
"tags":{<br />
},<br />
"textRenderer":{<br />
"type":"ANALOG",<br />
"useUnitAsSuffix":true,<br />
"unit":"",<br />
"renderedUnit":"",<br />
"format":"0"<br />
},<br />
"tolerance":0.0<br />
}<br />
]<br />
}</p>
{<br />
"xid":"A100",<br />
},<br />
],<br />
"unit":"",<br />
},<br />
"tags":{<br />
},<br />
"unit":"",<br />
"format":"0"<br />
},<br />
}<br />
]<br />
}</p>
]]></description><link>https://forum.mango-os.com/post/19500</link><guid isPermaLink="true">https://forum.mango-os.com/post/19500</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 10 Aug 2018 10:16:53 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 09 Aug 2018 20:19:26 GMT]]></title><description><![CDATA[<p dir="auto">Alas, I have limited faith in the assertion that the same thing is not doing the same thing. It's just not how things work. Repeating the assertion is not additional information. Knowing what versions they're on, and seeing the JSON for the points and data sources is more information. Let's find out what's different. Maybe it's a difference in your cache contents, and you need to clear that.</p>
]]></description><link>https://forum.mango-os.com/post/19495</link><guid isPermaLink="true">https://forum.mango-os.com/post/19495</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 09 Aug 2018 20:19:26 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 09 Aug 2018 19:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> But I have on another MangoES the same data source and the same JavaScript code and it's working, I don't get this error. An this is strange and I don't see why is happening...</p>
]]></description><link>https://forum.mango-os.com/post/19494</link><guid isPermaLink="true">https://forum.mango-os.com/post/19494</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Thu, 09 Aug 2018 19:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 09 Aug 2018 17:16:23 GMT]]></title><description><![CDATA[<p dir="auto">That second error seems like it would be a clear place to start. What would have populated that array with what you are trying to take the .value of? Maybe the points are not precisely the same? Maybe they differ in XID, or being enabled, or logging type?</p>
]]></description><link>https://forum.mango-os.com/post/19491</link><guid isPermaLink="true">https://forum.mango-os.com/post/19491</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 09 Aug 2018 17:16:23 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 09 Aug 2018 17:04:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Hi, I'm using core version 3.4.5 and UI version 3.4.7 on both mangoES.</p>
<p dir="auto">Below are some errors that I get in the developer console. I've marked with a black rectangle each error in belonging to each source code.</p>
<p dir="auto"><img src="https://camo.nodebb.org/af3fefcd9a4ff4574907ee747ec3471f0ab177d1?url=https%3A%2F%2Fi.imgur.com%2FMAps1UD.jpg" alt="0_1533834417214_err0r1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://camo.nodebb.org/aff5ac223439e4ea34e02b2e8dd1a7ed1fd07857?url=https%3A%2F%2Fi.imgur.com%2FwUv0ybs.jpg" alt="0_1533834429669_err0r2.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://camo.nodebb.org/84abdc24124df0b47bcd52008a998ad4e822281f?url=https%3A%2F%2Fi.imgur.com%2FIrR7aZz.jpg" alt="0_1533834434973_err0r3.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/19490</link><guid isPermaLink="true">https://forum.mango-os.com/post/19490</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Thu, 09 Aug 2018 17:04:27 GMT</pubDate></item><item><title><![CDATA[Reply to Chart&#x27;s not working on Thu, 09 Aug 2018 14:59:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi georgestefan,</p>
<p dir="auto">that's really not much information to contemplate. The only avenue of attacking the problem you have provided, having not said anything about the existence of errors in either the Mango/logs/ma.log file or the JavaScript developer console in the browser, is those three data points. So, if it's something there, you can share the JSON export of those three points from each system and check if they're the same to see what it could be about those points. I would encourage you to check for messages in your browser's console and ma.log file, and share the current version of the UI and Core from each.</p>
]]></description><link>https://forum.mango-os.com/post/19486</link><guid isPermaLink="true">https://forum.mango-os.com/post/19486</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 09 Aug 2018 14:59:23 GMT</pubDate></item></channel></rss>
